See <http://hudson.opengeo.org/hudson/job/geoserver-master/6274/changes>
Changes:
[RiniAngreani] GEOT-4531: 1D borehole tests.
[RiniAngreani] ToLineString user doc.
[jdeolive] changing extension to .gpkg, as per spec recommendation
[Andrea Aime] Make sure CSW is built by hudson during normal builds (not just nightlies)
[Andrea Aime] [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[...truncated 40101 lines...]
[INFO]
[INFO] --- maven-jar-plugin:2.4:jar (default-jar) @ csw-core ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ csw-core ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-tests.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ csw-core >>>
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ csw-core ---
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.08.2013 @ 16:55:56 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 22-Aug-2013 17:12
[INFO] [GitCommitIdMojo] build.build.time = 22.08.2013 @ 17:34:53 UTC
[INFO] [GitCommitIdMojo] build.branch = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 404bf5d
[INFO] [GitCommitIdMojo] build.commit.id = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ csw-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ csw-core ---
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 22.783 sec
Running org.geoserver.gwc.web.GWCSettingsPageTest
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-sources.jar>
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ csw-core >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ csw-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ csw-core ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ csw-core ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/csw/csw-core/2.5-SNAPSHOT/csw-core-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/csw/csw-core/2.5-SNAPSHOT/csw-core-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/csw/csw-core/2.5-SNAPSHOT/csw-core-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/csw/csw-core/2.5-SNAPSHOT/csw-core-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/csw-core-2.5-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/csw/csw-core/2.5-SNAPSHOT/csw-core-2.5-SNAPSHOT-test-sources.jar
[INFO]
[INFO] Building Application Schema Integration Test 2.5-SNAPSHOT
[WARNING] *****************************************************************
[WARNING] * Your build is requesting parallel execution, but project *
[WARNING] * contains the following plugin(s) that are not marked as *
[WARNING] * @threadSafe to support parallel building. *
[WARNING] * While this /may/ work fine, please look for plugin updates *
[WARNING] * and/or request plugins be made thread-safe. *
[WARNING] * If reporting an issue, report it against the plugin in *
[WARNING] * question, not against maven-core *
[WARNING] The following plugins are not marked @threadSafe in Application Schema Integration Test:
[WARNING] org.codehaus.mojo:cobertura-maven-plugin:2.3
[WARNING] pl.project13.maven:git-commit-id-plugin:2.0.4
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-app-schema/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-app-schema/11-SNAPSHOT/maven-metadata.xml
313/313 B
Downloaded: http://repo.opengeo.org/org/geotools/gt-app-schema/11-SNAPSHOT/maven-metadata.xml (313 B at 0.8 KB/sec)
Downloading: http://maven.geo-solutions.it/org/geotools/gt-complex/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-complex/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.302 sec
Running org.geoserver.gwc.web.gridset.GridSetNewPageTest
Downloading: http://repo.maven.apache.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[WARNING] The POM for org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1 is missing, no dependency information available
Downloading: http://repo.opengeo.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
Downloading: http://repo.maven.apache.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO]
[INFO] Skipping XLST based WFS output format
[INFO]
[INFO] Skipping WCS UI Module
[INFO]
[INFO] Skipping Web Processing Service GUI
[INFO]
[INFO] Skipping Monitor Hibernate Extension
[INFO]
[INFO] Skipping GeoServer JDBC Security Module
[INFO]
[INFO] Skipping GeoServer LDAP Security Module
[INFO]
[INFO] Skipping GeoServer CAS Security Module
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.72 sec
Running org.geoserver.gwc.web.gridset.GridSetsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.032 sec
Running org.geoserver.gwc.web.layer.CachedLayersPageTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.136s]
[INFO] Core Platform Module .............................. SUCCESS [10.786s]
[INFO] Open Web Service Module ........................... SUCCESS [12.152s]
[INFO] Main Module ....................................... SUCCESS [2:03.897s]
[INFO] Web Feature Service Module ........................ SUCCESS [3:13.788s]
[INFO] Web Coverage Service Module ....................... SUCCESS [3.451s]
[INFO] Web Map Service Module ............................ SUCCESS [4:33.729s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.313s]
[INFO] Core UI Module .................................... SUCCESS [1:55.103s]
[INFO] Security UI Module ................................ SUCCESS [3:19.699s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.426s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:41.131s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:28.469s]
[INFO] KML support for GeoServer ......................... SUCCESS [1:34.208s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [2:07.601s]
[INFO] REST Support Module ............................... SUCCESS [1:03.178s]
[INFO] REST Configuration Service Module ................. SUCCESS [2:38.690s]
[INFO] WMS UI Module ..................................... SUCCESS [48.154s]
[INFO] WFS UI Module ..................................... SUCCESS [30.004s]
[INFO] Demoes Module ..................................... SUCCESS [46.741s]
[INFO] Community Space ................................... SUCCESS [0.277s]
[INFO] Printing Module ................................... SUCCESS [55.469s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [31.378s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.194s]
[INFO] Application Schema Support ........................ SUCCESS [0.204s]
[INFO] Application Schema Integration Test ............... FAILURE [3.210s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [31.435s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [49.301s]
[INFO] GeoSearch Index Module ............................ SUCCESS [36.556s]
[INFO] H2 DataStore Extension ............................ SUCCESS [21.817s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [2.116s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.722s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.608s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.472s]
[INFO] ImageMap Output Format ............................ SUCCESS [13.938s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.264s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.518s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [26.255s]
[INFO] Excel Output Format ............................... SUCCESS [30.074s]
[INFO] Validation Module ................................. SUCCESS [9.819s]
[INFO] Chart external graphics support ................... SUCCESS [1.762s]
[INFO] Feature Generalization Extension .................. SUCCESS [6.942s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.006s]
[INFO] OWS request flow controller ....................... SUCCESS [27.116s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.292s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:22.093s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [32.811s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [13.058s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.444s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.687s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.559s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [43.571s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [1:23.830s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [1.626s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [18.614s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [19.300s]
[INFO] Catalog Services for the Web core module .......... SUCCESS [1:20.004s]
[INFO] BUILD FAILURE
[INFO] Total time: 23:01.738s (Wall Clock)
[INFO] Finished at: Thu Aug 22 17:35:03 UTC 2013
[INFO] Final Memory: 56M/253M
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.677 sec
Running org.geoserver.gwc.web.layer.LayerCacheOptionsTabPanelTest
[ERROR] Failed to execute goal on project app-schema-test: Could not resolve dependencies for project org.geoserver.extension:app-schema-test:jar:2.5-SNAPSHOT: Could not find artifact org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1 in opengeo (http://repo.opengeo.org/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[ERROR]
[ERROR] mvn <goals> -rf :app-schema-test
