[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6235
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6235/changes&gt;
Changes:
[Andrea Aime] [GEOS-5966] Switch GetFeatureInfo minimum search area to 5 pixels
[Andrea Aime] [GEOS-5943] KML wfs output format does not properly set the output file name
[Andrea Aime] Give kml wfs output a display name for the preview pane
[Andrea Aime] [GEOS-5953] Trying to change the style of a layer in a group wil have (visually) no effect
[...truncated 7678 lines...]
10 Aug 15:45:13 INFO [tester.BaseWicketTester] - path form:panel:dialog:content org.apache.wicket.markup.html.WebMarkupContainer
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.967 sec
Running org.geoserver.web.wicket.property.PropertyEditorFormComponentTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.256 sec
Results :
Tests in error:
  testComputeBounds(org.geoserver.web.data.layergroup.LayerGroupEditPageTest): path: 'form:generateBounds' does not exist for page: GeoServerErrorPage
Tests run: 139, Failures: 0, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping REST Support Module
[INFO]
[INFO] Skipping Validation Module
[INFO]
[INFO] Skipping Feature Generalization Extension
[INFO]
[INFO] Skipping OWS request flow controller
[INFO]
[INFO] Skipping Web Coverage Service 1.0 Module
[INFO]
[INFO] Skipping Web Coverage Service 1.1 Module
10 Aug 15:45:16 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type cdf:Fifteen unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.checkTypeName(GetFeatureKvpRequestReader.java:389)
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:146)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
  at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
  at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
  at org.geoserver.test.GeoServerSystemTestSupport.get(GeoServerSystemTestSupport.java:902)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
  at org.geoserver.wfs.v1_1.GetFeatureTest.testLayerQualified(GetFeatureTest.java:424)
10 Aug 15:45:17 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:new unknown
  at org.geoserver.wfs.v1_1.GetFeatureTest.testAfterFeatureTypeAdded(GetFeatureTest.java:389)
Tests run: 26, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.441 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.017s]
[INFO] Core Platform Module .............................. SUCCESS [6.110s]
[INFO] Open Web Service Module ........................... SUCCESS [32.363s]
[INFO] Main Module ....................................... SUCCESS [2:52.867s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SUCCESS [5.755s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.529s]
[INFO] Core UI Module .................................... FAILURE [2:49.363s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.253s]
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Extensions .............................. SUCCESS [0.183s]
[INFO] Application Schema Support ........................ SUCCESS [0.203s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.442s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.774s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.689s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.419s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [14.336s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [2.312s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SUCCESS [2.682s]
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.288s]
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SUCCESS [0.718s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 6:42.673s (Wall Clock)
[INFO] Finished at: Sat Aug 10 15:45:20 UTC 2013
[INFO] Final Memory: 32M/336M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project web-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/web/core/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :web-core
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6236/changes&gt;
