[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6043
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6043/&gt;
[...truncated 26884 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web-security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web-security ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-security >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-security ---
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5803, using proper name for storage parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.05.2013 @ 15:57:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 07:27
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 07:40:08 UTC
[INFO] [GitCommitIdMojo] build.branch = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = eb78a0b
[INFO] [GitCommitIdMojo] build.commit.id = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5803, using proper name for storage parameter
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-security ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building REST Configuration Service Module 2.4-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in REST Configuration Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ restconfig ---
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ restconfig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ restconfig ---
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ restconfig ---
[debug] execute contextualize
[INFO] Copying 37 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ restconfig ---
[INFO] Compiling 71 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/classes&gt;
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ restconfig ---
[INFO] Copying 7 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ restconfig ---
[INFO] Compiling 32 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/test-classes&gt;
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ restconfig ---
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt;
T E S T S
Running org.geoserver.catalog.rest.AdminRequestTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [12.333s]
[INFO] Core Platform Module .............................. SUCCESS [10.915s]
[INFO] Open Web Service Module ........................... SUCCESS [13.578s]
[INFO] Main Module ....................................... SUCCESS [1:56.830s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:57.776s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.472s]
[INFO] Web Map Service Module ............................ SUCCESS [3:14.186s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.531s]
[INFO] Core UI Module .................................... SUCCESS [1:41.925s]
[INFO] Security UI Module ................................ SUCCESS [2:58.609s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [49.181s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [55.363s]
[INFO] Web Map Service KML output formats ................ SUCCESS [44.054s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [7.305s]
[INFO] REST Support Module ............................... SUCCESS [26.776s]
[INFO] WFS UI Module ..................................... SUCCESS [25.410s]
[INFO] Community Space ................................... SUCCESS [0.325s]
[INFO] Printing Module ................................... SUCCESS [21.138s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.497s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.636s]
[INFO] Application Schema Support ........................ SUCCESS [0.299s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.477s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [21.957s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.592s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.538s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.835s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.607s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.691s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.403s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.732s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [24.217s]
[INFO] Excel Output Format ............................... SUCCESS [29.428s]
[INFO] Validation Module ................................. SUCCESS [2.371s]
[INFO] Chart external graphics support ................... SUCCESS [1.176s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.058s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.041s]
[INFO] OWS request flow controller ....................... SUCCESS [14.852s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.346s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:59.084s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [29.648s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.992s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.513s]
[INFO] BUILD FAILURE
[INFO] Total time: 13:07.513s (Wall Clock)
[INFO] Finished at: Fri May 10 07:40:16 UTC 2013
[INFO] Final Memory: 45M/174M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gwc: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gwc
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6044/changes&gt;
Changes:
[Matt Bertrand] Enclose code for disposing source and deleting directory inside finally block
[...truncated 26057 lines...]
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-gmaps/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 83.4 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-kml/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-kml/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-kml/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 116.5 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-rest/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-rest/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-rest/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 61.4 KB/sec)
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-tms/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-tms/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-tms/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 97.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-ve/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-ve/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-ve/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 232.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-wms/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-wms/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wms/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 194.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-wmts/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-wmts/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wmts/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 72.9 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-jdbc/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-jdbc/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-jdbc/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 65.3 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-diskquota/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 195.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://repository.codehaus.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml
Downloading: http://download.oracle.com/maven/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 90.4 KB/sec)
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ gwc ---
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gwc ---
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #231 from cga-harvard/dsfr_fix1
[INFO] [GitCommitIdMojo] build.commit.time = 10.05.2013 @ 13:35:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 14:51
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 15:04:23 UTC
[INFO] [GitCommitIdMojo] build.branch = 374dcdceeb6fefb26ea72f57d2624de1646530ab
[INFO] [GitCommitIdMojo] build.commit.user.name = Justin Deoliveira
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 374dcdc
[INFO] [GitCommitIdMojo] build.commit.id = 374dcdceeb6fefb26ea72f57d2624de1646530ab
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #231 from cga-harvard/dsfr_fix1
DataStoreFileResource: enclose cleanup code in a finally block
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ gwc ---
[Fatal Error] :1:1: Premature end of file.
