[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6237
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6237/changes&gt;
Changes:
[Andrea Aime] [GEOS-5955] Reosurce error handling drop down choice is not internationalized
[...truncated 26299 lines...]
testGetCapabilities(org.geoserver.kml.KMLWFSTest) Time elapsed: 17 sec <<< ERROR!
org.xml.sax.SAXParseException: Premature end of file.
  at com.sun.org.apache.xerces.internal.parsers.DOMParser.parse(DOMParser.java:249)
  at com.sun.org.apache.xerces.internal.jaxp.DocumentBuilderImpl.parse(DocumentBuilderImpl.java:284)
  at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1355)
  at org.geoserver.test.GeoServerSystemTestSupport.dom(GeoServerSystemTestSupport.java:1336)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1228)
  at org.geoserver.test.GeoServerSystemTestSupport.getAsDOM(GeoServerSystemTestSupport.java:1163)
  at org.geoserver.kml.KMLWFSTest.testGetCapabilities(KMLWFSTest.java:26)
testGetFeatureKMLAlias(org.geoserver.kml.KMLWFSTest) Time elapsed: 18 sec <<< ERROR!
  at org.geoserver.kml.KMLWFSTest.testGetFeatureKMLAlias(KMLWFSTest.java:48)
Running org.geoserver.kml.icons.IconPropertiesTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.292 sec
Running org.geoserver.kml.icons.IconPropertyInjectorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.013 sec
Running org.geoserver.kml.icons.IconRendererTest
11 Aug 20:52:50 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
11 Aug 20:52:51 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.707 sec
Running org.geoserver.kml.icons.IconServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.239 sec
Results :
Tests in error:
  testGetFeature(org.geoserver.kml.KMLWFSTest): java.io.EOFException
  testForceWGS84(org.geoserver.kml.KMLWFSTest): Premature end of file.
  testGetCapabilities(org.geoserver.kml.KMLWFSTest): Premature end of file.
  testGetFeatureKMLAlias(org.geoserver.kml.KMLWFSTest): Premature end of file.
Tests run: 102, Failures: 0, Errors: 4, Skipped: 3
[INFO]
[INFO] Skipping GeoWebCache (GWC) Module
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [7.397s]
[INFO] Core Platform Module .............................. SUCCESS [6.957s]
[INFO] Open Web Service Module ........................... SUCCESS [24.762s]
[INFO] Main Module ....................................... SUCCESS [2:29.710s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:24.477s]
[INFO] Web Coverage Service Module ....................... SUCCESS [5.500s]
[INFO] Web Map Service Module ............................ SUCCESS [4:06.706s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.574s]
[INFO] Core UI Module .................................... SUCCESS [1:58.149s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [55.132s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [58.890s]
[INFO] KML support for GeoServer ......................... FAILURE [54.607s]
[INFO] REST Support Module ............................... SUCCESS [31.807s]
[INFO] WFS UI Module ..................................... SUCCESS [37.315s]
[INFO] Community Space ................................... SUCCESS [0.206s]
[INFO] Printing Module ................................... SUCCESS [22.162s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [8.295s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.417s]
[INFO] Application Schema Support ........................ SUCCESS [0.443s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.651s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [26.112s]
[INFO] H2 DataStore Extension ............................ SUCCESS [18.522s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.605s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.862s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.458s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.454s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.034s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.768s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [25.114s]
[INFO] Excel Output Format ............................... SUCCESS [27.673s]
[INFO] Validation Module ................................. SUCCESS [2.797s]
[INFO] Chart external graphics support ................... SUCCESS [1.144s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.062s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.921s]
[INFO] OWS request flow controller ....................... SUCCESS [16.574s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.227s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:16.168s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [36.114s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.382s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.427s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [29.867s]
[INFO] BUILD FAILURE
[INFO] Total time: 15:17.517s (Wall Clock)
[INFO] Finished at: Sun Aug 11 20:52:56 UTC 2013
[INFO] Final Memory: 46M/188M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/target/surefire-reports&gt; for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6238/changes&gt;
