[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5737
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5737/changes&gt;
Changes:
[Andrea Aime] Improving range subsettting code and coverage response delegate class
[Andrea Aime] Make WCS 2.0 work against both lon/lat and lat/lon oriented coverages
[Andrea Aime] Improved WCS 2.0 GetCapabilities output
[Andrea Aime] Fixing dynamic dimension tests after changes to coverage delegate handlers
[...truncated 5387 lines...]
org.geoserver.wfs.WFSException: Request parsing failed
  at org.geoserver.wfs.xml.v2_0.WfsXmlReader.read(WfsXmlReader.java:58)
  at org.geoserver.ows.Dispatcher.parseRequestXML(Dispatcher.java:1472)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:631)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1352)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1371)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1306)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1288)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1115)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1050)
  at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1030)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1249)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1232)
  at org.geoserver.wfs.v2_0.GetFeatureTest.testInvalidRequest(GetFeatureTest.java:868)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Caused by: org.xml.sax.SAXParseException: The element type "fes:Filter" must be terminated by the matching end-tag "</fes:Filter>".
  at org.apache.xerces.util.ErrorHandlerWrapper.createSAXParseException(Unknown Source)
  at org.apache.xerces.util.ErrorHandlerWrapper.fatalError(Unknown Source)
  at org.apache.xerces.impl.XMLErrorReporter.reportError(Unknown Source)
  at org.apache.xerces.impl.XMLScanner.reportFatalError(Unknown Source)
  at org.apache.xerces.impl.XMLNSDocumentScannerImpl.scanEndElement(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl$FragmentContentDispatcher.dispatch(Unknown Source)
  at org.apache.xerces.impl.XMLDocumentFragmentScannerImpl.scanDocument(Unknown Source)
  at org.apache.xerces.parsers.XML11Configuration.parse(Unknown Source)
  at org.apache.xerces.parsers.XMLParser.parse(Unknown Source)
  at org.apache.xerces.parsers.AbstractSAXParser.parse(Unknown Source)
  at org.geotools.xml.Parser.parse(Parser.java:239)
  at org.geoserver.wfs.xml.WFSXmlUtils.parseRequest(WFSXmlUtils.java:82)
  at org.geoserver.wfs.xml.v2_0.WfsXmlReader.read(WfsXmlReader.java:53)
  ... 57 more
Tests run: 43, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.072 sec
Running org.geoserver.wfs.v2_0.GetFeaturePagingTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.093 sec
Running org.geoserver.wfs.v2_0.DescribeFeatureTypeTest
10 Jan 14:57:38 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: Streams.
Strict WFS protocol conformance is being applied.
Make sure the type name is correctly qualified
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:162)
  at org.geoserver.wfs.DefaultWebFeatureService20.describeFeatureType(DefaultWebFeatureService20.java:88)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy25.describeFeatureType(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:918)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:901)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:886)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1183)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1147)
  at org.geoserver.wfs.v2_0.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:236)
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.704 sec
Running org.geoserver.wfs.v2_0.GetCapabilitiesTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.652 sec
Running org.geoserver.wfs.v2_0.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.423 sec
Running org.geoserver.wfs.RetypingTransactionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.109 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 24.253 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.841 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.888 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.053 sec
Results :
Tests run: 451, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.3-SNAPSHOT/wfs-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.3-SNAPSHOT/wfs-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.3-SNAPSHOT/wfs-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.3-SNAPSHOT/wfs-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = e2a5fc6ab55fe288e390e7189c21ea21caf1538b
[INFO] [GitCommitIdMojo] build.commit.id = e2a5fc6ab55fe288e390e7189c21ea21caf1538b
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing dynamic dimension tests after changes to coverage delegate handlers
[INFO] [GitCommitIdMojo] build.commit.time = 10.01.2013 @ 14:24:33 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e2a5fc6
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing dynamic dimension tests after changes to coverage delegate handlers
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 10-Jan-2013 14:51
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 10.01.2013 @ 14:58:12 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/src/main/resources&gt;
[INFO] Compiling 16 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/src/main/java/org/geoserver/wcs/responses/GeoTIFFCoverageResponseDelegate.java&gt;:\[101,48\] cannot find symbol
symbol : variable RETAIN_AXES_ORDER
[INFO] Total time: 6 minutes 19 seconds
[INFO] Finished at: Thu Jan 10 14:58:14 UTC 2013
[INFO] Final Memory: 57M/389M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5738/&gt;
