[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3065
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3065/&gt;
[...truncated 10075 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 14-Nov-2012 12:02
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 14.11.2012 @ 12:06:37 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-cas <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-cas ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ sec-cas ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/cas/target/sec-cas-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ sec-cas ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 14.6 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276.jar
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276.jar (42 KB at 395.9 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276.pom
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276.pom (2 KB at 24.9 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml (519 B at 13.3 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 20.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/maven-metadata.xml (519 B at 11.3 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-tests.jar (27 KB at 380.1 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 25.8 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-sources.jar (28 KB at 500.5 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 26.2 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-test-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/sec-cas/2.3-SNAPSHOT/sec-cas-2.3-20121114.120637-276-test-sources.jar (13 KB at 150.8 KB/sec)
[INFO]
[INFO] Building GeoServer Security Extension Modules 2.3-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ security ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = bafc8e62089e12d3b6d205a72830dfa3ea7676ed
[INFO] [GitCommitIdMojo] build.commit.id = bafc8e62089e12d3b6d205a72830dfa3ea7676ed
[INFO] [GitCommitIdMojo] build.commit.message.short = Fix for GEOS-5402 and GEOS-5388
[INFO] [GitCommitIdMojo] build.commit.time = 14.11.2012 @ 11:29:27 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bafc8e6
[INFO] [GitCommitIdMojo] build.commit.message.full = Fix for GEOS-5402 and GEOS-5388
5402: Subclasses of GeoServerPreAuthenticationFilter do not map local admin
roles to global admin roles
5388: Confusing 'Bad credentials forroot' exception in verbose_logging mode
when logged in as admin or root
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.build.time = 14.11.2012 @ 12:06:38 UTC
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ security ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ security >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ security ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ security >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ security ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/security/target/security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ security ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml (820 B at 6.6 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20121114.120639-112.pom
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20121114.120639-112.pom (3 KB at 10.5 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml (358 B at 9.7 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/maven-metadata.xml (820 B at 15.1 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/security/maven-metadata.xml (358 B at 5.5 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20121114.120639-112-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/security/2.3-SNAPSHOT/security-2.3-20121114.120639-112-tests.jar (2 KB at 33.8 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [21.135s]
[INFO] Core Platform Module .............................. SUCCESS [5.852s]
[INFO] Open Web Service Module ........................... SUCCESS [5.273s]
[INFO] Main Module ....................................... SUCCESS [28.189s]
[INFO] Web Feature Service Module ........................ SUCCESS [3.659s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.366s]
[INFO] Web Map Service Module ............................ SUCCESS [3.713s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.682s]
[INFO] Core UI Module .................................... SUCCESS [4.428s]
[INFO] Security UI Module ................................ SUCCESS [2.168s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.961s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2.700s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1.387s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2.310s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.080s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [12.800s]
[INFO] REST Support Module ............................... SUCCESS [1.551s]
[INFO] REST Configuration Service Module ................. SUCCESS [2.486s]
[INFO] WMS UI Module ..................................... SUCCESS [1.678s]
[INFO] GWC UI Module ..................................... SUCCESS [1.789s]
[INFO] WFS UI Module ..................................... SUCCESS [1.776s]
[INFO] Demoes Module ..................................... SUCCESS [1.727s]
[INFO] WCS UI Module ..................................... SUCCESS [1.643s]
[INFO] Community Space ................................... SUCCESS [1.219s]
[INFO] Printing Module ................................... SUCCESS [1.769s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [19.888s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.407s]
[INFO] GeoServer Monitoring Extension .................... SUCCESS [9.308s]
[INFO] GeoServer Web Application ......................... SUCCESS [15.440s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.723s]
[INFO] Application Schema Support ........................ SUCCESS [6.606s]
[INFO] Application Schema Integration Test ............... SUCCESS [3.595s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [2.014s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [2.582s]
[INFO] GeoSearch Index Module ............................ SUCCESS [1.625s]
[INFO] H2 DataStore Extension ............................ SUCCESS [1.580s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.951s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [0.788s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [0.953s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.064s]
[INFO] ImageMap Output Format ............................ SUCCESS [2.061s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.775s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.061s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [1.980s]
[INFO] Excel Output Format ............................... SUCCESS [18.574s]
[INFO] Validation Module ................................. SUCCESS [1.758s]
[INFO] Chart external graphics support ................... SUCCESS [6.517s]
[INFO] Feature Generalization Extension .................. SUCCESS [1.420s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.129s]
[INFO] OWS request flow controller ....................... SUCCESS [2.348s]
[INFO] Web Processing Service parent ..................... SUCCESS [0.684s]
[INFO] Web Processing Service Module ..................... SUCCESS [14.878s]
[INFO] Web Processing Service GUI ........................ SUCCESS [6.692s]
[INFO] GeoServer Layer Querying filter functions ......... SUCCESS [1.556s]
[INFO] Teradata DataStore Extension ...................... SUCCESS [1.596s]
[INFO] GeoServer CAS Security Module ..................... SUCCESS [1.744s]
[INFO] GeoServer Security Extension Modules .............. SUCCESS [1.278s]
[INFO] BUILD SUCCESS
[INFO] Total time: 4:19.817s
[INFO] Finished at: Wed Nov 14 12:06:39 UTC 2012
[INFO] Final Memory: 55M/123M
[DEBUG] Closing connection to remote
[DEBUG] Waiting for process to finish
[DEBUG] Result: 0
[src] $ /bin/sh -xe /var/cache/jetty/data/hudson5294989436017680458.sh
+ VER=2.3-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.3-SNAPSHOT.jar
+ sha1sum web-app-2.3-SNAPSHOT.jar
+ curl -u hudson:chrono44logic -T web-app-2.3-SNAPSHOT.jar http://repo.opengeo.org/org/geoserver/web/web-app/2.3-SNAPSHOT/web-app-2.3-SNAPSHOT.jar
curl: (6) Couldn't resolve host 'repo.opengeo.org'
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3066/&gt;