Exception in thread "Thread-232" java.lang.RuntimeException: java.io.IOException: org.xml.sax.SAXParseException: Premature end of file.
  at org.geoserver.security.file.UserGroupFileWatcher.doOnChange(UserGroupFileWatcher.java:59)
  at org.geoserver.security.file.FileWatcher.checkAndConfigure(FileWatcher.java:104)
  at org.geoserver.security.file.FileWatcher.run(FileWatcher.java:126)
Caused by: java.io.IOException: org.xml.sax.SAXParseException: Premature end of file.
  at org.geoserver.security.xml.XMLUserGroupService.deserialize(XMLUserGroupService.java:149)
  at org.geoserver.security.impl.AbstractUserGroupService.load(AbstractUserGroupService.java:152)
  at org.geoserver.security.concurrent.LockingUserGroupService.load(LockingUserGroupService.java:95)
  at org.geoserver.security.file.UserGroupFileWatcher.doOnChange(UserGroupFileWatcher.java:57)
  ... 2 more
Caused by: org.xml.sax.SAXParseException: Premature end of file.
  at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:249)
  at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:284)
  at javax.xml.parsers.DocumentBuilder.parse(DocumentBuilder.java:124)
  at org.geoserver.security.xml.XMLUserGroupService.deserialize(XMLUserGroupService.java:147)
  ... 5 more
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gwc ---
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/classes&gt;
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.629 sec
Running org.geoserver.security.web.user.UserListPageTest
[INFO] 1 warning
[INFO] 1 error
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.501s]
[INFO] Core Platform Module .............................. SUCCESS [5.151s]
[INFO] Open Web Service Module ........................... SUCCESS [16.011s]
[INFO] Main Module ....................................... SUCCESS [1:52.675s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:57.142s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.947s]
[INFO] Web Map Service Module ............................ SUCCESS [3:22.283s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.727s]
[INFO] Core UI Module .................................... SUCCESS [1:28.026s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.249s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.147s]
[INFO] Web Map Service KML output formats ................ SUCCESS [44.100s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [7.167s]
[INFO] REST Support Module ............................... SUCCESS [24.381s]
[INFO] WFS UI Module ..................................... SUCCESS [19.192s]
[INFO] Community Space ................................... SUCCESS [0.342s]
[INFO] Printing Module ................................... SUCCESS [19.963s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.301s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.286s]
[INFO] Application Schema Support ........................ SUCCESS [0.317s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.993s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.320s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.798s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.791s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.517s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.648s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.625s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.462s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.717s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [24.959s]
[INFO] Excel Output Format ............................... SUCCESS [29.745s]
[INFO] Validation Module ................................. SUCCESS [4.379s]
[INFO] Chart external graphics support ................... SUCCESS [1.572s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.712s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.094s]
[INFO] OWS request flow controller ....................... SUCCESS [14.158s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.378s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:58.596s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.751s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.383s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.651s]
[INFO] Total time: 12:35.589s (Wall Clock)
[INFO] Finished at: Fri May 10 15:04:31 UTC 2013
[INFO] Final Memory: 45M/220M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.709 sec
Running org.geoserver.security.web.usergroup.XMLUserGroupConfigDetailsPanelTest
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6045/changes&gt;
Changes:
[jdeolive] utility script to list info about pull requests
[jdeolive] support for connection pooling ooptions in config file
[jdeolive] factored out script reading and execution into util class, and added optional (ignore failure) statements
[...truncated 25855 lines...]
10 May 19:03:47 INFO [tester.BaseWicketTester] - debugging ----------------------------------------------
10 May 19:03:47 INFO [tester.BaseWicketTester] - path faviconLink org.apache.wicket.markup.html.link.ExternalLink [resources/org.geoserver.web.GeoServerBasePage/favicon.ico]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path pageTitle org.apache.wicket.markup.html.basic.Label [GeoServer: Edit user]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path loginform org.apache.wicket.markup.html.WebMarkupContainer
10 May 19:03:47 INFO [tester.BaseWicketTester] - path logoutform org.apache.wicket.markup.html.WebMarkupContainer
10 May 19:03:47 INFO [tester.BaseWicketTester] - path logoutform:username org.apache.wicket.markup.html.basic.Label [admin]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path home org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path home:label org.apache.wicket.markup.html.basic.Label [GeoServer 2.3]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons org.geoserver.web.DeveloperToolbar
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:clearCache org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:reload org.apache.wicket.extensions.ajax.markup.html.IndicatingAjaxLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:wicketPaths org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:xhtml org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [null]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:wicketIds org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [true]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path devButtons:ajaxDebug org.apache.wicket.ajax.markup.html.form.AjaxCheckBox [false]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com, org.geoserver.web.Category@anonymised.com]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.header org.apache.wicket.markup.html.basic.Label [About &amp; Status]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Server Status]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [GeoServer Logs]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Contact Information]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [About GeoServer]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:0:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.header org.apache.wicket.markup.html.basic.Label [Data]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Workspaces]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Stores]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Layers]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Layer