[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6019
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6019/changes&gt;
Changes:
[Andrea Aime] Moving KML test data to the kml module
[Andrea Aime] Porting more tests from kml to kml2 module, fixing placemarks not being generated when working in ground overlay mode + kmplacemark being true
[...truncated 27132 lines...]
testStyleConverter(org.geoserver.kml.KMLTransformerTest) Time elapsed: 2 sec <<< ERROR!
java.lang.NullPointerException
  at org.geoserver.wms.WMSTestSupport.createMapLayer(WMSTestSupport.java:189)
  at org.geoserver.kml.KMLTransformerTest.testStyleConverter(KMLTransformerTest.java:445)
testRelativeDynamicSymbolizer(org.geoserver.kml.KMLTransformerTest) Time elapsed: 2 sec <<< ERROR!
  at org.geoserver.kml.KMLTransformerTest.testRelativeDynamicSymbolizer(KMLTransformerTest.java:489)
Running org.geoserver.kml.KMLVectorTransformerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.063 sec
Running org.geoserver.kml.KMZMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.196 sec
Results :
Failed tests: testVectorScaleRange(org.geoserver.kml.KMLTest): expected:<3> but was:<0>
  testMissingGraphic(org.geoserver.kml.KMLTest): expected:<1> but was:<0>
Tests in error:
  testGeometryRegionator(org.geoserver.kml.GeoSearchKMLTest)
  testBogusRegionator(org.geoserver.kml.GeoSearchKMLTest)
  testDuplicateAttribute(org.geoserver.kml.GeoSearchKMLTest)
  testRandomRegionator(org.geoserver.kml.GeoSearchKMLTest)
  testDataRegionator(org.geoserver.kml.GeoSearchKMLTest)
  testBigGeometries(org.geoserver.kml.GeoSearchKMLTest)
  testOutput(org.geoserver.kml.GeoSearchKMLTest)
  testStrategyChangesStuff(org.geoserver.kml.GeoSearchKMLTest)
  testWorldBoundsSuperOverlay(org.geoserver.kml.KMLSuperOverlayTransformerTest)
  testKmltitleFormatOption(org.geoserver.kml.KMLSuperOverlayTransformerTest)
  testSubtileSuperOverlay(org.geoserver.kml.KMLSuperOverlayTransformerTest)
  testVectorWithRemoteLayer(org.geoserver.kml.KMLTest)
  testKmltitleFormatOption(org.geoserver.kml.KMLTest)
  testEncodeTime(org.geoserver.kml.KMLTest)
  testKmltitleFormatOptionWithMultipleLayers(org.geoserver.kml.KMLTest)
  testVectorTransformer(org.geoserver.kml.KMLTransformerTest)
  testDynamicSymbolizer(org.geoserver.kml.KMLTransformerTest)
  testProxyBaseURL(org.geoserver.kml.KMLTransformerTest)
  testFilteredData(org.geoserver.kml.KMLTransformerTest)
  testExternalGraphicBackround(org.geoserver.kml.KMLTransformerTest)
  testExternalGraphicSubdir(org.geoserver.kml.KMLTransformerTest)
Tests run: 63, Failures: 2, Errors: 32, Skipped: 0
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping Core Monitor Extension
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 10.015 sec
Running org.geoserver.security.web.user.UserListPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.763s]
[INFO] Core Platform Module .............................. SUCCESS [6.030s]
[INFO] Open Web Service Module ........................... SUCCESS [13.163s]
[INFO] Main Module ....................................... SUCCESS [2:36.538s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:08.845s]
[INFO] Web Coverage Service Module ....................... SUCCESS [7.261s]
[INFO] Web Map Service Module ............................ SUCCESS [3:24.023s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.594s]
[INFO] Core UI Module .................................... SUCCESS [1:43.609s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [47.485s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [51.631s]
[INFO] Web Map Service KML output formats ................ FAILURE [43.616s]
[INFO] REST Support Module ............................... SUCCESS [21.181s]
[INFO] WFS UI Module ..................................... SUCCESS [20.459s]
[INFO] Community Space ................................... SUCCESS [0.283s]
[INFO] Printing Module ................................... SUCCESS [20.338s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [12.843s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.273s]
[INFO] Application Schema Support ........................ SUCCESS [0.296s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.998s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.278s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.968s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.522s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.827s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.998s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.493s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.504s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.785s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [26.993s]
[INFO] Excel Output Format ............................... SUCCESS [28.616s]
[INFO] Validation Module ................................. SUCCESS [4.646s]
[INFO] Chart external graphics support ................... SUCCESS [1.119s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.665s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.526s]
[INFO] OWS request flow controller ....................... SUCCESS [14.085s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.408s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:04.403s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.791s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.947s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.471s]
[INFO] BUILD FAILURE
[INFO] Total time: 13:45.365s (Wall Clock)
[INFO] Finished at: Fri Apr 26 17:37:50 UTC 2013
[INFO] Final Memory: 44M/162M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6020/changes&gt;
