[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5892
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5892/changes&gt;
Changes:
[Andrea Aime] First cut at a kml refactor
[jdeolive] fixing typo in python buffer example
[...truncated 5504 lines...]
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy25.describeFeatureType(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1355)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1374)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1309)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:921)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:904)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:889)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1186)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1150)
  at org.geoserver.wfs.v2_0.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:236)
  at org.junit.runners.model.FrameworkMethod$1.runReflectiveCall(FrameworkMethod.java:45)
  at org.junit.internal.runners.model.ReflectiveCallable.run(ReflectiveCallable.java:15)
  at org.junit.runners.model.FrameworkMethod.invokeExplosively(FrameworkMethod.java:42)
  at org.junit.internal.runners.statements.InvokeMethod.evaluate(InvokeMethod.java:20)
  at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:28)
  at org.junit.internal.runners.statements.RunAfters.evaluate(RunAfters.java:30)
  at org.junit.rules.RunRules.evaluate(RunRules.java:18)
  at org.junit.runners.ParentRunner.runLeaf(ParentRunner.java:263)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:68)
  at org.junit.runners.BlockJUnit4ClassRunner.runChild(BlockJUnit4ClassRunner.java:47)
  at org.junit.runners.ParentRunner$3.run(ParentRunner.java:231)
  at org.junit.runners.ParentRunner$1.schedule(ParentRunner.java:60)
  at org.junit.runners.ParentRunner.runChildren(ParentRunner.java:229)
  at org.junit.runners.ParentRunner.access$000(ParentRunner.java:50)
  at org.junit.runners.ParentRunner$2.evaluate(ParentRunner.java:222)
  at org.junit.runners.ParentRunner.run(ParentRunner.java:300)
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.974 sec
Running org.geoserver.wfs.v2_0.GetCapabilitiesTest
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.832 sec
Running org.geoserver.wfs.v2_0.SrsNameTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.509 sec
Running org.geoserver.wfs.RetypingTransactionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.785 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.896 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.345 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.386 sec
Running org.geoserver.wfs.SrsNameTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.462 sec
Results :
Tests run: 456, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = fixing typo in python buffer example
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 01.03.2013 @ 15:37:48 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 01-Mar-2013 15:38
[INFO] [GitCommitIdMojo] build.build.time = 01.03.2013 @ 15:43:10 UTC
[INFO] [GitCommitIdMojo] build.branch = 0a48f7a5e38ba003a691f53dfb3226e0a067cf32
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 0a48f7a
[INFO] [GitCommitIdMojo] build.commit.id = 0a48f7a5e38ba003a691f53dfb3226e0a067cf32
[INFO] [GitCommitIdMojo] build.commit.message.full = fixing typo in python buffer example
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/src/main/resources&gt;
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/src/test/resources&gt;
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 01.03.2013 @ 15:43:13 UTC
[INFO] Copying 1 resource
[INFO] Copying 64 resources
[INFO] snapshot org.geotools:gt-svg:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:10-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 165 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java&gt;:\[341,8\] cannot find symbol
symbol : class Map
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java&gt;:\[341,40\] cannot find symbol
symbol : class HashMap
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/src/main/java/org/geoserver/wms/WMSMapContent.java&gt;:\[344,22\] cannot find symbol
symbol : variable StreamingRenderer
[INFO] 3 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
symbol : class Map
[INFO] Total time: 4 minutes 43 seconds
[INFO] Finished at: Fri Mar 01 15:43:19 UTC 2013
[INFO] Final Memory: 62M/381M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5893/&gt;
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.011 sec
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.416 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.537 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.925 sec
Tests run: 20, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.684 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.366 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.53 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.454 sec
Results :
[INFO] [GitCommitIdMojo] build.timestamp = 01-Mar-2013 15:44
[INFO] [GitCommitIdMojo] build.build.time = 01.03.2013 @ 15:48:49 UTC
[INFO] [GitCommitIdMojo] build.build.time = 01.03.2013 @ 15:48:51 UTC
symbol : class Map
[INFO] 3 errors
symbol : class Map
[INFO] Total time: 4 minutes 23 seconds
[INFO] Finished at: Fri Mar 01 15:48:57 UTC 2013
[INFO] Final Memory: 61M/382M
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5894/changes&gt;
