See <http://hudson.opengeo.org/hudson/job/geoserver-master/6301/changes>
Changes:
[Niels Charlier] GEOS-5940: CSW support mapping multi-valued metadata property with multiple catalog properties.
[...truncated 55595 lines...]
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>-29.0434 167.9388</gml:pos>
</gml:Point>
</gsml:shape>
</gsml:MappedFeature>
</gml:featureMember>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf3">
<gsml:shape>
<gml:pos>-12.1883 96.8339</gml:pos>
</gml:Point>
</gsml:shape>
<gml:featureMember>
<gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
<gsml:shape>
<gml:pos>-34.9502 117.8102</gml:pos>
</gml:Point>
</gsml:shape>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.155 sec
Running org.geoserver.test.SRSWfsTest
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.103s]
[INFO] Core Platform Module .............................. SUCCESS [5.995s]
[INFO] Open Web Service Module ........................... SUCCESS [21.414s]
[INFO] Main Module ....................................... SUCCESS [2:12.474s]
[INFO] Web Feature Service Module ........................ SUCCESS [5:02.609s]
[INFO] Web Coverage Service Module ....................... SUCCESS [4.068s]
[INFO] Web Map Service Module ............................ SUCCESS [3:46.529s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.715s]
[INFO] Core UI Module .................................... SUCCESS [5:03.568s]
[INFO] Security UI Module ................................ SUCCESS [3:28.660s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.368s]
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [1:07.930s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [1:05.726s]
[INFO] KML support for GeoServer ......................... SUCCESS [3:04.917s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [5:06.801s]
[INFO] REST Support Module ............................... SUCCESS [32.249s]
[INFO] REST Configuration Service Module ................. SUCCESS [3:18.694s]
[INFO] WMS UI Module ..................................... SUCCESS [45.299s]
[INFO] GWC UI Module ..................................... SUCCESS [57.682s]
[INFO] WFS UI Module ..................................... SUCCESS [24.358s]
[INFO] Demoes Module ..................................... SUCCESS [46.726s]
[INFO] WCS UI Module ..................................... SUCCESS [26.591s]
[INFO] Community Space ................................... SUCCESS [0.221s]
[INFO] Printing Module ................................... SUCCESS [18.144s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [7.429s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.173s]
[INFO] Application Schema Support ........................ SUCCESS [0.225s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [21.863s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [23.850s]
[INFO] GeoSearch Index Module ............................ SUCCESS [26.034s]
[INFO] H2 DataStore Extension ............................ SUCCESS [15.242s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.987s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.686s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.499s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.625s]
[INFO] ImageMap Output Format ............................ SUCCESS [15.035s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.211s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [0.569s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [33.862s]
[INFO] Excel Output Format ............................... SUCCESS [31.056s]
[INFO] Validation Module ................................. SUCCESS [2.656s]
[INFO] Chart external graphics support ................... SUCCESS [1.126s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.836s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.090s]
[INFO] OWS request flow controller ....................... SUCCESS [24.100s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.423s]
[INFO] Web Processing Service Module ..................... SUCCESS [3:11.353s]
[INFO] Web Processing Service GUI ........................ SUCCESS [32.659s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [39.876s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [3.064s]
[INFO] GeoServer Monitor Extensions ...................... SUCCESS [0.508s]
[INFO] Core Monitor Extension ............................ SUCCESS [21.799s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [0.327s]
[INFO] XLST based WFS output format ...................... SUCCESS [41.541s]
[INFO] GeoServer INSPIRE Extensions ...................... SUCCESS [47.500s]
[INFO] GeoServer CSS Styling ............................. SUCCESS [27.228s]
[INFO] Catalog Services for the Web parent ............... SUCCESS [0.723s]
[INFO] Catalog Services for the Web interfaces ........... SUCCESS [15.715s]
[INFO] Catalog Services for the Web - Simple CatalogStore implementation SUCCESS [21.832s]
[INFO] Catalog Services for the Web core module .......... FAILURE [37.360s]
[INFO] CSW UI Module ..................................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 27:51.982s (Wall Clock)
[INFO] Finished at: Mon Sep 02 14:05:14 UTC 2013
Sep 2, 2013 2:05:14 PM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<?xml version="1.0" encoding="UTF-8" standalone="no"?>
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" numberOfFeatures="1" timeStamp="2013-09-02T14:05:14.426Z" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2724264798694072597data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:Polygon gml:id="geom_1" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
<gml:LinearRing srsDimension="2">
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:shape>
<gml:LineString gml:id="shape_1" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
</gml:LineString>
</ex:shape>
<ex:length uom="m">1.0</ex:length>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested_one_2">
<ex:geom>
<gml:Point gml:id="nested_one_geom_2" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested_two_1">
<ex:geom>
<gml:Polygon gml:id="nested_two_geom_1" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
[INFO] Final Memory: 58M/250M
Sep 2, 2013 2:05:14 PM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" numberOfFeatures="2" timeStamp="2013-09-02T14:05:14.623Z" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/app-schema/app-schema-test/target/app-schema-mock2724264798694072597data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:geom>
<gml:exterior>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:shape>
</gml:LineString>
</ex:shape>
<ex:nestedFeature>
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature>
<ex:geom>
<gml:exterior>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
<gml:Point gml:id="geom_2" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
</gml:Point>
</ex:geom>
<ex:shape>
<gml:LineString gml:id="shape_2" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:posList>42.58000004047607 31.29 42.58000004047607 31.29</gml:posList>
</gml:LineString>
</ex:shape>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested_one_1">
<ex:geom>
<gml:Polygon gml:id="nested_one_geom_1" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested_two_2">
<ex:geom>
<gml:Point gml:id="nested_two_geom_2" srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-surefire-plugin:2.12.3:test (default-test) on project csw-core: There are test failures.
[ERROR]
[ERROR] Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/src/extension/csw/core/target/surefire-reports> for the individual test results.
[ERROR] -> [Help 1]
[ERROR]
[ERROR]
[ERROR]
[ERROR] mvn <goals> -rf :csw-core
