[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5734
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5734/changes&gt;
Changes:
[Davide Savazzi] GEOT-4358: added style test for isCoverage filter function
[Martin Davis] Fixed typo in User Guide Rendering Transformation section
[Andrea Aime] [GEOS-5539] Support raster custom dimensions generated at runtime
[...truncated 7905 lines...]
09 Jan 19:49:29 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
  at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1240)
  at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:209)
  at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:79)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1352)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1371)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1306)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:918)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:901)
  at org.geoserver.wms.WMSServiceExceptionTest.testJsonException130(WMSServiceExceptionTest.java:94)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.091 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.geoserver.wms.ResourceAccessManagerWMSTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.435 sec
Running org.geoserver.wms.legendgraphic.AbstractLegendGraphicOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.974 sec
Running org.geoserver.wms.legendgraphic.GetLegendGraphicKvpReaderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.877 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.341 sec
Running org.geoserver.wms.map.GIFMapResponseTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.167 sec
Running org.geoserver.wms.map.GetMapKvpRequestReaderTest
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.831 sec
Running org.geoserver.wms.map.quantize.ColorIndexerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.wms.map.quantize.QuantizerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.959 sec
Running org.geoserver.wms.map.quantize.ColorMapTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.001 sec
Running org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest
09 Jan 19:49:40 ERROR [geoserver.ows] -
java.lang.RuntimeException: Unable to find function isCoverage
  at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:205)
  at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:152)
  at org.geotools.filter.FunctionFinder.findFunction(FunctionFinder.java:127)
  at org.geotools.filter.FilterFactoryImpl.function(FilterFactoryImpl.java:754)
  at org.geotools.filter.ExpressionDOMParser.expression(ExpressionDOMParser.java:423)
  at org.geotools.filter.FilterDOMParser.parseFilter(FilterDOMParser.java:346)
  at org.geotools.styling.SLDParser.parseFilter(SLDParser.java:954)
  at org.geotools.styling.SLDParser.parseRule(SLDParser.java:910)
  at org.geotools.styling.SLDParser.parseFeatureTypeStyle(SLDParser.java:835)
  at org.geotools.styling.SLDParser.parseStyle(SLDParser.java:791)
  at org.geotools.styling.SLDParser.parseUserLayer(SLDParser.java:495)
  at org.geotools.styling.SLDParser.parseDescriptor(SLDParser.java:450)
  at org.geotools.styling.SLDParser.parseSLD(SLDParser.java:409)
  at org.geoserver.catalog.Styles$Handler$1.parse(Styles.java:282)
  at org.geoserver.catalog.Styles.parse(Styles.java:92)
  at org.geoserver.catalog.ResourcePool.getStyle(ResourcePool.java:1314)
  at org.geoserver.catalog.impl.StyleInfoImpl.getStyle(StyleInfoImpl.java:84)
  at sun.reflect.GeneratedMethodAccessor115.invoke(Unknown Source)
  at org.geoserver.catalog.impl.ModificationProxy.invoke(ModificationProxy.java:144)
  at $Proxy12.getStyle(Unknown Source)
  at org.geoserver.wms.WMS.getStyleByName(WMS.java:201)
  at org.geoserver.wms.map.GetMapKvpRequestReader.parseStyles(GetMapKvpRequestReader.java:1371)
  at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:309)
  at org.geoserver.wms.WMSTestSupport.getAsImage(WMSTestSupport.java:435)
  at org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest.testNoOutline(RasterWithoutOutlineMapStyleTest.java:40)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.533 sec <<< FAILURE!
testNoOutline(org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest) Time elapsed: 1519 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
  at org.junit.Assert.assertEquals(Assert.java:125)
  at org.junit.Assert.assertEquals(Assert.java:147)
  at org.geoserver.wms.WMSTestSupport.getAsImage(WMSTestSupport.java:436)
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.map.GetMapIntegrationTest
09 Jan 19:49:42 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-expected.png with image2
09 Jan 19:49:42 ERROR [image.test] - perceptualdiff is not available, can't compare src/test/resources/org/geoserver/wms/map/indexed-bg-expected.png with image2
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.94 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.095 sec
Running org.geoserver.wms.georss.AtomGeoRSSTransformerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.241 sec
Running org.geoserver.wms.georss.RSSGeoRSSTransformerTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.028 sec
Running org.geoserver.wms.GetMapOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.947 sec
Running org.geoserver.wms.RenderingBufferTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.186 sec
Running org.geoserver.wms.decoration.MapDecorationLayoutTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.114 sec
Running org.geoserver.wms.decoration.ScaleRatioDecorationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.wms.WMSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.65 sec
Results :
Failed tests: testGetMapInvalidValue(org.geoserver.wms.wms_1_1_1.DynamicDimensionsTest)
  testNoOutline(org.geoserver.wms.map.RasterWithoutOutlineMapStyleTest): expected:<[image/png]> but was:<[application/vnd.ogc.se_xml]>
Tests run: 505, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 10 minutes 19 seconds
[INFO] Finished at: Wed Jan 09 19:49:50 UTC 2013
[INFO] Final Memory: 57M/324M
Changes:
this function has just been added on GeoTools:
https://github.com/geotools/geotools/pull/96
Davide Savazzi
