See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3061/>
[...truncated 1389 lines...]
Downloading: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-postgis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/jdbc/gt-jdbc-postgis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/jdbc/gt-jdbc-postgis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/jdbc/gt-jdbc-postgis/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/jdbc/gt-jdbc-postgis/9-SNAPSHOT/maven-metadata.xml (988 B at 68.9 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-shapefile/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-shapefile/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-shapefile/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-shapefile/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-shapefile/9-SNAPSHOT/maven-metadata.xml (980 B at 13.7 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-wfs/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-wfs/9-SNAPSHOT/maven-metadata.xml (974 B at 32.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/unsupported/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/unsupported/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/unsupported/9-SNAPSHOT/maven-metadata.xml (596 B at 25.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-wfs/9-SNAPSHOT/maven-metadata.xml (982 B at 24.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/maven-metadata.xml (987 B at 23.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/maven-metadata.xml (987 B at 15.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/xsd/gt-xsd-fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/xsd/gt-xsd-fes/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/xsd/gt-xsd-fes/9-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/xsd/gt-xsd-fes/9-SNAPSHOT/maven-metadata.xml (982 B at 20.4 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-gtopo30/9-SNAPSHOT/gt-gtopo30-9-20121112.114800-256.jar
Downloaded: http://repo.opengeo.org/org/geotools/gt-gtopo30/9-SNAPSHOT/gt-gtopo30-9-20121112.114800-256.jar (37 KB at 1640.1 KB/sec)
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ main ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 92c16eb88cdbba004c05c76bf6647661d1e785f3
[INFO] [GitCommitIdMojo] build.commit.id = 92c16eb88cdbba004c05c76bf6647661d1e785f3
[INFO] [GitCommitIdMojo] build.commit.message.short = proxy auth documentation
[INFO] [GitCommitIdMojo] build.commit.time = 12.11.2012 @ 08:54:35 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 92c16eb
[INFO] [GitCommitIdMojo] build.commit.message.full = proxy auth documentation
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 12-Nov-2012 12:52
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 12.11.2012 @ 12:53:13 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ main ---
[debug] execute contextualize
[INFO] Copying 32 resources
[INFO] Copying 162 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ main ---
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/classes>
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ main ---
[INFO] Copying 91 resources
[INFO] Copying 12 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ main ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ main ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ main ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/main-2.3-SNAPSHOT.jar>
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ main ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ main >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 12.11.2012 @ 12:53:22 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ main <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ main ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ main >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ main <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ main ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ main ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/main-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.3-SNAPSHOT/main-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.3-SNAPSHOT/main-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/main-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.3-SNAPSHOT/main-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/main-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.3-SNAPSHOT/main-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/main/target/main-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/main/2.3-SNAPSHOT/main-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ main ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 68.9 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/main-2.3-20121112.125323-275.jar
Uploaded: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/main-2.3-20121112.125323-275.jar (1504 KB at 10441.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/main-2.3-20121112.125323-275.pom
Uploaded: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/main-2.3-20121112.125323-275.pom (7 KB at 131.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/main/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/main/maven-metadata.xml (2 KB at 48.2 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 30.0 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/main/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/main/maven-metadata.xml (2 KB at 33.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/main/2.3-SNAPSHOT/main-2.3-20121112.125323-275-tests.jar
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [25.757s]
[INFO] Core Platform Module .............................. SUCCESS [2.875s]
[INFO] Open Web Service Module ........................... SUCCESS [4.995s]
[INFO] Main Module ....................................... FAILURE [23.410s]
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Monitoring Extension .................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:00.005s
[INFO] Finished at: Mon Nov 12 12:53:28 UTC 2012
[INFO] Final Memory: 25M/252M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project main: Failed to deploy artifacts: Could not transfer artifact org.geoserver:main:jar:tests:2.3-20121112.125323-275 from/to opengeo (dav:http://repo.opengeo.org): Failed to create destination WebDAV collection (directory): /org/geoserver/main/2.3-SNAPSHOT
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project main: Failed to deploy artifacts: Could not transfer artifact org.geoserver:main:jar:tests:2.3-20121112.125323-275 from/to opengeo (dav:http://repo.opengeo.org): Failed to create destination WebDAV collection (directory): /org/geoserver/main/2.3-SNAPSHOT: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :main
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
