[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5769
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5769/changes&gt;
Changes:
[Andrea Aime] WCS20: More tests for multiband rasters, adding first cut of resource limits for WCS
[Andrea Aime] WCS 2.0, getcaps tests improvements
[Andrea Aime] fixing tests on windows + getcap
[Andrea Aime] GEOS-5566
[Andrea Aime] Fixing the build so that it works both on windows and linux
[jdeolive] refactoring resource pool, making it possible to plug in custom implementation
[David Winslow] Update to use geoscript/geocss 0.7.5
[Andrea Aime] [GEOS-5570] QueryProcess fails if called with an OGC filter (either 1.0 or 1.1)
[...truncated 32868 lines...]
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.69 sec
Running org.geoserver.wps.gs.StyleCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.558 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.618 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.167 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Point2D.Double[0.0, 250.0]
Point2D.Double[10.0, 265.0]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.3 sec
Running org.geoserver.wps.gs.CropCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.689 sec
Running org.geoserver.wps.gs.SimplifyProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.624 sec
Running org.geoserver.wps.gs.RangeLookupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.895 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.595 sec
Running org.geoserver.wps.gs.ReprojectProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.787 sec
Running org.geoserver.wps.gs.StoreCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.082 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.253 sec
Running org.geoserver.wps.gs.RasterZonalStatsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.844 sec
Running org.geoserver.wps.gs.ContourProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.078 sec
Running org.geoserver.wps.gs.VectorZonalStatsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.625 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.911 sec
Running org.geoserver.wps.ExecuteTest
POLYGON ((0 1, 0 2, 0.0192147195967696 2.1950903220161284, 0.0761204674887133 2.38268343236509, 0.1685303876974546 2.555570233019602, 0.2928932188134525 2.7071067811865475, 0.444429766980398 2.8314696123025453, 0.6173165676349103 2.923879532511287, 0.8049096779838718 2.9807852804032304, 1 3, 2 3, 2.1950903220161284 2.9807852804032304, 2.3826834323650896 2.923879532511287, 2.555570233019602 2.8314696123025453, 2.7071067811865475 2.7071067811865475, 2.8314696123025453 2.555570233019602, 2.923879532511287 2.3826834323650896, 2.9807852804032304 2.1950903220161284, 3 2, 3 1, 2.9807852804032304 0.8049096779838718, 2.923879532511287 0.6173165676349102, 2.8314696123025453 0.4444297669803978, 2.7071067811865475 0.2928932188134525, 2.555570233019602 0.1685303876974548, 2.3826834323650896 0.0761204674887133, 2.1950903220161284 0.0192147195967696, 2 0, 1 0, 0.8049096779838718 0.0192147195967696, 0.6173165676349103 0.0761204674887133, 0.444429766980398 0.1685303876974546, 0.2928932188134525 0.2928932188134524, 0.1685303876974546 0.4444297669803978, 0.0761204674887133 0.6173165676349102, 0.0192147195967696 0.8049096779838714, 0 1))
17 Jan 17:04:08 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Sorry dude, things went pear shaped...
  at org.geoserver.wps.ExecuteTest.testProcessFailure(ExecuteTest.java:818)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
17 Jan 17:04:09 ERROR [wps.executor] - Request failed during output encoding
java.io.IOException
  at org.geoserver.ows.XmlObjectEncodingResponse.write(XmlObjectEncodingResponse.java:55)
  at org.geoserver.wps.executor.WPSExecutionManager$AsynchronousProcessContext.writeOutResponse(WPSExecutionManager.java:372)
  at org.geoserver.wps.executor.WPSExecutionManager$AsynchronousProcessContext.writeResponseFile(WPSExecutionManager.java:343)
  at org.geoserver.wps.executor.WPSExecutionManager$1.run(WPSExecutionManager.java:117)
  at java.util.concurrent.Executors$RunnableAdapter.call(Executors.java:441)
  at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
  at java.util.concurrent.FutureTask.run(FutureTask.java:138)
  at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
  at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
  at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.RuntimeException: java.lang.RuntimeException: Toasted!
