[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3069
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3069/&gt;
[...truncated 800 lines...]
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO]
[INFO] Building GeoServer 2.3-SNAPSHOT
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-compiler-plugin/maven-metadata.xml (686 B at 1.8 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml (686 B at 3.5 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml (588 B at 14.0 KB/sec)
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml (692 B at 22.5 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-api/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-api:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
[WARNING] Failure to transfer org.geotools:gt-api:9-SNAPSHOT/maven-metadata.xml from http://repo.opengeo.org/ was cached in the local repository, resolution will not be reattempted until the update interval of opengeo has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-api:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/\): repo.opengeo.org
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/library/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:library:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
Downloading: http://repo.opengeo.org/org/geotools/modules/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:modules:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/geotools/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:geotools:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
Downloading: http://repo.opengeo.org/org/geotools/gt-referencing/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-referencing/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-referencing:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
Downloading: http://repo.opengeo.org/org/geotools/gt-metadata/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-metadata/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-metadata:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
[WARNING] Failure to transfer org.geotools:gt-metadata:9-SNAPSHOT/maven-metadata.xml from http://repo.opengeo.org/ was cached in the local repository, resolution will not be reattempted until the update interval of opengeo has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-metadata:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/\): repo.opengeo.org
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-opengis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-opengis/9-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-opengis:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/9-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-main/9-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geotools:gt-main:9-SNAPSHOT/maven-metadata.xml from/to opengeo (http://repo.opengeo.org/): repo.opengeo.org
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ geoserver ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 33fa771c21d08fd52ca047c1e62083b27fbc74b8
[INFO] [GitCommitIdMojo] build.commit.id = 33fa771c21d08fd52ca047c1e62083b27fbc74b8
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #65 from jive/cleanup
[INFO] [GitCommitIdMojo] build.commit.time = 17.11.2012 @ 11:56:34 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 33fa771
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #65 from jive/cleanup
Fill in a header comment for pom.xml files
[INFO] [GitCommitIdMojo] build.commit.user.email = jody.garnett@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Jody Garnett
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 17-Nov-2012 13:02
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 17.11.2012 @ 13:03:23 UTC
[INFO]
[INFO] --- maven-jar-plugin:2.4:test-jar (default) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ geoserver ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ geoserver ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ geoserver ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.3-SNAPSHOT/geoserver-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/target/geoserver-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.3-SNAPSHOT/geoserver-2.3-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ geoserver ---
WAGON_VERSION: 1.0-beta-2
Downloading: dav:http://repo.opengeo.org/org/geoserver/geoserver/2.3-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver:geoserver:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/geoserver/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [31.365s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Monitoring Extension .................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 33.684s
[INFO] Finished at: Sat Nov 17 13:03:24 UTC 2012
[INFO] Final Memory: 21M/139M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/geoserver/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project geoserver: Failed to retrieve remote metadata org.geoserver:geoserver:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver:geoserver:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/geoserver/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3070/&gt;
