See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/2773/>
[...truncated 804 lines...]
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-surefire-report-plugin is missing. @ line 1336, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-jxr-plugin is missing. @ line 1344, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:taglist-maven-plugin is missing. @ line 1352, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:cobertura-maven-plugin is missing. @ line 1366, column 12
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer CAS Security Module
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Monitoring Extension
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO]
[INFO] Building GeoServer 2.2-SNAPSHOT
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloading: http://maven-svn-revision-number-plugin.googlecode.com/svn/m2/releases/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml (686 B at 0.1 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloading: http://maven-svn-revision-number-plugin.googlecode.com/svn/m2/releases/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml (657 B at 16.0 KB/sec)
Downloading: http://maven-svn-revision-number-plugin.googlecode.com/svn/m2/releases/org/apache/maven/plugins/maven-surefire-plugin/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-surefire-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-surefire-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-surefire-plugin/maven-metadata.xml (2 KB at 44.4 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloading: http://maven-svn-revision-number-plugin.googlecode.com/svn/m2/releases/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml (588 B at 27.3 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloading: http://maven-svn-revision-number-plugin.googlecode.com/svn/m2/releases/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml (632 B at 7.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-api/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-api/8-SNAPSHOT/maven-metadata.xml (978 B at 7.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/library/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/library/8-SNAPSHOT/maven-metadata.xml (594 B at 34.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/modules/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/modules/8-SNAPSHOT/maven-metadata.xml (594 B at 30.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/geotools/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/geotools/8-SNAPSHOT/maven-metadata.xml (595 B at 20.8 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/8-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-referencing/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-referencing/8-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-referencing/8-SNAPSHOT/maven-metadata.xml (986 B at 38.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-metadata/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-metadata/8-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-metadata/8-SNAPSHOT/maven-metadata.xml (983 B at 48.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/8-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-opengis/8-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-opengis/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-opengis/8-SNAPSHOT/maven-metadata.xml (982 B at 43.6 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-main/8-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/8-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-main/8-SNAPSHOT/maven-metadata.xml (2 KB at 44.7 KB/sec)
[INFO]
[INFO] --- svn-revision-number-maven-plugin:1.8-SVN7:revision (default) @ geoserver ---
Downloading: http://maven.tmatesoft.com/content/repositories/snapshots/org/tmatesoft/sqljet/sqljet/1.1.0-SNAPSHOT/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/tmatesoft/sqljet/sqljet/1.1.0-SNAPSHOT/maven-metadata.xml
Downloaded: http://maven.tmatesoft.com/content/repositories/snapshots/org/tmatesoft/sqljet/sqljet/1.1.0-SNAPSHOT/maven-metadata.xml (2 KB at 0.2 KB/sec)
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/> (directory)
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.1.2:jar (attach-sources) @ geoserver >>>
[INFO]
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedDate" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO]
[INFO] <<< maven-source-plugin:2.1.2:jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.1.2:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.1.2:test-jar (attach-sources) @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.1.2:test-jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.1.2:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.2-SNAPSHOT/geoserver-2.2-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/target/geoserver-2.2-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.2-SNAPSHOT/geoserver-2.2-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [18.233s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Monitoring Extension .................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 20.624s
[INFO] Finished at: Mon Jul 02 16:27:17 UTC 2012
[INFO] Final Memory: 20M/136M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to deploy artifacts/metadata: No connector available to access repository opengeo (dav:http://repo.opengeo.org) of type default using the available factories WagonRepositoryConnectorFactory
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to deploy artifacts/metadata: No connector available to access repository opengeo (dav:http://repo.opengeo.org) of type default using the available factories WagonRepositoryConnectorFactory -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