Groups]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:1:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.header org.apache.wicket.markup.html.basic.Label [Settings]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Global]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [JAI]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Coverage Access]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:2:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.Category@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.header org.apache.wicket.markup.html.basic.Label [Security]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links org.apache.wicket.markup.html.list.ListView [[org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com, org.geoserver.web.MenuPageInfo@anonymised.com]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:0 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.label org.apache.wicket.markup.html.basic.Label [Settings]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:0:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:1 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.label org.apache.wicket.markup.html.basic.Label [Authentication]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:1:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:2 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.label org.apache.wicket.markup.html.basic.Label [Passwords]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:2:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:3 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.label org.apache.wicket.markup.html.basic.Label [Users, Groups, Roles]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:3:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:4 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.label org.apache.wicket.markup.html.basic.Label [Data]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:4:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:5 org.apache.wicket.markup.html.list.ListItem [org.geoserver.web.MenuPageInfo@anonymised.com]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link org.apache.wicket.markup.html.link.BookmarkablePageLink
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.label org.apache.wicket.markup.html.basic.Label [Services]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path category:3:category.links:5:link:link.icon org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path standalone org.apache.wicket.markup.html.list.ListView []
10 May 19:03:47 INFO [tester.BaseWicketTester] - path feedback org.apache.wicket.markup.html.panel.FeedbackPanel
10 May 19:03:47 INFO [tester.BaseWicketTester] - path feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
10 May 19:03:47 INFO [tester.BaseWicketTester] - path feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
10 May 19:03:47 INFO [tester.BaseWicketTester] - path ajaxFeedbackImage org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path headerPanel org.apache.wicket.markup.html.WebMarkupContainer
10 May 19:03:47 INFO [tester.BaseWicketTester] - path gbpTitle org.apache.wicket.markup.html.basic.Label [Edit user]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path gbpDescription org.apache.wicket.markup.html.basic.Label [You can update the password, enable/disable the user or change user roles and user groups]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path dialog org.geoserver.web.wicket.GeoServerDialog
10 May 19:03:47 INFO [tester.BaseWicketTester] - path dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
10 May 19:03:47 INFO [tester.BaseWicketTester] - path dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form org.apache.wicket.markup.html.form.Form [Username: user1; Password: [PROTECTED]; Enabled: true; AccountNonExpired: true; CredentialsNonExpired: true; AccountNonLocked: true; [ ] ]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:username org.apache.wicket.markup.html.form.TextField [user1]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:enabled org.apache.wicket.markup.html.form.CheckBox [true]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:password org.apache.wicket.markup.html.form.PasswordTextField [digest1:cDLO5hL6s2vL4i+0olCW52lXyFUEXyytshN6ObgT/+jcWMgCTSs9YwCfqU5WJohZ]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:confirmPassword org.apache.wicket.markup.html.form.PasswordTextField [digest1:cDLO5hL6s2vL4i+0olCW52lXyFUEXyytshN6ObgT/+jcWMgCTSs9YwCfqU5WJohZ]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:properties org.geoserver.web.wicket.property.PropertyEditorFormComponent [{}]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:properties:container org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: container]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:properties:container:list org.apache.wicket.markup.html.list.ListView []
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:properties:add org.apache.wicket.ajax.markup.html.AjaxLink [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: add]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups org.geoserver.security.web.user.UserGroupPaletteFormComponent
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette org.apache.wicket.extensions.markup.html.form.palette.Palette [[Groupname: group1 Enabled: true]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:recorder org.apache.wicket.extensions.markup.html.form.palette.component.Recorder [group1]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:choices org.apache.wicket.extensions.markup.html.form.palette.component.Choices [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: choices]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:selection org.apache.wicket.extensions.markup.html.form.palette.component.Selection [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: selection]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:addButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: addButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:addButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:removeButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: removeButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:removeButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:moveUpButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: moveUpButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:moveUpButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:moveDownButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: moveDownButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:moveDownButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:availableHeader org.apache.wicket.markup.html.basic.Label [Available Groups]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:palette:selectedHeader org.apache.wicket.markup.html.basic.Label [Selected Groups]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:groups:addGroup org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: addGroup]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles org.geoserver.security.web.role.RolePaletteFormComponent
