See <http://hudson.opengeo.org/hudson/job/geoserver-master/6036/changes>
Changes:
[Niels Charlier] GEOS-5755 Support Local Resolve in App-Schema
[Niels Charlier] GEOS-5756 GetPropertyValue support for complex features and App-schema
[Niels Charlier] GEOS-5795 Update App-Schema docs for WFS 2.0 features
[...truncated 4298 lines...]
[INFO] [GitCommitIdMojo] build.build.time = 06.05.2013 @ 12:24:55 UTC
[INFO] [GitCommitIdMojo] build.branch = 71c3c981481f47f9dac46a5ff25940ebcc545af6
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Niels Charlier
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 71c3c98
[INFO] [GitCommitIdMojo] build.commit.id = 71c3c981481f47f9dac46a5ff25940ebcc545af6
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5795 Update App-Schema docs for WFS 2.0 features
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ wcs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ wcs ---
[INFO] Copying 11 resources
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ wcs ---
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5795 Update App-Schema docs for WFS 2.0 features
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 06.05.2013 @ 11:08:39 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 06-May-2013 12:22
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wcs ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wcs ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT.pom
[INFO] Copying 10 resources
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wcs/target/wcs-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs/2.4-SNAPSHOT/wcs-2.4-SNAPSHOT-sources.jar
[INFO]
[INFO] Building Core UI Module 2.4-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Core UI Module:
[WARNING] org.apache.maven.plugins:maven-antrun-plugin:1.3
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ wfs ---
[INFO] Compiling 241 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/classes>
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ web-core ---
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/target>
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ web-core ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-core ---
[INFO] [GitCommitIdMojo] build.build.time = 06.05.2013 @ 12:24:57 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ web-core ---
[debug] execute contextualize
[INFO] Copying 8 resources
[INFO] Copying 371 resources
[INFO]
[INFO] --- maven-antrun-plugin:1.3:run (process-resources) @ web-core ---
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ web-core ---
[INFO] Compiling 222 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/request/GetFeatureRequest.java>:\[269,26\] getResolve() is already defined in org.geoserver.wfs.request.GetFeatureRequest.WFS20
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/src/main/java/org/geoserver/wfs/request/GetFeatureRequest.java>:\[274,20\] getResolveTimeOut() is already defined in org.geoserver.wfs.request.GetFeatureRequest.WFS20
[INFO] 2 errors
[INFO]
[INFO] Skipping REST Support Module
[INFO]
[INFO] Skipping Validation Module
[INFO]
[INFO] Skipping Feature Generalization Extension
[INFO]
[INFO] Skipping OWS request flow controller
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ web-core ---
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ web-core ---
[INFO] Compiling 55 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/target/test-classes>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.763s]
[INFO] Core Platform Module .............................. SUCCESS [5.211s]
[INFO] Open Web Service Module ........................... SUCCESS [13.016s]
[INFO] Main Module ....................................... SUCCESS [1:54.314s]
[INFO] Web Feature Service Module ........................ FAILURE [10.739s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.671s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.640s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.313s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.291s]
[INFO] Application Schema Support ........................ SUCCESS [0.285s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.559s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.873s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.650s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.253s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.491s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.623s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.271s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.026s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.485s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:45.654s (Wall Clock)
[INFO] Finished at: Mon May 06 12:25:07 UTC 2013
[INFO] Final Memory: 35M/373M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project wfs: Compilation failure: Compilation failure:
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :wfs
Destroying 1 processes
Destroying process..
Destroyed 1 processes
