See <http://hudson.opengeo.org/hudson/job/geoserver-master/6121/>
[...truncated 4309 lines...]
testModify(org.geoserver.security.xml.XMLUserGroupServiceTest) Time elapsed: 19 sec <<< ERROR!
java.io.IOException: Already locked
location: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/default71998425452260958data/security/usergroup/test/users.xml.lock>
hostname: gridlock
principal: UNKNOWN
ip: UNKNOWN
at org.geoserver.security.file.LockFile.writeLock(LockFile.java:106)
at org.geoserver.security.xml.XMLUserGroupStore.ensureLock(XMLUserGroupStore.java:201)
at org.geoserver.security.xml.XMLUserGroupStore.clear(XMLUserGroupStore.java:279)
at org.geoserver.security.concurrent.LockingUserGroupStore.clear(LockingUserGroupStore.java:181)
at org.geoserver.security.xml.XMLUserGroupServiceTest.clearUserGroupService(XMLUserGroupServiceTest.java:45)
at org.junit.internal.runners.statements.RunBefores.evaluate(RunBefores.java:24)
testRemove(org.geoserver.security.xml.XMLUserGroupServiceTest) Time elapsed: 2 sec <<< ERROR!
hostname: gridlock
principal: UNKNOWN
ip: UNKNOWN
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.137 sec
Running org.geoserver.template.GeoServerTemplateLoader2Test
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.threadlocals.AdminRequestThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.033 sec
Running org.geoserver.threadlocals.AuthenticationThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.threadlocals.LocalLayerThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.threadlocals.LocalWorkspaceThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Running org.geoserver.threadlocals.PublicThreadLocalTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.threadlocals.ThreadLocalsTransferTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.594 sec
Running org.geoserver.util.PartialBufferOutputStream2Test
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0 sec
Running org.geoserver.util.XCQLTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.274 sec
Running org.geoserver.vfny.global.TolerantStartupTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.688 sec
Running org.vfny.geoserver.ProjectionPolicyTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.931 sec
Running org.vfny.geoserver.crs.OverrideCRSTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.759 sec
Running org.vfny.geoserver.crs.OvverideTransformationsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.982 sec
Running org.vfny.geoserver.global.xml.WriterHelperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.vfny.geoserver.util.ResponseUtilsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Results :
Failed tests: testIsModified(org.geoserver.security.xml.XMLUserGroupServiceTest)
Tests in error:
testPasswordRecoding(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
testEraseCredentials(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
testEmptyPassword(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
testInsert(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
testModify(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
testRemove(org.geoserver.security.xml.XMLUserGroupServiceTest): Already locked(..)
Tests run: 536, Failures: 1, Errors: 6, Skipped: 1
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [13.531s]
[INFO] Core Platform Module .............................. SUCCESS [6.356s]
[INFO] Open Web Service Module ........................... SUCCESS [14.574s]
[INFO] Main Module ....................................... FAILURE [2:11.863s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.453s]
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.278s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.172s]
[INFO] Application Schema Support ........................ SUCCESS [0.355s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.021s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.277s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.488s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.419s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.293s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.547s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [1.070s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.139s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.204s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:50.554s (Wall Clock)
[INFO] Finished at: Sat Jun 22 11:31:23 UTC 2013
[INFO] Final Memory: 30M/357M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project main: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/main/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :main