  at org.geotools.xml.Encoder.encode(Encoder.java:715)
  at org.geotools.xml.Encoder.encode(Encoder.java:588)
  at org.geoserver.ows.XmlObjectEncodingResponse.write(XmlObjectEncodingResponse.java:52)
  ... 9 more
Caused by: java.lang.RuntimeException: Toasted!
  at org.geoserver.wps.ExecuteTest$1.openIterator(ExecuteTest.java:1034)
  at org.geotools.feature.collection.AbstractFeatureCollection.iterator(AbstractFeatureCollection.java:163)
  at org.geotools.xml.Encoder.encode(Encoder.java:1026)
  at org.geoserver.wps.ppio.WFSPPIO.encode(WFSPPIO.java:191)
  at org.geoserver.wps.XMLEncoderDelegate.encode(XMLEncoderDelegate.java:30)
  at org.geotools.xml.Encoder.encode(Encoder.java:712)
  ... 11 more
Tests run: 29, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.713 sec
Running org.geoserver.wps.SnapTest
17 Jan 17:04:15 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Parameter features is missing but has min multiplicity > 0
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:633)
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:501)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:219)
  at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:193)
org.geotools.process.ProcessException: Parameter point is missing but has min multiplicity > 0
17 Jan 17:04:18 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: Process execution 8d84b638-1b41-40a1-8e8e-e904f1e5dff1 failed
  at org.geoserver.wps.executor.DefaultProcessManager.getOutput(DefaultProcessManager.java:161)
  at org.geoserver.wps.executor.WPSExecutionManager.getOutput(WPSExecutionManager.java:177)
  at org.geoserver.wps.Execute.run(Execute.java:75)
  at org.geoserver.wps.DefaultWebProcessingService.execute(DefaultWebProcessingService.java:76)
  at sun.reflect.GeneratedMethodAccessor187.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy25.execute(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor186.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1352)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1371)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1306)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1288)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1115)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1050)
  at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1030)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1249)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1232)
  at org.geoserver.wps.SnapTest.testWrongCRS(SnapTest.java:449)
Caused by: org.geoserver.wps.WPSException: Failed to retrieve value for input crs
  at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:37)
  at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:616)
Caused by: org.opengis.referencing.NoSuchAuthorityCodeException: No code "EPSG:EPSG" from authority "European Petroleum Survey Group" found for object of type "IdentifiedObject".
  at org.geotools.referencing.factory.AbstractAuthorityFactory.noSuchAuthorityCode(AbstractAuthorityFactory.java:951)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.getWKT(PropertyAuthorityFactory.java:316)
  at org.geotools.referencing.factory.PropertyAuthorityFactory.createCoordinateReferenceSystem(PropertyAuthorityFactory.java:390)
  at org.geotools.referencing.factory.BufferedAuthorityFactory.createCoordinateReferenceSystem(BufferedAuthorityFactory.java:783)
  at org.geotools.referencing.factory.AuthorityFactoryAdapter.createCoordinateReferenceSystem(AuthorityFactoryAdapter.java:801)
  at org.geotools.referencing.factory.FallbackAuthorityFactory.createCoordinateReferenceSystem(FallbackAuthorityFactory.java:640)
  at org.geotools.referencing.factory.ThreadedAuthorityFactory.createCoordinateReferenceSystem(ThreadedAuthorityFactory.java:731)
  at org.geotools.referencing.DefaultAuthorityFactory.createCoordinateReferenceSystem(DefaultAuthorityFactory.java:179)
  at org.geotools.referencing.CRS.decode(CRS.java:489)
  at org.geotools.referencing.CRS.decode(CRS.java:417)
  at org.geoserver.wps.ppio.CoordinateReferenceSystemPPIO.decode(CoordinateReferenceSystemPPIO.java:29)
  at org.geoserver.wps.executor.SimpleInputProvider.getValue(SimpleInputProvider.java:136)
  at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:35)
  ... 9 more
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.427 sec
Results :
Failed tests: testFilterOGC(org.geoserver.wps.gs.QueryProcessTest): expected:<[1]> but was:<[0]>
Tests run: 130, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/wps/wps-core/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 39 minutes 53 seconds
[INFO] Finished at: Thu Jan 17 17:04:18 UTC 2013
[INFO] Final Memory: 82M/243M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5770/changes&gt;
