See <http://hudson.opengeo.org/hudson/job/geoserver-master/6005/>
Started by user hudson
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/> - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 1d29fea1a7ee281ede82ee48a38c71d8b3151cef (origin/master)
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/geoserver/geoserver.git
Commencing build of Revision 1d29fea1a7ee281ede82ee48a38c71d8b3151cef (origin/master)
Checking out Revision 1d29fea1a7ee281ede82ee48a38c71d8b3151cef (origin/master)
FATAL: Error performing command: git checkout -f 1d29fea1a7ee281ede82ee48a38c71d8b3151cef
null
hudson.plugins.git.GitException: Error performing command: git checkout -f 1d29fea1a7ee281ede82ee48a38c71d8b3151cef
null
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:730)
at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:692)
at hudson.plugins.git.GitAPI.launchCommand(GitAPI.java:703)
at hudson.plugins.git.GitAPI.checkoutBranch(GitAPI.java:798)
at hudson.plugins.git.GitSCM$1.invoke(GitSCM.java:702)
at hudson.plugins.git.GitSCM$1.invoke(GitSCM.java:687)
at hudson.FilePath.act(FilePath.java:758)
at hudson.FilePath.act(FilePath.java:740)
at hudson.plugins.git.GitSCM.getBuildConfig(GitSCM.java:687)
at hudson.plugins.git.GitSCM.checkout(GitSCM.java:647)
at hudson.model.AbstractProject.checkout(AbstractProject.java:1479)
at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: java.lang.InterruptedException
at java.lang.Object.wait(Native Method)
at java.lang.Object.wait(Object.java:485)
at java.lang.UNIXProcess.waitFor(UNIXProcess.java:165)
at hudson.Proc$LocalProc.join(Proc.java:226)
at hudson.Launcher$ProcStarter.join(Launcher.java:281)
at hudson.plugins.git.GitAPI.launchCommandIn(GitAPI.java:717)
... 16 more
