See <http://hudson.opengeo.org/hudson/job/geoserver-master/6256/changes>
Changes:
[David Winslow] GEOS-5929
[David Winslow] Rebase CSS legend support onto latest master
[...truncated 14350 lines...]
testDocsPanel(org.geoserver.community.css.web.CssDemoTest) Time elapsed: 35 sec <<< ERROR!
org.apache.wicket.WicketRuntimeException: path: 'main-content:context:tabs-container:tabs:4:link' does not exist for page: CssDemoPage
at org.apache.wicket.util.tester.BaseWicketTester.fail(BaseWicketTester.java:1523)
at org.apache.wicket.util.tester.BaseWicketTester.getComponentFromLastRenderedPage(BaseWicketTester.java:489)
at org.apache.wicket.util.tester.BaseWicketTester.clickLink(BaseWicketTester.java:721)
at org.apache.wicket.util.tester.BaseWicketTester.clickLink(BaseWicketTester.java:690)
at org.geoserver.community.css.web.CssDemoTest.testDocsPanel(CssDemoTest.java:62)
testSLDPreviewPanel(org.geoserver.community.css.web.CssDemoTest) Time elapsed: 66 sec <<< FAILURE!
junit.framework.AssertionFailedError: component 'DocsPanel' is not type:SLDPreviewPanel
at org.apache.wicket.util.tester.WicketTester.assertResult(WicketTester.java:658)
at org.apache.wicket.util.tester.WicketTester.assertComponent(WicketTester.java:369)
at org.geoserver.community.css.web.CssDemoTest.testSLDPreviewPanel(CssDemoTest.java:38)
Results :
Failed tests: testBasicLayout(org.geoserver.community.css.web.CssDemoTest): component 'SLDPreviewPanel' is not type:EmptyPanel
testSLDPreviewPanel(org.geoserver.community.css.web.CssDemoTest): component 'DocsPanel' is not type:SLDPreviewPanel
Tests in error:
testDocsPanel(org.geoserver.community.css.web.CssDemoTest): path: 'main-content:context:tabs-container:tabs:4:link' does not exist for page: CssDemoPage
Tests run: 6, Failures: 2, Errors: 1, Skipped: 0
[INFO]
[INFO] Skipping WFS UI Module
[INFO]
[INFO] Skipping Sample DataAccess Integration Test
[INFO]
[INFO] Skipping ogr2ogr Output Format
[INFO]
[INFO] Skipping Excel Output Format
[INFO]
[INFO] Skipping GeoServer Layer Querying filter functions
[INFO]
[INFO] Skipping Web Processing Service Module
[INFO]
[INFO] Skipping GeoServer Monitor Extensions
[INFO]
[INFO] --- maven-resources-plugin:2.6:testResources (default-testResources) @ wms ---
[INFO] Copying 73 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ wms ---
[INFO] Compiling 88 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/wms/target/test-classes>
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.919s]
[INFO] Core Platform Module .............................. SUCCESS [5.829s]
[INFO] Open Web Service Module ........................... SUCCESS [15.919s]
[INFO] Main Module ....................................... SUCCESS [2:08.017s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:14.337s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.214s]
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SUCCESS [0.582s]
[INFO] Core UI Module .................................... SUCCESS [1:43.848s]
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.776s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [54.570s]
[INFO] REST Support Module ............................... SUCCESS [27.377s]
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SUCCESS [0.203s]
[INFO] Printing Module ................................... SUCCESS [22.989s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.782s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.165s]
[INFO] Application Schema Support ........................ SUCCESS [0.211s]
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.547s]
[INFO] H2 DataStore Extension ............................ SUCCESS [11.432s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.124s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.744s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.447s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.562s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.216s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.520s]
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SUCCESS [4.194s]
[INFO] Chart external graphics support ................... SUCCESS [1.912s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.011s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.991s]
[INFO] OWS request flow controller ....................... SUCCESS [16.493s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.196s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.158s]
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] GeoServer CSS Styling ............................. FAILURE [21.789s]
[INFO] BUILD FAILURE
[INFO] Total time: 7:18.105s (Wall Clock)
[INFO] Finished at: Fri Aug 16 22:44:28 UTC 2013
[INFO] Final Memory: 41M/245M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project css: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/css/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :css
Destroying 1 processes
Destroying process..
Destroyed 1 processes
