[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6067
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6067/changes&gt;
Changes:
[David Winslow] Add raster properties in CSS module
[...truncated 10575 lines...]
Thread[Thread-19,5,main] calling requestComplete
Thread[Thread-19,5,main] done
sleep interrupted
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.411 sec
Thread[Thread-20,5,main] calling requestComplete
Thread[Thread-20,5,main] done
Thread[Thread-21,5,main] calling requestIncoming
Thread[Thread-21,5,main] waiting
Thread[Thread-21,5,main] calling requestComplete
Thread[Thread-21,5,main] done
Thread[Thread-22,5,main] calling requestIncoming
Thread[Thread-22,5,main] waiting
Thread[Thread-23,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-22,5,main] calling requestComplete
Thread[Thread-22,5,main] done
Thread[Thread-23,5,main] waiting
Results :
Tests run: 464, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ wfs ---
sleep interrupted
Thread[Thread-23,5,main] calling requestComplete
Thread[Thread-23,5,main] done
Thread[Thread-24,5,main] calling requestIncoming
Thread[Thread-24,5,main] waiting
Thread[Thread-24,5,main] calling requestComplete
Thread[Thread-24,5,main] done
Thread[Thread-25,5,main] calling requestIncoming
Thread[Thread-25,5,main] waiting
Thread[Thread-26,5,main] calling requestIncoming
sleep interrupted
Thread[Thread-25,5,main] calling requestComplete
Thread[Thread-25,5,main] done
Thread[Thread-26,5,main] waiting
sleep interrupted
Thread[Thread-26,5,main] calling requestComplete
Thread[Thread-26,5,main] done
Thread[Thread-27,5,main] calling requestIncoming
Thread[Thread-27,5,main] waiting
Thread[Thread-28,5,main] calling requestIncoming
Thread[Thread-28,5,main] waiting
sleep interrupted
Thread[Thread-27,5,main] calling requestComplete
Thread[Thread-27,5,main] done
sleep interrupted
Thread[Thread-28,5,main] calling requestComplete
Thread[Thread-28,5,main] done
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.323 sec
Results :
Failed tests: testUserAndIPAddressFlowControl(org.geoserver.flow.controller.IpFlowControllerTest): expected:<PROCESSING> but was:<STARTED>
Tests run: 19, Failures: 1, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
[INFO]
[INFO] Skipping Printing Module
[INFO]
[INFO] Skipping ArcSDE DataStore Extension
[INFO]
[INFO] Skipping H2 DataStore Extension
[INFO]
[INFO] Skipping Teradata DataStore Extension
[INFO]
[INFO] Skipping HTTP Proxy Extension
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT.jar&gt;
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ wfs ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-tests.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ wfs >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ wfs ---
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Add raster properties in CSS module
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.05.2013 @ 16:49:23 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-May-2013 18:09
[INFO] [GitCommitIdMojo] build.build.time = 19.05.2013 @ 18:14:21 UTC
[INFO] [GitCommitIdMojo] build.branch = d5346297d409811c029cc94c0d4e0d195062bf10
[INFO] [GitCommitIdMojo] build.commit.user.email = cdwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d534629
[INFO] [GitCommitIdMojo] build.commit.id = d5346297d409811c029cc94c0d4e0d195062bf10
[INFO] [GitCommitIdMojo] build.commit.message.full = Add raster properties in CSS module
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ wfs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ wfs ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-sources.jar&gt;
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ wfs >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 19.05.2013 @ 18:14:24 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wfs <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wfs ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wfs ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wfs/target/wfs-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/wfs/2.4-SNAPSHOT/wfs-2.4-SNAPSHOT-test-sources.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.992s]
[INFO] Core Platform Module .............................. SUCCESS [4.689s]
[INFO] Open Web Service Module ........................... SUCCESS [12.437s]
[INFO] Main Module ....................................... SUCCESS [1:51.156s]
[INFO] Web Feature Service Module ........................ SUCCESS [2:44.603s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.416s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.719s]
[INFO] Core UI Module .................................... SUCCESS [1:37.684s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SUCCESS [27.194s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.333s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.276s]
[INFO] Application Schema Support ........................ SUCCESS [0.279s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.528s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.817s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.653s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.158s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.580s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.657s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [3.977s]
[INFO] Chart external graphics support ................... SUCCESS [1.270s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.197s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.384s]
[INFO] OWS request flow controller ....................... FAILURE [25.069s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.325s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5:02.558s (Wall Clock)
[INFO] Finished at: Sun May 19 18:14:24 UTC 2013
[INFO] Final Memory: 34M/300M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project control-flow: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/control-flow/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :control-flow
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6068/changes&gt;
