See <http://hudson.opengeo.org/hudson/job/geoserver-master/5698/changes>
Changes:
[Andrea Aime] Adding support for KVP parsing the wcs 2.0 scaling extension
[...truncated 947 lines...]
SEVERE: Error occurred processing a configuration change listener
java.lang.IllegalArgumentException: No loader for foo
at org.geoserver.config.ServicePersister.findServiceLoader(ServicePersister.java:94)
at org.geoserver.config.ServicePersister.handlePostServiceChange(ServicePersister.java:58)
at org.geoserver.config.impl.GeoServerImpl.firePostServiceModified(GeoServerImpl.java:372)
at org.geoserver.config.impl.GeoServerImpl.add(GeoServerImpl.java:228)
at org.geoserver.config.ServicePersisterTest.testAddWorkspaceLocalService(ServicePersisterTest.java:62)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
at org.junit.rules.RunRules.evaluate(RunRules.java:18)
at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Dec 16, 2012 2:27:51 PM org.geoserver.config.impl.GeoServerImpl fireServiceRemoved
at org.geoserver.config.ServicePersister.handleServiceRemove(ServicePersister.java:73)
at org.geoserver.config.impl.GeoServerImpl.fireServiceRemoved(GeoServerImpl.java:383)
at org.geoserver.config.impl.GeoServerImpl.remove(GeoServerImpl.java:278)
at org.geoserver.config.ServicePersisterTest.removeFooService(ServicePersisterTest.java:46)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:27)
Dec 16, 2012 2:27:51 PM org.geoserver.config.impl.GeoServerImpl firePostServiceModified
at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:68)
at org.geoserver.config.ServicePersisterTest.testRemoveWorkspaceLocalService(ServicePersisterTest.java:77)
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.8 sec
Running org.geoserver.config.GeoServerPersisterTest
Tests run: 42, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.173 sec
Running org.geoserver.config.util.AuthorityURLInfoInfoListConverterTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.069 sec
Running org.geoserver.config.util.XStreamPersisterTest
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.078 sec
Running org.geoserver.config.util.LayerIdentifierInfoListConverterTest
[{"authority":"auth1","identifier":"IDENTIFIER_1"},{"authority":"auth2","identifier":"IDENTIFIER_2"}]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.config.UpdateSequenceListenerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.733 sec
Running org.geoserver.feature.retype.RetypingDataStoreTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceMockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.feature.retype.FullyRetypingDataStoreTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Running org.geoserver.feature.retype.RetypingFeatureSourceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.feature.ReprojectingFeatureCollectionTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.081 sec
Running org.geoserver.ows.CustomManglerTest
16 Dec 14:27:56 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
16 Dec 14:27:56 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockFilter Transaction'
16 Dec 14:27:56 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.RetypingDataStoreTest.testLockUnlockQuery Transaction'
16 Dec 14:27:56 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockQuery Transaction'
16 Dec 14:27:56 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.feature.retype.FullyRetypingDataStoreTest.testLockUnlockFilter Transaction'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.788 sec
Running org.geoserver.ows.URLManglersTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.892 sec
Running org.geoserver.ows.kvp.NamespaceKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.ows.LocalWorkspaceSecureCatalogTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.017 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.37 sec
Running org.geoserver.logging.LoggingStartupContextListenerTest
org.apache.log4j.spi.RootLogger@anonymised.com
log4j:WARN No appenders could be found for logger (org.geoserver.platform).
log4j:WARN Please initialize the log4j system properly.
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.geoserver.logging.LegacyLoggingImporterTest
Results :
Tests in error:
testEmptyPassword(org.geoserver.security.xml.XMLUserGroupServiceTest)
Tests run: 482, Failures: 0, Errors: 1, Skipped: 1
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 2 minutes 52 seconds
[INFO] Finished at: Sun Dec 16 14:27:58 UTC 2012
[INFO] Final Memory: 58M/389M
