[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3085
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3085/&gt;
[...truncated 8419 lines...]
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 21-Nov-2012 19:19
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 21.11.2012 @ 19:23:35 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wps-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wps-core ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wps-core ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ wps-core ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 17.2 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295.jar
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295.jar (274 KB at 2320.6 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295.pom
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295.pom (6 KB at 65.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml (788 B at 16.7 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 17.6 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml (788 B at 17.1 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-tests.jar (438 KB at 5833.3 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 22.5 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-sources.jar (181 KB at 3060.1 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 24.0 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-test-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/wps-core-2.3-20121121.192335-295-test-sources.jar (397 KB at 6106.4 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.3-SNAPSHOT/maven-metadata.xml (2 KB at 22.8 KB/sec)
[INFO]
[INFO] Building Web Processing Service GUI 2.3-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-wps ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 45817b3e7e99e0b91cb1d13f459ac2e63a721af8
[INFO] [GitCommitIdMojo] build.commit.id = 45817b3e7e99e0b91cb1d13f459ac2e63a721af8
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding documentation about role source
[INFO] [GitCommitIdMojo] build.commit.time = 21.11.2012 @ 10:16:19 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 45817b3
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding documentation about role source
[INFO] [GitCommitIdMojo] build.build.time = 21.11.2012 @ 19:23:37 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ web-wps ---
[debug] execute contextualize
[INFO] Copying 12 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ web-wps ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ web-wps ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ web-wps ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ web-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ web-wps ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ web-wps ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-wps ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.3-SNAPSHOT/web-wps-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ web-wps ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/web-wps/2.3-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.extension:web-wps:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.084s]
[INFO] Core Platform Module .............................. SUCCESS [2.702s]
[INFO] Open Web Service Module ........................... SUCCESS [4.995s]
[INFO] Main Module ....................................... SUCCESS [14.596s]
[INFO] Web Feature Service Module ........................ SUCCESS [4.017s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.912s]
[INFO] Web Map Service Module ............................ SUCCESS [8.305s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.982s]
[INFO] Core UI Module .................................... SUCCESS [5.656s]
[INFO] Security UI Module ................................ SUCCESS [3.114s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.938s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2.763s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [1.461s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2.826s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.459s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [11.002s]
[INFO] REST Support Module ............................... SUCCESS [4.004s]
[INFO] REST Configuration Service Module ................. SUCCESS [7.164s]
[INFO] WMS UI Module ..................................... SUCCESS [2.318s]
[INFO] GWC UI Module ..................................... SUCCESS [2.999s]
[INFO] WFS UI Module ..................................... SUCCESS [1.958s]
[INFO] Demoes Module ..................................... SUCCESS [2.639s]
[INFO] WCS UI Module ..................................... SUCCESS [1.937s]
[INFO] Community Space ................................... SUCCESS [0.666s]
[INFO] Printing Module ................................... SUCCESS [2.113s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [17.559s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [3.201s]
[INFO] GeoServer Monitoring Extension .................... SUCCESS [9.999s]
[INFO] GeoServer Web Application ......................... SUCCESS [27.446s]
[INFO] GeoServer Extensions .............................. SUCCESS [0.795s]
[INFO] Application Schema Support ........................ SUCCESS [0.851s]
[INFO] Application Schema Integration Test ............... SUCCESS [5.118s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [1.795s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [2.369s]
[INFO] GeoSearch Index Module ............................ SUCCESS [2.412s]
[INFO] H2 DataStore Extension ............................ SUCCESS [1.746s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.596s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [1.131s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [1.181s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [1.216s]
[INFO] ImageMap Output Format ............................ SUCCESS [2.478s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [2.174s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.082s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [2.188s]
[INFO] Excel Output Format ............................... SUCCESS [7.158s]
[INFO] Validation Module ................................. SUCCESS [2.585s]
[INFO] Chart external graphics support ................... SUCCESS [2.389s]
[INFO] Feature Generalization Extension .................. SUCCESS [1.868s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.251s]
[INFO] OWS request flow controller ....................... SUCCESS [2.086s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.360s]
[INFO] Web Processing Service Module ..................... SUCCESS [13.430s]
[INFO] Web Processing Service GUI ........................ FAILURE [11.618s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:57.046s
[INFO] Finished at: Wed Nov 21 19:23:48 UTC 2012
[INFO] Final Memory: 52M/91M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-wps: Failed to retrieve remote metadata org.geoserver.extension:web-wps:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.extension:web-wps:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-wps: Failed to retrieve remote metadata org.geoserver.extension:web-wps:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.extension:web-wps:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :web-wps
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3086/&gt;
