[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #5944
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5944/changes&gt;
Changes:
[Davide Savazzi] GEOS5273: disabled entities evaluation for remote SLD files
[Davide Savazzi] GEOS5273: moved external entity setting to global configuration
[Davide Savazzi] GEOS5707: disabled entities evaluation in WFS POST requests
[Davide Savazzi] GEOS5273 - GEOS5707: created EntityResolverProvider
[...truncated 7949 lines...]
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:183)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:150)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:32)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:172)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:202)
  at $Proxy25.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor357.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:774)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:272)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:789)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:727)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1355)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1374)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1309)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1291)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1118)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsServletResponse(GeoServerSystemTestSupport.java:1053)
  at org.geoserver.test.GeoServerSystemTestSupport.post(GeoServerSystemTestSupport.java:1033)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1252)
  at org.geoserver.test.GeoServerSystemTestSupport.postAsDOM(GeoServerSystemTestSupport.java:1235)
  at org.geoserver.wfs.v2_0.TransactionTest.testUpdateLayerQualified(TransactionTest.java:703)
18 Mar 16:40:49 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:110)
  at org.geoserver.wfs.DefaultWebFeatureService20.transaction(DefaultWebFeatureService20.java:120)
  at sun.reflect.GeneratedMethodAccessor358.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:318)
  at org.geoserver.wfs.v2_0.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:635)
Caused by: java.lang.StringIndexOutOfBoundsException: String index out of range: -1
  at java.lang.String.substring(String.java:1937)
  at org.geoserver.wfs.WFSException.init(WFSException.java:103)
  at org.geoserver.wfs.WFSException.<init>(WFSException.java:23)
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:120)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:225)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
  ... 70 more
Tests run: 16, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.714 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.362 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.563 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.656 sec
Running org.geoserver.wfs.xml.v1_1.NativeTypeParsingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Results :
Failed tests: testPostWithMatchingUrnBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
  testWithSRS(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<1> but was:<0>
  testPostWithBboxFilter(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
  testPostWithBoundsEnabled(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
  testWithSillyLiteral(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
  testWithGmlObjectId(org.geoserver.wfs.v1_1.GetFeatureTest): expected:<[wfs:FeatureCollection]> but was:<[ows:ExceptionReport]>
Tests run: 459, Failures: 6, Errors: 0, Skipped: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.612s]
[INFO] Core Platform Module .............................. SUCCESS [4.613s]
[INFO] Open Web Service Module ........................... SUCCESS [14.156s]
[INFO] Main Module ....................................... SUCCESS [1:54.273s]
[INFO] Web Feature Service Module ........................ FAILURE [1:46.722s]
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 4:13.195s
[INFO] Finished at: Mon Mar 18 16:40:51 UTC 2013
[INFO] Final Memory: 27M/347M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project wfs: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :wfs
See <http://hudson.opengeo.org/hudson/job/geoserver-master/5945/changes&gt;
