See <http://hudson.opengeo.org/hudson/job/geoserver-master/5742/changes>
Changes:
[Mauro Bartolomeoli] Added support for LayerGroup to the WMS GetLegendGraphic action
[Mauro Bartolomeoli] fixed some bugs and added forceTitles legend option
[Mauro Bartolomeoli] fixed layer, style and rule parameters size mismatch; fixed tests not running on linux
[Mauro Bartolomeoli] GetLegendGraphic LayerGroup: fixed issue with fontAntiAliasing legend option
[Andrea Aime] [GEOS-5551] WFS 1.0 capabilities will NPE with misconfigured OGR and XSLT output formats
[...truncated 32988 lines...]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 91f21d2d5d260b9e5f31003a234c3931e87b7537
[INFO] [GitCommitIdMojo] build.commit.id = 91f21d2d5d260b9e5f31003a234c3931e87b7537
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5551] WFS 1.0 capabilities will NPE with misconfigured OGR and XSLT output formats
[INFO] [GitCommitIdMojo] build.commit.time = 11.01.2013 @ 10:43:39 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 91f21d2
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5551] WFS 1.0 capabilities will NPE with misconfigured OGR and XSLT output formats
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 11-Jan-2013 10:54
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 11.01.2013 @ 11:33:42 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/target/monitor-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/monitor/2.3-SNAPSHOT/monitor-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/target/monitor-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/monitor/2.3-SNAPSHOT/monitor-2.3-SNAPSHOT-tests.jar
[INFO] Building Core Monitor Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/target>
[INFO] Copying 7 resources
[INFO] Copying 17 resources
[INFO] Compiling 59 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/target/classes>
[INFO] Copying 2 resources
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/target/surefire-reports>
T E S T S
Running org.geoserver.monitor.rest.RequestResourceTest
Jan 11, 2013 11:33:52 AM org.geoserver.platform.GeoServerExtensions checkContext
WARNING: Extension lookup occured, but ApplicationContext is unset.
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.942 sec
Running org.geoserver.monitor.MemoryMonitorDAOTest
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.03 sec
Running org.geoserver.monitor.ows.ControlFlowCallbackProxyTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.monitor.ows.MonitorCallbackTest
Jan 11, 2013 11:33:53 AM org.geoserver.platform.GeoServerExtensions checkContext
Jan 11, 2013 11:33:54 AM org.vfny.geoserver.crs.GeoserverWKTOperationFactory getDefinitionsURL
INFO: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/user_projections/epsg_operations.properties> was not found, using the default set of coordinate operation overrides (normally empty)
Jan 11, 2013 11:33:55 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 16, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 2.351 sec <<< FAILURE!
testWMSGetLegendGraphic(org.geoserver.monitor.ows.MonitorCallbackTest) Time elapsed: 8 sec <<< ERROR!
java.lang.IllegalArgumentException: No such property 'layer' for object org.geoserver.wms.GetLegendGraphicRequest@anonymised.com
at org.geoserver.ows.util.OwsUtils.get(OwsUtils.java:155)
at org.geoserver.monitor.ows.wms.GetLegendGraphicHandler.getLayers(GetLegendGraphicHandler.java:24)
at org.geoserver.monitor.ows.RequestObjectHandler.handle(RequestObjectHandler.java:42)
at org.geoserver.monitor.ows.MonitorCallback.operationDispatched(MonitorCallback.java:93)
at org.geoserver.monitor.ows.MonitorCallbackTest.testWMSGetLegendGraphic(MonitorCallbackTest.java:304)
at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:44)
at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:41)
at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:76)
at org.junit.runners.ParentRunner$3.run(ParentRunner.java:193)
at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:52)
at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:191)
at org.junit.runners.ParentRunner.access$000(ParentRunner.java:42)
at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:184)
at org.junit.runners.ParentRunner.run(ParentRunner.java:236)
Running org.geoserver.monitor.MonitorServletResponseTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.monitor.PipeliningTaskQueueTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.009 sec
Running org.geoserver.monitor.MonitorServletRequestTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.monitor.GeoIPPostProcessorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.monitor.MonitorFilterTest
Jan 11, 2013 11:33:59 AM org.geoserver.monitor.MonitorFilter <init>
INFO: Monitor extension enabled
Jan 11, 2013 11:33:59 AM org.geoserver.platform.GeoServerExtensions checkContext
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Results :
Tests in error:
testWMSGetLegendGraphic(org.geoserver.monitor.ows.MonitorCallbackTest): No such property 'layer' for object org.geoserver.wms.GetLegendGraphicRequest@anonymised.com
Tests run: 57, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/monitor/core/target/surefire-reports> for the individual test results.
[INFO] Total time: 39 minutes 8 seconds
[INFO] Finished at: Fri Jan 11 11:33:59 UTC 2013
[INFO] Final Memory: 79M/223M
