See <http://hudson.opengeo.org/hudson/job/geoserver-master/6100/changes>
Changes:
[Andrea Aime] Refactoring superoverlay code generation, adding more tests
[Andrea Aime] KML 2 superoverlay refactor and tests
[...truncated 707 lines...]
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-surefire-report-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1373, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-jxr-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1381, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:taglist-maven-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1389, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:cobertura-maven-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1403, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.extension:inspire:jar:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-resources-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1126, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-source-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1253, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ org.geoserver:extension:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/pom.xml,> line 32, column 10
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-site-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1307, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-javadoc-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1312, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-project-info-reports-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/pom.xml,> line 1368, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:extension:pom:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 32, column 10
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:geoserver:pom:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-resources-plugin is missing. @ line 1126, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-source-plugin is missing. @ line 1253, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 1225, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-site-plugin is missing. @ line 1307, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-javadoc-plugin is missing. @ line 1312, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-project-info-reports-plugin is missing. @ line 1368, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-surefire-report-plugin is missing. @ line 1373, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-jxr-plugin is missing. @ line 1381, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:taglist-maven-plugin is missing. @ line 1389, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:cobertura-maven-plugin is missing. @ line 1403, column 12
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Map Service KML output formats
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] Building with 2 threads
[INFO]
[INFO] Building GeoServer 2.4-SNAPSHOT
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
686/686 B
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml (686 B at 0.9 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
588/588 B
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml (588 B at 47.9 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
692/692 B
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml (692 B at 39.8 KB/sec)
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in GeoServer:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://repo.opengeo.org/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
974/974 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml (974 B at 2.4 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/library/10-SNAPSHOT/maven-metadata.xml
592/592 B
Downloaded: http://repo.opengeo.org/org/geotools/library/10-SNAPSHOT/maven-metadata.xml (592 B at 9.6 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml
592/592 B
Downloaded: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml (592 B at 22.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/modules-10-20130612.055210-79.pom
Downloading: http://repo.opengeo.org/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
2/2 KB
Downloaded: http://repo.opengeo.org/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml (2 KB at 64.3 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [3.698s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 8.428s (Wall Clock)
[INFO] Finished at: Wed Jun 12 19:36:52 UTC 2013
[INFO] Final Memory: 19M/149M
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.4-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.1.RELEASE (compile), org.springframework:spring-core:jar:3.1.1.RELEASE (compile), org.springframework:spring-context:jar:3.1.1.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.1.RELEASE (compile), org.geotools:gt-api:jar:10-SNAPSHOT (compile), org.geotools:gt-main:jar:10-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:10-SNAPSHOT: Could not find artifact org.geotools:modules:pom:10-20130612.055210-79 in opengeo (http://repo.opengeo.org/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
