See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3310/>
[...truncated 8416 lines...]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ wps-core <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ wps-core ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ wps-core ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/wps-core/target/wps-core-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ wps-core ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml (2 KB at 7.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47.jar
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47.jar (275 KB at 628.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47.pom
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47.pom (5 KB at 37.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml (954 B at 133.1 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml (2 KB at 16.9 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/maven-metadata.xml (954 B at 20.7 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-tests.jar (441 KB at 6680.6 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml (2 KB at 12.7 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-sources.jar (182 KB at 3122.5 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml (2 KB at 13.2 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-test-sources.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/wps-core-2.4-20130220.200710-47-test-sources.jar (399 KB at 6532.5 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/extension/wps-core/2.4-SNAPSHOT/maven-metadata.xml (2 KB at 25.7 KB/sec)
[INFO]
[INFO] Building Web Processing Service GUI 2.4-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ web-wps ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #152 from bencaradocdavies/geot-4386
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.02.2013 @ 09:01:03 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Feb-2013 20:03
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2013 @ 20:07:12 UTC
[INFO] [GitCommitIdMojo] build.branch = d16f39ec9137862b2ccfc8bf855c33e9a4a858d5
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = d16f39e
[INFO] [GitCommitIdMojo] build.commit.id = d16f39ec9137862b2ccfc8bf855c33e9a4a858d5
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #152 from bencaradocdavies/geot-4386
GEOT-4386 schema resolver api changes and promotion to gt-xml
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ web-wps ---
[debug] execute contextualize
[INFO] Copying 12 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/src/main/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ web-wps ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ web-wps ---
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/src/test/resources>
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ web-wps ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ web-wps ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ web-wps ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ web-wps ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ web-wps ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 20.02.2013 @ 20:07:13 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ web-wps ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.4-SNAPSHOT-test-sources.jar>
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ web-wps ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.4-SNAPSHOT/web-wps-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.4-SNAPSHOT/web-wps-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.4-SNAPSHOT/web-wps-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.4-SNAPSHOT/web-wps-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/extension/wps/web-wps/target/web-wps-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/extension/web-wps/2.4-SNAPSHOT/web-wps-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ web-wps ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/extension/web-wps/2.4-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.extension:web-wps:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [6.089s]
[INFO] Core Platform Module .............................. SUCCESS [3.119s]
[INFO] Open Web Service Module ........................... SUCCESS [5.178s]
[INFO] Main Module ....................................... SUCCESS [14.172s]
[INFO] Web Feature Service Module ........................ SUCCESS [4.770s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.592s]
[INFO] Web Map Service Module ............................ SUCCESS [3.484s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.614s]
[INFO] Core UI Module .................................... SUCCESS [5.528s]
[INFO] Security UI Module ................................ SUCCESS [3.050s]
[INFO] GeoServer Security Modules ........................ SUCCESS [1.009s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2.060s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [2.035s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2.059s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.627s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [6.587s]
[INFO] REST Support Module ............................... SUCCESS [1.510s]
[INFO] REST Configuration Service Module ................. SUCCESS [2.311s]
[INFO] WMS UI Module ..................................... SUCCESS [1.777s]
[INFO] GWC UI Module ..................................... SUCCESS [6.167s]
[INFO] WFS UI Module ..................................... SUCCESS [2.755s]
[INFO] Demoes Module ..................................... SUCCESS [1.967s]
[INFO] WCS UI Module ..................................... SUCCESS [1.647s]
[INFO] Community Space ................................... SUCCESS [0.587s]
[INFO] Printing Module ................................... SUCCESS [1.636s]
[INFO] HTTP Proxy Extension .............................. SUCCESS [4.881s]
[INFO] GeoServer Embedded FTP server ..................... SUCCESS [2.898s]
[INFO] GeoServer Web Application ......................... SUCCESS [14.368s]
[INFO] GeoServer Extensions .............................. SUCCESS [2.264s]
[INFO] Application Schema Support ........................ SUCCESS [0.659s]
[INFO] Application Schema Integration Test ............... SUCCESS [3.268s]
[INFO] Sample DataAccess Integration Test ................ SUCCESS [3.687s]
[INFO] ArcSDE DataStore Extension ........................ SUCCESS [5.660s]
[INFO] GeoSearch Index Module ............................ SUCCESS [2.207s]
[INFO] H2 DataStore Extension ............................ SUCCESS [1.593s]
[INFO] SQL Server DataStore Extension .................... SUCCESS [1.627s]
[INFO] Oracle DataStore Extension ........................ SUCCESS [5.038s]
[INFO] MySQL DataStore Extension ......................... SUCCESS [2.761s]
[INFO] DB2 DataStore Extension ........................... SUCCESS [0.992s]
[INFO] ImageMap Output Format ............................ SUCCESS [8.659s]
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SUCCESS [1.909s]
[INFO] JP2K Coverage Extension ........................... SUCCESS [1.336s]
[INFO] ogr2ogr Output Format ............................. SUCCESS [7.185s]
[INFO] Excel Output Format ............................... SUCCESS [3.137s]
[INFO] Validation Module ................................. SUCCESS [2.545s]
[INFO] Chart external graphics support ................... SUCCESS [1.462s]
[INFO] Feature Generalization Extension .................. SUCCESS [3.245s]
[INFO] Image Mosaic JDBC Extension ....................... SUCCESS [1.407s]
[INFO] OWS request flow controller ....................... SUCCESS [3.441s]
[INFO] Web Processing Service parent ..................... SUCCESS [1.209s]
[INFO] Web Processing Service Module ..................... SUCCESS [18.692s]
[INFO] Web Processing Service GUI ........................ FAILURE [26.291s]
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 3:44.330s
[INFO] Finished at: Wed Feb 20 20:07:38 UTC 2013
[INFO] Final Memory: 52M/96M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-wps: Failed to retrieve remote metadata org.geoserver.extension:web-wps:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.extension:web-wps:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project web-wps: Failed to retrieve remote metadata org.geoserver.extension:web-wps:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.extension:web-wps:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/extension/web\-wps/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :web-wps
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