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette org.apache.wicket.extensions.markup.html.form.palette.Palette [[ROLE_WFS, ROLE_WMS]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:recorder org.apache.wicket.extensions.markup.html.form.palette.component.Recorder [ROLE_WFS,ROLE_WMS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:choices org.apache.wicket.extensions.markup.html.form.palette.component.Choices [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: choices]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:selection org.apache.wicket.extensions.markup.html.form.palette.component.Selection [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: selection]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:addButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: addButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:addButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:removeButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: removeButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:removeButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:moveUpButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: moveUpButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:moveUpButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:moveDownButton org.apache.wicket.extensions.markup.html.form.palette.Palette$PaletteButton [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: moveDownButton]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:moveDownButton:image org.apache.wicket.markup.html.image.Image
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:availableHeader org.apache.wicket.markup.html.basic.Label [Available Roles]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:palette:selectedHeader org.apache.wicket.markup.html.basic.Label [Selected Roles]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:roles org.apache.wicket.markup.html.basic.Label [Roles taken from active role service: test]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:roles:addRole org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: addRole]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:adminGroups org.geoserver.security.web.user.UserGroupListMultipleChoice []
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer org.apache.wicket.markup.html.WebMarkupContainer [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: calculatedRolesContainer]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles org.apache.wicket.markup.html.list.ListView [[ROLE_AUTHENTICATED, ROLE_WFS, ROLE_WMS]]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:0 org.apache.wicket.markup.html.list.ListItem [ROLE_AUTHENTICATED]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:0:role org.geoserver.web.wicket.SimpleAjaxLink [ROLE_AUTHENTICATED]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:0:role:link org.apache.wicket.ajax.markup.html.AjaxLink [ROLE_AUTHENTICATED]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:0:role:link:label org.apache.wicket.markup.html.basic.Label [ROLE_AUTHENTICATED]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:1 org.apache.wicket.markup.html.list.ListItem [ROLE_WFS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:1:role org.geoserver.web.wicket.SimpleAjaxLink [ROLE_WFS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:1:role:link org.apache.wicket.ajax.markup.html.AjaxLink [ROLE_WFS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:1:role:link:label org.apache.wicket.markup.html.basic.Label [ROLE_WFS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2 org.apache.wicket.markup.html.list.ListItem [ROLE_WMS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role org.geoserver.web.wicket.SimpleAjaxLink [ROLE_WMS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role:link org.apache.wicket.ajax.markup.html.AjaxLink [ROLE_WMS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:calculatedRolesContainer:calculatedRoles:2:role:link:label org.apache.wicket.markup.html.basic.Label [ROLE_WMS]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:save org.apache.wicket.markup.html.form.SubmitLink [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: save]
10 May 19:03:47 INFO [tester.BaseWicketTester] - path form:cancel org.apache.wicket.markup.html.link.Link [No get method defined for class: class org.geoserver.security.xml.XMLGeoserverUser expression: cancel]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.323s]
[INFO] Core Platform Module .............................. SUCCESS [4.296s]
[INFO] Open Web Service Module ........................... SUCCESS [12.062s]
[INFO] Main Module ....................................... SUCCESS [1:45.883s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:56.388s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.668s]
[INFO] Web Map Service Module ............................ SUCCESS [3:32.581s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.661s]
[INFO] Core UI Module .................................... SUCCESS [1:24.861s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.639s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [52.217s]
[INFO] Web Map Service KML output formats ................ SUCCESS [42.863s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [7.179s]
[INFO] REST Support Module ............................... SUCCESS [21.383s]
[INFO] WFS UI Module ..................................... SUCCESS [21.060s]
[INFO] Community Space ................................... SUCCESS [0.326s]
[INFO] Printing Module ................................... SUCCESS [22.938s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.861s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.629s]
[INFO] Application Schema Support ........................ SUCCESS [0.300s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.929s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.075s]
[INFO] H2 DataStore Extension ............................ SUCCESS [10.812s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.376s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.830s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.814s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.649s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.938s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.770s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.413s]
[INFO] Excel Output Format ............................... SUCCESS [29.247s]
[INFO] Validation Module ................................. SUCCESS [3.111s]
[INFO] Chart external graphics support ................... SUCCESS [1.394s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.729s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.909s]
[INFO] OWS request flow controller ....................... SUCCESS [15.001s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.311s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:59.447s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.326s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.356s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [1.738s]
[INFO] Total time: 12:26.084s (Wall Clock)
[INFO] Finished at: Fri May 10 19:03:48 UTC 2013
[INFO] Final Memory: 45M/206M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6046/&gt;
[...truncated 25985 lines...]
