See <http://hudson.opengeo.org/hudson/job/geoserver-master/6271/changes>
Changes:
[Andrea Aime] Improve logging for asynch requests
[Andrea Aime] [GEOS-5983] Add a way for styling to know what kind of KML output mode we are using
[...truncated 26814 lines...]
Running org.geoserver.kml.KMLWFSTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.267 sec
Running org.geoserver.kml.icons.IconPropertiesTest
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.325 sec
Running org.geoserver.kml.icons.IconPropertyInjectorTest
Tests run: 11, Failures: 0, Errors: 0, Skipped: 1, Time elapsed: 0.016 sec
Running org.geoserver.kml.icons.IconRendererTest
22 Aug 09:59:16 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
22 Aug 09:59:17 ERROR [image.test] - perceptualdiff is not available, can't compare target/expected.png with image2
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.182 sec
Running org.geoserver.kml.icons.IconServiceTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.383 sec
Results :
Failed tests: testOutputModeVector(org.geoserver.kml.KMLTest): expected:<[1]> but was:<[0]>
Tests in error:
testVectorWithRemoteLayer(org.geoserver.kml.KMLTest): Could not load outputMode.sld from scope class org.geoserver.kml.KMLTest.
testEncodeTime(org.geoserver.kml.KMLTest)
Tests run: 103, Failures: 1, Errors: 2, Skipped: 3
[INFO]
[INFO] Skipping REST Configuration Service Module
[INFO]
[INFO] Skipping WMS UI Module
[INFO]
[INFO] Skipping Demoes Module
[INFO]
[INFO] Skipping ImageMap Output Format
[INFO]
[INFO] Skipping GeoServer INSPIRE Extensions
[INFO]
[INFO] Skipping Core Monitor Extension
[INFO]
[INFO] Skipping Catalog Services for the Web core module
[INFO]
[INFO] Skipping GeoServer Security Modules
[INFO]
[INFO] Skipping GeoServer Security Extension Modules
22 Aug 09:59:20 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer cdf:BasicPolygons
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1252)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:218)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:80)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1412)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:622)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:263)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:923)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:852)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:882)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:778)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:707)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:820)
at org.geoserver.test.GeoServerSystemTestSupport$2.service(GeoServerSystemTestSupport.java:1431)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1450)
at org.geoserver.test.GeoServerSystemTestSupport.dispatch(GeoServerSystemTestSupport.java:1385)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:934)
at org.geoserver.test.GeoServerSystemTestSupport.getAsServletResponse(GeoServerSystemTestSupport.java:917)
at org.geoserver.gwc.GWCIntegrationTest.testDirectWMSIntegrationWithVirtualServicesHiddenLayer(GWCIntegrationTest.java:390)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [16.896s]
[INFO] Core Platform Module .............................. SUCCESS [12.490s]
[INFO] Open Web Service Module ........................... SUCCESS [25.107s]
[INFO] Main Module ....................................... SUCCESS [2:11.555s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:14.171s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.795s]
[INFO] Web Map Service Module ............................ SUCCESS [5:56.849s]
[INFO] GeoServer Web Modules ............................. SUCCESS [1.917s]
[INFO] Core UI Module .................................... SUCCESS [1:39.898s]
[INFO] Security UI Module ................................ SUCCESS [3:12.158s]
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [44.514s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [56.919s]
[INFO] KML support for GeoServer ......................... FAILURE [1:05.719s]
[INFO] REST Support Module ............................... SUCCESS [28.389s]
[INFO] WFS UI Module ..................................... SUCCESS [29.759s]
[INFO] Community Space ................................... SUCCESS [0.270s]
[INFO] Printing Module ................................... SUCCESS [23.927s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [6.922s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.197s]
[INFO] Application Schema Support ........................ SUCCESS [0.149s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [33.271s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [25.580s]
[INFO] H2 DataStore Extension ............................ SUCCESS [11.843s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [4.254s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [5.014s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [2.100s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.473s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.598s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.622s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [1:21.855s]
[INFO] Excel Output Format ............................... SUCCESS [2:37.705s]
[INFO] Validation Module ................................. SUCCESS [3.880s]
[INFO] Chart external graphics support ................... SUCCESS [1.836s]
[INFO] Feature Generalization Extension .................. SUCCESS [2.847s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [0.985s]
[INFO] OWS request flow controller ....................... SUCCESS [16.332s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.248s]
[INFO] Web Processing Service Module ..................... SUCCESS [7:11.605s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1:47.300s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [2.562s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [2.053s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [23.354s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.458s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [17.503s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [3:26.803s]
[INFO] Catalog Services for the Web core module .......... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 22:09.702s (Wall Clock)
[INFO] Finished at: Thu Aug 22 09:59:23 UTC 2013
[INFO] Final Memory: 49M/123M
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project kml: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/kml/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :kml
