See <http://hudson.opengeo.org/hudson/job/geoserver-master/6227/changes>
Changes:
[jdeolive] Added geopackage community module
[...truncated 20095 lines...]
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getRendering(RenderedOp.java:888)
at javax.media.jai.RenderedOp$1.getPropertyNames(RenderedOp.java:1791)
at javax.media.jai.PropertyEnvironment.mapDefaults(PropertyEnvironment.java:270)
at javax.media.jai.PropertyEnvironment.getPropertyNames(PropertyEnvironment.java:125)
at javax.media.jai.WritablePropertySourceImpl.addProperties(WritablePropertySourceImpl.java:298)
at javax.media.jai.RenderedOp.createPropertySource(RenderedOp.java:1817)
at javax.media.jai.RenderedOp.setProperty(RenderedOp.java:2034)
at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:717)
at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:258)
at org.vfny.geoserver.util.WCSUtils.resample(WCSUtils.java:132)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:550)
at org.geoserver.wps.executor.SimpleInputProvider.handleAsInternalWCS(SimpleInputProvider.java:242)
at org.geoserver.wps.executor.SimpleInputProvider.getValue(SimpleInputProvider.java:123)
at org.geoserver.wps.executor.LazyInputMap.get(LazyInputMap.java:35)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.buildProcessArguments(AnnotationDrivenProcessFactory.java:630)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:515)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:227)
at org.geoserver.wps.executor.DefaultProcessManager$ProcessCallable.call(DefaultProcessManager.java:194)
at java.util.concurrent.FutureTask$Sync.innerRun(FutureTask.java:303)
at java.util.concurrent.FutureTask.run(FutureTask.java:138)
at java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Caused by: java.lang.ClassNotFoundException: com.sun.medialib.mlib.Image
at java.net.URLClassLoader$1.run(URLClassLoader.java:202)
at java.security.AccessController.doPrivileged(Native Method)
at java.net.URLClassLoader.findClass(URLClassLoader.java:190)
at java.lang.ClassLoader.loadClass(ClassLoader.java:307)
at sun.misc.Launcher$AppClassLoader.loadClass(Launcher.java:301)
at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
... 40 more
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Added geopackage community module
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 07.08.2013 @ 14:01:49 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 07-Aug-2013 14:37
[INFO] [GitCommitIdMojo] build.build.time = 07.08.2013 @ 15:02:44 UTC
[INFO] [GitCommitIdMojo] build.branch = 03c7ed13fa948553ef6c97ee0ccb454eb4e1a492
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 03c7ed1
[INFO] [GitCommitIdMojo] build.commit.id = 03c7ed13fa948553ef6c97ee0ccb454eb4e1a492
[INFO] [GitCommitIdMojo] build.commit.message.full = Added geopackage community module
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ web-security ---
[debug] execute contextualize
07 Aug 15:02:45 ERROR [geoserver.wps] - Process execution failed
org.geotools.process.ProcessException: coverageA and coverageB should share the same Envelope
at org.geotools.process.raster.BaseCoverageAlgebraProcess.checkCompatibleCoverages(BaseCoverageAlgebraProcess.java:79)
at org.geotools.process.raster.AddCoveragesProcess.execute(AddCoveragesProcess.java:55)
at org.geotools.process.factory.AnnotationDrivenProcessFactory$InvokeMethodProcess.execute(AnnotationDrivenProcessFactory.java:520)
[INFO] Copying 7 resources
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 114.461 sec
Running org.geoserver.wps.gs.BufferFeatureCollectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.181 sec
Running org.geoserver.wps.gs.ClipProcessTest
<?xml version="1.0" encoding="UTF-8"?><wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs" xmlns:feature="http://www.openplans.org/topp" xmlns:ogc="http://www.opengis.net/ogc" xmlns:gml="http://www.opengis.net/gml"><gml:boundedBy><gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326"><gml:coord><gml:X>\-91\.516129</gml:X><gml:Y>36\.986771000000005</gml:Y></gml:coord><gml:coord><gml:X>\-87\.507889</gml:X><gml:Y>42\.50936100000001</gml:Y></gml:coord></gml:Box></gml:boundedBy><gml:featureMember><feature:states fid="states.1"><gml:boundedBy><gml:Box srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326"><gml:coord><gml:X>\-91\.516129</gml:X><gml:Y>40\.0</gml:Y></gml:coord><gml:coord><gml:X>\-90\.0</gml:X><gml:Y>42\.50936100000001</gml:Y></gml:coord></gml:Box></gml:boundedBy><feature:the\_geom><gml:MultiPolygon