[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6130
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6130/changes&gt;
Changes:
[Ben Caradoc-Davies] Updated test axis order and added srsName check for [GEOT-4471] App-schema: filtering by xlink:href causes ClassCastException if the type has native CRS
[...truncated 41321 lines...]
Caused by: java.lang.IllegalArgumentException: Could not find working property accessor for attribute (DOESNT_EXIST) in object (SimpleFeatureImpl:MappedFeatureNoId=[SimpleFeatureImpl.Attribute: LOC_ACC<LOC_ACC id=1>=200.0, SimpleFeatureImpl.Attribute: SHAPE<SHAPE id=1>=POINT (-23.6701 133.8855), SimpleFeatureImpl.Attribute: ID<ID id=1>=mf1, SimpleFeatureImpl.Attribute: GEOLOGIC_UNIT_ID<GEOLOGIC_UNIT_ID id=1>=gu.25699])
  at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:268)
  at org.geotools.filter.AttributeExpressionImpl.evaluate(AttributeExpressionImpl.java:231)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.getValues(DataAccessMappingFeatureIterator.java:456)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:521)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:1008)
  ... 66 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.678 sec
Running org.geoserver.test.Reprojection3DTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.643 sec
Running org.geoserver.test.RestconfigWfsTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.787 sec
Running org.geoserver.test.SRSReprojectionTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.227 sec
Running org.geoserver.test.SRSWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.131 sec
Running org.geoserver.test.SameNameDiffNamespaceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 20.012 sec
Running org.geoserver.security.jdbc.H2JNDIUserDetailsServiceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.246 sec
Running org.geoserver.test.SecondaryNamespaceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.598 sec
Running org.geoserver.test.SecuredFeatureChainingTest
25 Jun 09:59:59 ERROR [security.decorators] - Complex store returned more properties than allowed by security (because they are required by the schema). Either the security setup is broken or you have a security breach
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.415 sec
Running org.geoserver.test.SimpleAttributeFeatureChainWfsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.917 sec
Running org.geoserver.test.SpecimenWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.466 sec
Running org.geoserver.test.SubstitutionGroupTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 12.008 sec
Running org.geoserver.security.jdbc.H2JNDIUserGroupServiceTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.592 sec
Running org.geoserver.test.TimeSeriesInlineWfsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.821 sec
Running org.geoserver.test.TimeSeriesWfsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.031 sec
Running org.geoserver.test.ValidationTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.733 sec
Running org.geoserver.test.WaterMLTimeSeriesWfsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.19 sec
Running org.geoserver.security.jdbc.H2RoleServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.51 sec
Running org.geoserver.test.WmsGetFeatureInfoTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.86 sec
Running org.geoserver.security.jdbc.H2UserDetailsServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.723 sec
Running org.geoserver.test.WmsGetLegendGraphicTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.012 sec
Running org.geoserver.test.WmsGetMapTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.946 sec
Running org.geoserver.security.jdbc.H2UserGroupServiceTest
25 Jun 10:00:27 ERROR [image.test] - perceptualdiff is not available, can't compare <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/test-classes/test-data/img/outcrop.tiff&gt; with image2
25 Jun 10:00:27 ERROR [image.test] - perceptualdiff is not available, can't compare <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/test-classes/test-data/img/posacc.tiff&gt; with image2
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.794 sec
Running org.geoserver.test.XYGeomTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.979 sec
Running org.geoserver.security.jdbc.JDBCConnectAuthProviderTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.243 sec
Running org.geoserver.test.XlinkGeometryTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.78 sec
Running org.geoserver.test.XlinkWfsTest
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 1.541 sec <<< FAILURE!
testGetFeatureContent(org.geoserver.test.XlinkWfsTest) Time elapsed: 57 sec <<< FAILURE!