  at org.geoserver.security.web.user.NewUserPage.onFormSubmit(NewUserPage.java:36)
  at org.geoserver.security.web.user.AbstractUserPage$6.onSubmit(AbstractUserPage.java:194)
  at org.apache.wicket.markup.html.form.Form.delegateSubmit(Form.java:1561)
  at org.apache.wicket.markup.html.form.Form.process(Form.java:958)
  at org.apache.wicket.markup.html.form.Form.onFormSubmitted(Form.java:920)
  at sun.reflect.GeneratedMethodAccessor161.invoke(Unknown Source)
  at org.apache.wicket.RequestListenerInterface.invoke(RequestListenerInterface.java:182)
  at org.apache.wicket.request.target.component.listener.ListenerInterfaceRequestTarget.processEvents(ListenerInterfaceRequestTarget.java:73)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.processEvents(AbstractRequestCycleProcessor.java:92)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1250)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1329)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1436)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:545)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:527)
  at org.apache.wicket.util.tester.FormTester.submit(FormTester.java:695)
  at org.apache.wicket.util.tester.FormTester.submit(FormTester.java:742)
  at org.geoserver.security.web.user.NewUserPageTest.testUserNameConflict(NewUserPageTest.java:218)
Caused by: org.geoserver.security.validation.UserGroupServiceException: User user1 already exists
  at org.geoserver.security.validation.UserGroupServiceValidationWrapper.createSecurityException(UserGroupServiceValidationWrapper.java:282)
  ... 55 more
2/2 KB
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-jdbc/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 69.2 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 167.3 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 42.0 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO] [GitCommitIdMojo] build.commit.time = 10.05.2013 @ 18:08:17 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2013 08:19
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 08:31:45 UTC
[INFO] [GitCommitIdMojo] build.branch = 5bbbd1f3ac589d29e6d1714e71ac7b0d5a222b0a
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5bbbd1f
[INFO] [GitCommitIdMojo] build.commit.id = 5bbbd1f3ac589d29e6d1714e71ac7b0d5a222b0a
[INFO] [GitCommitIdMojo] build.commit.message.full = factored out script reading and execution into util class, and added optional (ignore failure) statements
[INFO]
[INFO]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.217 sec
[INFO] 1 warning
[INFO] 1 error
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.462s]
[INFO] Core Platform Module .............................. SUCCESS [5.144s]
[INFO] Open Web Service Module ........................... SUCCESS [13.765s]
[INFO] Main Module ....................................... SUCCESS [1:51.378s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:00.034s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.238s]
[INFO] Web Map Service Module ............................ SUCCESS [3:13.501s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.988s]
[INFO] Core UI Module .................................... SUCCESS [1:32.855s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [49.801s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [55.922s]
[INFO] Web Map Service KML output formats ................ SUCCESS [40.850s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [8.283s]
[INFO] REST Support Module ............................... SUCCESS [20.478s]
[INFO] WFS UI Module ..................................... SUCCESS [23.817s]
[INFO] Community Space ................................... SUCCESS [0.313s]
[INFO] Printing Module ................................... SUCCESS [19.419s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.659s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.296s]
[INFO] Application Schema Support ........................ SUCCESS [0.331s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [32.276s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.637s]
[INFO] H2 DataStore Extension ............................ SUCCESS [12.334s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.930s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.824s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.896s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.578s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.778s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.535s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [24.331s]
[INFO] Excel Output Format ............................... SUCCESS [26.359s]
[INFO] Validation Module ................................. SUCCESS [4.327s]
[INFO] Chart external graphics support ................... SUCCESS [1.288s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.284s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.163s]
[INFO] OWS request flow controller ....................... SUCCESS [14.023s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.373s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:56.083s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.745s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.325s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.410s]
[INFO] Total time: 12:37.973s (Wall Clock)
[INFO] Finished at: Sun May 12 08:31:54 UTC 2013
[INFO] Final Memory: 45M/219M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6047/changes&gt;
Changes:
[Andrea Aime] [GEOS-4014] servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3, section 9.7.2.
[...truncated 26109 lines...]
  ... 55 more
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-tms/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 105.9 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-ve/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 97.0 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wms/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 105.9 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wmts/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 29.9 KB/sec)
Exception in thread "Thread-230" java.lang.RuntimeException: java.io.IOException: org.xml.sax.SAXParseException: Premature end of file.
  ... 2 more
  ... 5 more
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-jdbc/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 7.8 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 46.8 KB/sec)
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 39.2 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #227 from aaime/servlet-exclude
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2013 @ 14:33:32 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2013 14:34
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 14:47:49 UTC
[INFO] [GitCommitIdMojo] build.branch = 50edd98c7f4b01769a28418c9860b47aca4998ca
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 50edd98
[INFO] [GitCommitIdMojo] build.commit.id = 50edd98c7f4b01769a28418c9860b47aca4998ca
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #227 from aaime/servlet-exclude
[GEOS-4014] servlet-api-2.4.jar) - jar not loaded. See Servlet Spec 2.3,...
[INFO]
[debug] execute contextualize
[INFO]
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.745 sec
[INFO] -------------------------------------------------------------
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java&gt;:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java&gt;:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[INFO]
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoSearch Index Module
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.769 sec
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.456s]
[INFO] Core Platform Module .............................. SUCCESS [4.732s]
[INFO] Open Web Service Module ........................... SUCCESS [17.640s]
[INFO] Main Module ....................................... SUCCESS [2:07.871s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:00.311s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.310s]
[INFO] Web Map Service Module ............................ SUCCESS [3:28.009s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.789s]
[INFO] Core UI Module .................................... SUCCESS [1:38.662s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [48.402s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [55.290s]
[INFO] Web Map Service KML output formats ................ SUCCESS [46.256s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [10.516s]
[INFO] REST Support Module ............................... SUCCESS [27.411s]
[INFO] WFS UI Module ..................................... SUCCESS [24.016s]
[INFO] Community Space ................................... SUCCESS [0.386s]
[INFO] Printing Module ................................... SUCCESS [21.683s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.841s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.546s]
[INFO] Application Schema Support ........................ SUCCESS [1.989s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.508s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.592s]
[INFO] H2 DataStore Extension ............................ SUCCESS [12.728s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.674s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.474s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.573s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.798s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.438s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.724s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.650s]
[INFO] Excel Output Format ............................... SUCCESS [28.171s]
[INFO] Validation Module ................................. SUCCESS [2.662s]
[INFO] Chart external graphics support ................... SUCCESS [2.373s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.150s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.912s]
[INFO] OWS request flow controller ....................... SUCCESS [14.788s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.331s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:51.923s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [33.043s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [8.294s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.374s]
[INFO] Total time: 13:14.697s (Wall Clock)
[INFO] Finished at: Sun May 12 14:48:00 UTC 2013
[INFO] Final Memory: 44M/195M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6048/changes&gt;
Changes:
[nuno] Remove obsolete KML response format.
