[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master #6313
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6313/&gt;
Started by user hudson
Checkout:workspace / <http://hudson.opengeo.org/hudson/job/geoserver-master/ws/&gt; - hudson.remoting.LocalChannel@anonymised.com
Using strategy: Default
Last Built Revision: Revision 4e5d21b282c8dd0f0e9d37e9ec15708bdbedf339 (origin/master)
Fetching changes from the remote Git repository
Fetching upstream changes from git://github.com/geoserver/geoserver.git
ERROR: Problem fetching from origin / origin - could be unavailable. Continuing anyway
ERROR: (Underlying report) : Error performing command: git fetch -t git://github.com/geoserver/geoserver.git +refs/heads/*:refs/remotes/origin/*
null
ERROR: Could not fetch from any repository
FATAL: Could not fetch from any repository
hudson.plugins.git.GitException: Could not fetch from any repository
  at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:887)
  at hudson.plugins.git.GitSCM$3.invoke(GitSCM.java:845)
  at hudson.FilePath.act(FilePath.java:758)
  at hudson.FilePath.act(FilePath.java:740)
  at hudson.plugins.git.GitSCM.gerRevisionToBuild(GitSCM.java:845)
  at hudson.plugins.git.GitSCM.checkout(GitSCM.java:622)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:1479)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:507)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:424)
  at hudson.model.Run.run(Run.java:1366)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:145)
See <http://hudson.opengeo.org/hudson/job/geoserver-master/6314/changes&gt;