org.junit.ComparisonFailure: expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
  at org.junit.Assert.assertEquals(Assert.java:115)
  at org.junit.Assert.assertEquals(Assert.java:144)
  at org.geoserver.test.AbstractAppSchemaTestSupport.assertXpathEvaluatesTo(AbstractAppSchemaTestSupport.java:344)
  at org.geoserver.test.XlinkWfsTest.testGetFeatureContent(XlinkWfsTest.java:73)
Results :
Failed tests: testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest): expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
  testEncodeFeatureMember(org.geoserver.test.FeatureChainingWfsTest): expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
  testEncodeFeatureMembers(org.geoserver.test.FeatureChainingWfsTest): expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
  testGetFeatureContent(org.geoserver.test.IdFunctionWfsTest): expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
  testGetFeatureContent(org.geoserver.test.XlinkWfsTest): expected:<[urn:x-ogc:def:crs:EPSG:4326]> but was:<>
Tests run: 138, Failures: 5, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.794 sec
Running org.geoserver.security.jdbc.JDBCGroupAdminServiceTest
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.161 sec
Running org.geoserver.security.jdbc.JdbcSecurityConfigValidatorTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.291s]
[INFO] Core Platform Module .............................. SUCCESS [6.207s]
[INFO] Open Web Service Module ........................... SUCCESS [19.016s]
[INFO] Main Module ....................................... SUCCESS [2:14.672s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:08.471s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.608s]
[INFO] Web Map Service Module ............................ SUCCESS [3:31.735s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.439s]
[INFO] Core UI Module .................................... SUCCESS [1:40.109s]
[INFO] Security UI Module ................................ SUCCESS [3:03.692s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.553s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [51.140s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:01.988s]
[INFO] Web Map Service KML output formats ................ SUCCESS [48.614s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [1:19.545s]
[INFO] REST Support Module ............................... SUCCESS [30.988s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:15.101s]
[INFO] WMS UI Module ..................................... SUCCESS [41.048s]
[INFO] GWC UI Module ..................................... SUCCESS [56.455s]
[INFO] WFS UI Module ..................................... SUCCESS [27.728s]
[INFO] Demoes Module ..................................... SUCCESS [40.456s]
[INFO] WCS UI Module ..................................... SUCCESS [28.779s]
[INFO] Community Space ................................... SUCCESS [0.185s]
[INFO] Printing Module ................................... SUCCESS [24.449s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.829s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.153s]
[INFO] Application Schema Support ........................ SUCCESS [0.209s]
[INFO] Application Schema Integration Test ............... FAILURE [3:34.516s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.402s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [32.732s]
[INFO] GeoSearch Index Module ............................ SUCCESS [33.010s]
[INFO] H2 DataStore Extension ............................ SUCCESS [16.998s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.409s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.274s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.505s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.410s]
[INFO] ImageMap Output Format ............................ SUCCESS [14.722s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.240s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.596s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [28.578s]
[INFO] Excel Output Format ............................... SUCCESS [29.233s]
[INFO] Validation Module ................................. SUCCESS [2.208s]
[INFO] Chart external graphics support ................... SUCCESS [1.037s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.141s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.711s]
[INFO] OWS request flow controller ....................... SUCCESS [17.354s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.175s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:05.966s]
[INFO] Web Processing Service GUI ........................ SUCCESS [32.670s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [33.694s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.521s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.374s]
[INFO] Core Monitor Extension ............................ SUCCESS [26.335s]
[INFO] Monitor Hibernate Extension ....................... SUCCESS [16.267s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.409s]
[INFO] XLST based WFS output format ...................... SUCCESS [44.357s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [34.555s]
[INFO] BUILD FAILURE
[INFO] Total time: 21:11.634s (Wall Clock)
[INFO] Finished at: Tue Jun 25 10:00:37 UTC 2013
[INFO] Final Memory: 54M/146M
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.786 sec
Running org.geoserver.security.jdbc.MySqlRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0 sec
Running org.geoserver.security.jdbc.MySqlUserDetailsServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 3, Time elapsed: 0 sec
Running org.geoserver.security.jdbc.MySqlUserGroupServiceTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 8, Time elapsed: 0 sec
Running org.geoserver.security.jdbc.OracleRoleServiceTest
Running org.geoserver.security.jdbc.OracleUserDetailsServiceTest
Running org.geoserver.security.jdbc.OracleUserGroupServiceTest
Running org.geoserver.security.jdbc.PostGisRoleServiceTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 5, Time elapsed: 0.001 sec
Running org.geoserver.security.jdbc.PostGisUserDetailsServiceTest
Running org.geoserver.security.jdbc.PostGisUserGroupServiceTest
Running org.geoserver.security.jdbc.SqlServerRoleServiceTest
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project app-schema-test: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :app-schema-test
Running org.geoserver.security.jdbc.SqlServerUserDetailsServiceTest
Running org.geoserver.security.jdbc.SqlServerUserGroupServiceTest
Running org.geoserver.security.web.jdbc.JDBCConnectionPanelTest
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6131/&gt;