[nuno] Extended styles to support the inclusion of 3D models. W3DS X3D format response improved to suport the inclusion of inline X3D models based on styles.
[nuno] 3D styles extended to support transform operations on 3D models.
[nuno] Add KML responde format for W3DS service. Currently only POINT features are supported.
[Martin Sucha] Remove hacks for comments in WMS capabilities.
[Christian Mueller] GEOS-5811 Changing the SSL Port has no effect for
[...truncated 27045 lines...]
[INFO] [GitCommitIdMojo] build.commit.time = 12.05.2013 @ 15:04:43 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-May-2013 15:52
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 16:04:55 UTC
[INFO] [GitCommitIdMojo] build.branch = e1c449c47ea23d644d5dd9621ec7b053e255b14a
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e1c449c
[INFO] [GitCommitIdMojo] build.commit.id = e1c449c47ea23d644d5dd9621ec7b053e255b14a
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #233 from martin-sucha/fix-comments-hack
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ restconfig ---
2/2 KB
[INFO] Copying 37 resources
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wms/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 129.4 KB/sec)
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ restconfig ---
[INFO] Compiling 71 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/classes&gt;
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-wmts/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 83.3 KB/sec)
2/2 KB
2/2 KB
2/2 KB
Downloaded: http://repo.opengeo.org/org/geowebcache/gwc-diskquota-core/1.4-SNAPSHOT/maven-metadata.xml (2 KB at 58.8 KB/sec)
[INFO]
[INFO]
[INFO]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #233 from martin-sucha/fix-comments-hack
[INFO] [GitCommitIdMojo] build.build.time = 12.05.2013 @ 16:04:56 UTC
[INFO]
[INFO]
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ restconfig ---
[INFO] Copying 7 resources
[INFO] Copying 1 resource
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ restconfig ---
[INFO] Compiling 32 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/test-classes&gt;
[INFO] 1 warning
[INFO] 1 error
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ restconfig ---
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/surefire-reports&gt;
T E S T S
Running org.geoserver.catalog.rest.AdminRequestTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.515s]
[INFO] Core Platform Module .............................. SUCCESS [4.614s]
[INFO] Open Web Service Module ........................... SUCCESS [11.665s]
[INFO] Main Module ....................................... SUCCESS [1:43.720s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:42.662s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.456s]
[INFO] Web Map Service Module ............................ SUCCESS [3:05.900s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.359s]
[INFO] Core UI Module .................................... SUCCESS [1:29.969s]
[INFO] Security UI Module ................................ SUCCESS [3:11.021s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [49.496s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [55.511s]
[INFO] Web Map Service KML output formats ................ SUCCESS [42.834s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [8.569s]
[INFO] REST Support Module ............................... SUCCESS [26.583s]
[INFO] WFS UI Module ..................................... SUCCESS [28.029s]
[INFO] Community Space ................................... SUCCESS [0.197s]
[INFO] Printing Module ................................... SUCCESS [21.105s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.001s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.172s]
[INFO] Application Schema Support ........................ SUCCESS [0.179s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [30.069s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [19.302s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.233s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.443s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.685s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.368s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.420s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.479s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.499s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.849s]
[INFO] Excel Output Format ............................... SUCCESS [26.300s]
[INFO] Validation Module ................................. SUCCESS [4.380s]
[INFO] Chart external graphics support ................... SUCCESS [0.981s]
[INFO] Feature Generalization Extension .................. SUCCESS [5.706s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.750s]
[INFO] OWS request flow controller ....................... SUCCESS [16.461s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.198s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:10.343s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [30.499s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.765s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.434s]
[INFO] BUILD FAILURE
[INFO] Total time: 12:39.851s (Wall Clock)
[INFO] Finished at: Sun May 12 16:05:06 UTC 2013
[INFO] Final Memory: 48M/252M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-compiler-plugin:2.3.2:compile (default-compile) on project gwc: Compilation failure
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :gwc
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6049/&gt;
[...truncated 26862 lines...]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:5:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default2]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default2]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default2]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:6:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLUserGroupServiceConfig@anonymised.com]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML user/group service]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [Digest]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:items:7:itemProperties:3:component org.apache.wicket.markup.html.basic.Label [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[passwordEncoderName], BeanProperty[passwordPolicyName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordEncoderName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[passwordEncoderName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:2:header:link:label org.apache.wicket.markup.html.basic.Label [Password Encryption]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3 org.apache.wicket.markup.html.list.ListItem [BeanProperty[passwordPolicyName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[passwordPolicyName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:listContainer:sortableLinks:3:header:link:label org.apache.wicket.markup.html.basic.Label [Password Policy]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback org.apache.wicket.markup.html.panel.FeedbackPanel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog org.geoserver.web.wicket.GeoServerDialog
