See <http://hudson.opengeo.org/hudson/job/geoserver-master/6126/changes>
Changes:
[Mauro Bartolomeoli] GEOS-5847 fixed issue with nested layergroups
[...truncated 36643 lines...]
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
at org.geoserver.test.GeoServerSystemTestSupport.getAsJSON(GeoServerSystemTestSupport.java:1189)
at org.geoserver.service.rest.LocalWFSSettingsTest.testDelete(LocalWFSSettingsTest.java:138)
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.926 sec
Running org.geoserver.service.rest.LocalWMSSettingsTest
24 Jun 07:52:48 ERROR [geoserver.rest] - Service for workspace sf does not exist
org.geoserver.rest.RestletException
at org.geoserver.service.rest.ServiceSettingsResource.handleObjectGet(ServiceSettingsResource.java:83)
at org.geoserver.rest.ReflectiveResource.handleGet(ReflectiveResource.java:88)
at org.restlet.Finder.handle(Finder.java:292)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at org.geoserver.service.rest.LocalWMSSettingsTest.testDelete(LocalWMSSettingsTest.java:144)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.678 sec
Running org.geoserver.service.rest.WCSSettingsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.418 sec
Running org.geoserver.service.rest.WFSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.716 sec
Running org.geoserver.service.rest.WMSSettingsTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.84 sec
Results :
Failed tests: testPostAsXML(org.geoserver.catalog.rest.CoverageTest): expected:<201> but was:<500>
testPostAsXML(org.geoserver.catalog.rest.FeatureTypeTest): expected:<201> but was:<500>
testPostAsJSON(org.geoserver.catalog.rest.FeatureTypeTest): expected:<201> but was:<500>
Tests in error:
testFeatureTypeConcurrency(org.geoserver.catalog.rest.RestConcurrencyTest): java.lang.AssertionError: expected:<201> but was:<500>
Tests run: 285, Failures: 3, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping GeoSearch Index Module
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
[INFO]
[INFO] Skipping GWC UI Module
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 18.146 sec
Running org.geoserver.web.demo.MapPreviewPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.448s]
[INFO] Core Platform Module .............................. SUCCESS [6.038s]
[INFO] Open Web Service Module ........................... SUCCESS [23.530s]
[INFO] Main Module ....................................... SUCCESS [2:03.294s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:29.588s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.331s]
[INFO] Web Map Service Module ............................ SUCCESS [3:56.433s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.537s]
[INFO] Core UI Module .................................... SUCCESS [1:54.281s]
[INFO] Security UI Module ................................ SUCCESS [3:07.303s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [53.585s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [56.967s]
[INFO] Web Map Service KML output formats ................ SUCCESS [46.403s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:19.145s]
[INFO] REST Support Module ............................... SUCCESS [28.228s]
[INFO] REST Configuration Service Module ................. FAILURE [2:04.198s]
[INFO] WMS UI Module ..................................... SUCCESS [45.338s]
[INFO] WFS UI Module ..................................... SUCCESS [22.845s]
[INFO] Community Space ................................... SUCCESS [0.233s]
[INFO] Printing Module ................................... SUCCESS [24.204s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.887s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.171s]
[INFO] Application Schema Support ........................ SUCCESS [0.189s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.660s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [22.507s]
[INFO] H2 DataStore Extension ............................ SUCCESS [14.312s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.888s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.507s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.760s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.565s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [5.412s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.754s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [26.562s]
[INFO] Excel Output Format ............................... SUCCESS [28.894s]
[INFO] Validation Module ................................. SUCCESS [5.884s]
[INFO] Chart external graphics support ................... SUCCESS [2.660s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.557s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.779s]
[INFO] OWS request flow controller ....................... SUCCESS [16.805s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.179s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:23.349s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.024s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.403s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.429s]
[INFO] BUILD FAILURE
[INFO] Total time: 16:38.746s (Wall Clock)
[INFO] Finished at: Mon Jun 24 07:52:58 UTC 2013
[INFO] Final Memory: 45M/176M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project restconfig: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/restconfig/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :restconfig