srsName="http://www.opengis.net/gml/srs/epsg\.xml\#4326"><gml:polygonMember><gml:Polygon><gml:outerBoundaryIs><gml:LinearRing><gml:coordinates>\-91\.48342924966074,40\.0 -91.487289,40.005753 -91.504005,40.066711 -91.516129,40.134544000000005 -91.506546,40.200458999999995 -91.498932,40.25137699999999 -91.486694,40.309624000000014 -91.448593,40.371902000000006 -91.418816,40.386875 -91.385757,40.392360999999994 -91.372757,40.40298799999999 -91.385399,40.44725 -91.374794,40.50365400000001 -91.382103,40.52849599999999 -91.412872,40.54799299999999 -91.411118,40.572970999999995 -91.37561,40.60343900000001 -91.262062,40.639545 -91.214912,40.64381800000001 -91.162498,40.65631099999999 -91.129158,40.68214800000001 -91.119987,40.70540199999999 -91.092751,40.76154700000001 -91.088905,40.833729000000005 -91.04921,40.87958499999999 -90.983276,40.92392699999999 -90.960709,40.950503999999995 -90.954651,41.07036199999999 -90.957787,41.10435899999999 -90.990341,41.14437100000001 -91.018257,41.16582500000001 -91.05632,41.17625799999999 -91.101524,41.23152200000001 -91.102348,41.267818000000005 -91.07328,41.334895999999986 -91.055786,41.40137899999999 -91.027489,41.423508 -91.000694,41.431084 -90.949654,41.421234 -90.844139,41.44462200000001 -90.7799,41.449820999999986 -90.708214,41.450062 -90.658791,41.46231800000001 -90.6007,41.50958600000001 -90.54084,41.52597 -90.454994,41.527546 -90.434967,41.543578999999994 -90.423004,41.567272 -90.348366,41.586849 -90.339348,41.60279800000001 -90.341133,41.64909 -90.326027,41.722736 -90.304886,41.75646599999999 -90.25531,41.78173799999999 -90.195839,41.80613700000001 -90.154518,41.93077500000001 -90.14267,41.98396299999999 -90.150536,42.03342799999999 -90.168098,42.06104300000001 -90.166649,42.103745 -90.176086,42.12050199999999 -90.191574,42.12268800000001 -90.230934,42.15972099999999 -90.323601,42.19731899999999 -90.367729,42.21020899999999 -90.407173,42.24264500000001 -90.417984,42.263924 -90.427681,42.340633 -90.441597,42.360073 -90.491043,42.38878299999999 -90.563583,42.42183700000001 -90.605827,42.46055999999999 -90.648346,42.47564299999999 -90.651772,42.494698 -90.638329,42.50936100000001 -90.419975,42.508362000000005 -90.0,42.50476298296556 -90.0,40.0 -91.48342924966074,40.0</gml:coordinates></gml:LinearRing></gml:outerBoundaryIs></gml:Polygon></gml:polygonMember></gml:MultiPolygon></feature:the_geom><feature:STATE_NAME>Illinois</feature:STATE_NAME><feature:STATE_FIPS>17</feature:STATE_FIPS><feature:SUB_REGION>E N Cen</feature:SUB_REGION><feature:STATE_ABBR>IL</feature:STATE_ABBR><feature:LAND_KM>143986.61</feature:LAND_KM><feature:WATER_KM>1993.335</feature:WATER_KM><feature:PERSONS>1.1430602E7</feature:PERSONS><feature:FAMILIES>2924880.0</feature:FAMILIES><feature:HOUSHOLD>4202240.0</feature:HOUSHOLD><feature:MALE>5552233.0</feature:MALE><feature:FEMALE>5878369.0</feature:FEMALE><feature:WORKERS>4199206.0</feature:WORKERS><feature:DRVALONE>3741715.0</feature:DRVALONE><feature:CARPOOL>652603.0</feature:CARPOOL><feature:PUBTRANS>538071.0</feature:PUBTRANS><feature:EMPLOYED>5417967.0</feature:EMPLOYED><feature:UNEMPLOY>385040.0</feature:UNEMPLOY><feature:SERVICE>1360159.0</feature:SERVICE><feature:MANUAL>828906.0</feature:MANUAL><feature:P_MALE>0.486</feature:P_MALE><feature:P_FEMALE>0.514</feature:P_FEMALE><feature:SAMP_POP>1747776.0</feature:SAMP_POP></feature:states></gml:featureMember></wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.594 sec
Running org.geoserver.wps.gs.CollectGeometriesTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.399 sec
Running org.geoserver.wps.gs.ContourProcessTest
[INFO] Copying 86 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ web-security ---
[INFO] Compiling 138 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/classes>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 121.451 sec
Running org.geoserver.wps.gs.CountProcessTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.336 sec
Running org.geoserver.wps.gs.Coverage2RenderedImageAdapterTest
Point2D.Double[0.0, 250.0]
Point2D.Double[10.0, 265.0]
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.27 sec
Running org.geoserver.wps.gs.CropCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.347 sec