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServices:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:userGroupServicesHelp org.geoserver.web.wicket.HelpLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices org.geoserver.security.web.role.RoleServicesPanel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:add org.apache.wicket.ajax.markup.html.AjaxLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:remove org.apache.wicket.ajax.markup.html.AjaxLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table org.geoserver.security.web.SecurityNamedServicesPanel$SecurityNamedServiceTablePanel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm org.apache.wicket.markup.html.form.Form
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:filter org.apache.wicket.markup.html.form.TextField
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:submit org.apache.wicket.ajax.markup.html.form.AjaxButton
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop org.apache.wicket.markup.html.panel.Panel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:filterForm:navigatorTop:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items org.apache.wicket.markup.repeater.data.DataView
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLRoleServiceConfig@anonymised.com]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [default]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML role service]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:5:itemProperties:2:component org.apache.wicket.markup.html.basic.Label [ADMIN]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6 org.apache.wicket.markup.repeater.OddEvenItem [org.geoserver.security.xml.XMLRoleServiceConfig@anonymised.com]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:selectItemContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:selectItemContainer:selectItem org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component org.geoserver.web.wicket.SimpleAjaxLink [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component:link org.apache.wicket.ajax.markup.html.AjaxLink [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:0:component:link:label org.apache.wicket.markup.html.basic.Label [test]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:1:component org.apache.wicket.markup.html.basic.Label [Default XML role service]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:items:6:itemProperties:2:component org.apache.wicket.markup.html.basic.Label
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:selectAllContainer org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:selectAllContainer:selectAll org.apache.wicket.markup.html.form.CheckBox [false]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks org.apache.wicket.markup.html.list.ListView [[BeanProperty[name], Property[type], BeanProperty[adminRoleName]]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0 org.apache.wicket.markup.html.list.ListItem [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[name]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:0:header:link:label org.apache.wicket.markup.html.basic.Label [Name]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1 org.apache.wicket.markup.html.list.ListItem [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header:link org.apache.wicket.ajax.markup.html.AjaxLink [Property[type]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:1:header:link:label org.apache.wicket.markup.html.basic.Label [Type]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2 org.apache.wicket.markup.html.list.ListItem [BeanProperty[adminRoleName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header org.apache.wicket.markup.html.panel.Fragment
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header:link org.apache.wicket.ajax.markup.html.AjaxLink [BeanProperty[adminRoleName]]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:listContainer:sortableLinks:2:header:link:label org.apache.wicket.markup.html.basic.Label [Administrator Role]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom org.apache.wicket.markup.html.panel.Panel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator org.geoserver.web.wicket.GeoServerPagingNavigator
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigation [1]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0 org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0:pageLink org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:navigation:0:pageLink:pageNumber org.apache.wicket.markup.html.basic.Label [1]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:first org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:prev org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:next org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationIncrementLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:navigator:last org.apache.wicket.ajax.markup.html.navigation.paging.AjaxPagingNavigationLink
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:table:navigatorBottom:filterMatch org.apache.wicket.markup.html.basic.Label [Results 1 to 2 (out of 2 items)]
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback org.apache.wicket.markup.html.panel.FeedbackPanel
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback:feedbackul org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:feedback:feedbackul:messages org.apache.wicket.markup.html.list.ListView []
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog org.geoserver.web.wicket.GeoServerDialog
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog:dialog org.apache.wicket.extensions.ajax.markup.html.modal.ModalWindow
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServices:dialog:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
12 May 18:46:19 INFO [tester.BaseWicketTester] - path panel:panel:roleServicesHelp org.geoserver.web.wicket.HelpLink
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.854 sec
Results :
Tests run: 92, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ web-security ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ web-security ---
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.514s]
[INFO] Core Platform Module .............................. SUCCESS [5.471s]
[INFO] Open Web Service Module ........................... SUCCESS [11.944s]
[INFO] Main Module ....................................... SUCCESS [1:45.631s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:54.046s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.529s]
[INFO] Web Map Service Module ............................ SUCCESS [3:14.693s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.382s]
[INFO] Core UI Module .................................... SUCCESS [1:29.279s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.486s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [52.701s]
[INFO] Web Map Service KML output formats ................ SUCCESS [45.543s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [9.765s]
