[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3193
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3193/&gt;
[...truncated 2453 lines...]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ security ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 727d164f97b764693c476f2fb45eea427755805e
[INFO] [GitCommitIdMojo] build.commit.id = 727d164f97b764693c476f2fb45eea427755805e
[INFO] [GitCommitIdMojo] build.commit.message.short = fixed docguide URL from translation page
[INFO] [GitCommitIdMojo] build.commit.time = 14.01.2013 @ 11:23:16 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 727d164
[INFO] [GitCommitIdMojo] build.commit.message.full = fixed docguide URL from translation page
[INFO] [GitCommitIdMojo] build.commit.user.email = fgdrf@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Frank Gasdorf
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 14-Jan-2013 12:09
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 14.01.2013 @ 12:10:47 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ security ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/target/security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ security ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/maven-metadata.xml (810 B at 13.0 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/security-2.3-20130114.121047-403.pom
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/security-2.3-20130114.121047-403.pom (3 KB at 24.7 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml (608 B at 15.2 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/maven-metadata.xml (810 B at 5.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml (608 B at 12.9 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/security-2.3-20130114.121047-403-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/security-2.3-20130114.121047-403-tests.jar (2 KB at 38.3 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.3-SNAPSHOT/maven-metadata.xml (810 B at 15.2 KB/sec)
[INFO]
[INFO] Building GeoServer JDBC Security Module 2.3-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ sec-jdbc ---
[INFO] [GitCommitIdMojo] build.build.time = 14.01.2013 @ 12:10:49 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ sec-jdbc ---
[debug] execute contextualize
[INFO] Copying 8 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ sec-jdbc ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ sec-jdbc ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ sec-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ sec-jdbc ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ sec-jdbc ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ sec-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ sec-jdbc ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/sec-jdbc-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/sec-jdbc-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/sec-jdbc-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/sec-jdbc-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/sec-jdbc-2.3-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ sec-jdbc ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/sec-jdbc/2.3-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.security:sec-jdbc:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [8.538s]
[INFO] Core Platform Module .............................. SUCCESS [5.519s]
[INFO] Open Web Service Module ........................... SUCCESS [6.174s]
[INFO] Main Module ....................................... SUCCESS [14.472s]
[INFO] Web Feature Service Module ........................ SUCCESS [5.362s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.190s]
[INFO] Web Map Service Module ............................ SUCCESS [3.301s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.718s]
[INFO] Core UI Module .................................... SUCCESS [12.870s]
[INFO] Security UI Module ................................ SUCCESS [2.219s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.088s]
[INFO] GeoServer JDBC Security Module .................... FAILURE [12.305s]
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 1:17.274s
[INFO] Finished at: Mon Jan 14 12:11:00 UTC 2013
[INFO] Final Memory: 31M/267M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project sec-jdbc: Failed to retrieve remote metadata org.geoserver.security:sec-jdbc:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.security:sec-jdbc:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project sec-jdbc: Failed to retrieve remote metadata org.geoserver.security:sec-jdbc:2.3-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.security:sec-jdbc:2.3-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.3\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :sec-jdbc
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3194/&gt;