Running org.geoserver.wps.gs.GeorectifyCoverageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.832 sec
Running org.geoserver.wps.gs.ImportProcessTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.943 sec
Running org.geoserver.wps.gs.InclusionFeatureCollectionTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.198 sec
Running org.geoserver.wps.gs.PolygonExtractionProcessTest
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ web-security ---
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.273 sec
Running org.geoserver.wps.gs.QueryProcessTest
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ web-security ---
[INFO] Compiling 43 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/test-classes>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.145 sec
Running org.geoserver.wps.gs.RangeLookupTest
Killed
Results :
Tests run: 107, Failures: 0, Errors: 0, Skipped: 0
[INFO]
[INFO] Skipping KML support for GeoServer
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ web-security ---
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/security/target/surefire-reports>
T E S T S
Running org.geoserver.security.web.SecuritySettingsPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [9.914s]
[INFO] Core Platform Module .............................. SUCCESS [9.292s]
[INFO] Open Web Service Module ........................... SUCCESS [32.281s]
[INFO] Main Module ....................................... SUCCESS [2:54.261s]
[INFO] Web Feature Service Module ........................ SUCCESS [4:18.159s]
[INFO] Web Coverage Service Module ....................... SUCCESS [6.736s]
[INFO] Web Map Service Module ............................ SUCCESS [11:31.755s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.887s]
[INFO] Core UI Module .................................... SUCCESS [2:19.517s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:29.343s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2:03.682s]
[INFO] REST Support Module ............................... SUCCESS [39.668s]
[INFO] WFS UI Module ..................................... SUCCESS [36.815s]
[INFO] Community Space ................................... SUCCESS [3.235s]
[INFO] Printing Module ................................... SUCCESS [1:00.630s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [10.614s]
[INFO] GeoServer Extensions .............................. SUCCESS [5.919s]
[INFO] Application Schema Support ........................ SUCCESS [0.584s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [37.342s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [46.852s]
[INFO] H2 DataStore Extension ............................ SUCCESS [29.812s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [9.527s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.174s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.569s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.569s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.971s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.836s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [36.506s]
[INFO] Excel Output Format ............................... SUCCESS [50.123s]
[INFO] Validation Module ................................. SUCCESS [3.062s]
[INFO] Chart external graphics support ................... SUCCESS [2.430s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.008s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.328s]
[INFO] OWS request flow controller ....................... SUCCESS [25.477s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.407s]
[INFO] Web Processing Service Module ..................... FAILURE [13:06.506s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [53.275s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [5.293s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [9.216s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [41.863s]
[INFO] BUILD FAILURE
[INFO] Total time: 28:11.114s (Wall Clock)
[INFO] Finished at: Wed Aug 07 15:05:47 UTC 2013
[INFO] Final Memory: 45M/202M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project wps-core: Execution default-test of goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test failed: The forked VM terminated without saying properly goodbye. VM crash or System.exit called ? -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/PluginExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :wps-core