[INFO] REST Support Module ............................... SUCCESS [19.486s]
[INFO] WFS UI Module ..................................... SUCCESS [20.868s]
[INFO] Community Space ................................... SUCCESS [0.202s]
[INFO] Printing Module ................................... SUCCESS [21.014s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.338s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.166s]
[INFO] Application Schema Support ........................ SUCCESS [0.191s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.068s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.034s]
[INFO] H2 DataStore Extension ............................ SUCCESS [12.213s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.826s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.700s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.378s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.493s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.202s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.516s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.101s]
[INFO] Excel Output Format ............................... SUCCESS [29.133s]
[INFO] Validation Module ................................. SUCCESS [3.415s]
[INFO] Chart external graphics support ................... SUCCESS [1.346s]
[INFO] Feature Generalization Extension .................. SUCCESS [4.687s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.859s]
[INFO] OWS request flow controller ....................... SUCCESS [15.049s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.215s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:55.558s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [31.275s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.558s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.491s]
[INFO] Total time: 12:25.852s (Wall Clock)
[INFO] Finished at: Sun May 12 18:46:20 UTC 2013
[INFO] Final Memory: 48M/253M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-tests.jar&gt;
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6050/changes&gt;
Changes:
[RiniAngreani] GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[...truncated 27144 lines...]
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ gwc ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ gwc ---
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[INFO] [GitCommitIdMojo] build.commit.time = 13.05.2013 @ 05:43:33 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-May-2013 06:53
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 07:05:44 UTC
[INFO] [GitCommitIdMojo] build.branch = 08f60336f8e5ef7cbbc52ad959a868afcaf4086f
[INFO] [GitCommitIdMojo] build.commit.user.email = rini.angreani@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = RiniAngreani
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 08f6033
[INFO] [GitCommitIdMojo] build.commit.id = 08f60336f8e5ef7cbbc52ad959a868afcaf4086f
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5618: Remove references to getID() as they break feature chaining with joining.
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ gwc ---
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ gwc ---
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/gwc/target/classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/web-security-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.4-SNAPSHOT/web-security-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building REST Configuration Service Module 2.4-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in REST Configuration Service Module:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
[INFO]
[INFO] --- maven-clean-plugin:2.4.1:clean (default-clean) @ restconfig ---
[INFO] Deleting <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target&gt;
[INFO]
[INFO] --- cobertura-maven-plugin:2.3:clean (default) @ restconfig ---
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ restconfig ---
[INFO] [GitCommitIdMojo] build.build.time = 13.05.2013 @ 07:05:45 UTC
[INFO]
[INFO]
[INFO] 1 warning
[INFO] 1 error
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
[INFO]
T E S T S
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.546s]
[INFO] Core Platform Module .............................. SUCCESS [4.631s]
[INFO] Open Web Service Module ........................... SUCCESS [12.502s]
[INFO] Main Module ....................................... SUCCESS [1:47.542s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:53.934s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.277s]
[INFO] Web Map Service Module ............................ SUCCESS [3:17.395s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.692s]
[INFO] Core UI Module .................................... SUCCESS [1:23.636s]
[INFO] Security UI Module ................................ SUCCESS [3:01.762s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [45.937s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [53.073s]
[INFO] Web Map Service KML output formats ................ SUCCESS [48.326s]
[INFO] GeoWebCache (GWC) Module .......................... FAILURE [8.654s]
[INFO] REST Support Module ............................... SUCCESS [21.922s]
[INFO] WFS UI Module ..................................... SUCCESS [22.766s]
[INFO] Community Space ................................... SUCCESS [0.285s]
[INFO] Printing Module ................................... SUCCESS [18.442s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.917s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.330s]
[INFO] Application Schema Support ........................ SUCCESS [0.387s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.145s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.689s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.497s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.597s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.904s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.616s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.104s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.613s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.828s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.679s]
[INFO] Excel Output Format ............................... SUCCESS [33.345s]
[INFO] Validation Module ................................. SUCCESS [3.113s]
[INFO] Chart external graphics support ................... SUCCESS [1.357s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.223s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.656s]
[INFO] OWS request flow controller ....................... SUCCESS [16.598s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.323s]
[INFO] Web Processing Service Module ..................... SUCCESS [2:59.012s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [29.619s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.942s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.433s]
[INFO] Total time: 12:37.634s (Wall Clock)
[INFO] Finished at: Mon May 13 07:05:53 UTC 2013
[INFO] Final Memory: 45M/211M
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6051/changes&gt;
