[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3325
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3325/&gt;
[...truncated 4675 lines...]
[INFO] Building HTTP Proxy Extension 2.4-SNAPSHOT
Downloading: http://maven.restlet.org/org/geotools/ogc/net.opengis.ows/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-ows/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-core/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-cql/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-property/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-epsg-hsql/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-wms/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-render/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-sld/10-SNAPSHOT/maven-metadata.xml
[WARNING] Failure to transfer org.geotools.xsd:gt-xsd-filter:10-SNAPSHOT/maven-metadata.xml from http://maven.geo-solutions.it/ was cached in the local repository, resolution will not be reattempted until the update interval of geosolutions has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.xsd:gt-xsd-filter:10-SNAPSHOT/maven-metadata.xml from/to geosolutions (http://maven.geo-solutions.it/\): maven.geo-solutions.it
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-filter/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-gml2/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-gml3/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-imagemosaic/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/jdbc/gt-jdbc-h2/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/jdbc/gt-jdbc-oracle/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-coverage/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-validation/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-graph/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-data/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-shapefile/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/jdbc/gt-jdbc-postgis/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-wfs/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-xml/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-wfs/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/xsd/gt-xsd-fes/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/ogc/net.opengis.wfs/10-SNAPSHOT/maven-metadata.xml
[WARNING] Failure to transfer org.geotools.ogc:org.w3.xlink:10-SNAPSHOT/maven-metadata.xml from http://maven.geo-solutions.it/ was cached in the local repository, resolution will not be reattempted until the update interval of geosolutions has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools.ogc:org.w3.xlink:10-SNAPSHOT/maven-metadata.xml from/to geosolutions (http://maven.geo-solutions.it/\): maven.geo-solutions.it
Downloading: http://maven.restlet.org/org/geotools/ogc/org.w3.xlink/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/ogc/net.opengis.fes/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-jdbc/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-metadata/10-SNAPSHOT/maven-metadata.xml
[WARNING] Failure to transfer org.geotools:gt-opengis:10-SNAPSHOT/maven-metadata.xml from http://maven.geo-solutions.it/ was cached in the local repository, resolution will not be reattempted until the update interval of geosolutions has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-opengis:10-SNAPSHOT/maven-metadata.xml from/to geosolutions (http://maven.geo-solutions.it/\): maven.geo-solutions.it
Downloading: http://maven.restlet.org/org/geotools/gt-opengis/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-arcgrid/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-geotiff/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-gtopo30/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-image/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
[WARNING] Failure to transfer org.geotools:gt-referencing:10-SNAPSHOT/maven-metadata.xml from http://maven.geo-solutions.it/ was cached in the local repository, resolution will not be reattempted until the update interval of geosolutions has elapsed or updates are forced. Original error: Could not transfer metadata org.geotools:gt-referencing:10-SNAPSHOT/maven-metadata.xml from/to geosolutions (http://maven.geo-solutions.it/\): maven.geo-solutions.it
Downloading: http://maven.restlet.org/org/geotools/gt-referencing/10-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.restlet.org/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ proxy ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5667] Add support for multipart responses in WCS 2.0
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 28.02.2013 @ 11:29:21 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 28-Feb-2013 12:28
[INFO] [GitCommitIdMojo] build.build.time = 28.02.2013 @ 12:30:30 UTC
[INFO] [GitCommitIdMojo] build.branch = 1b396caa01f283f099b8262d30296a216609a457
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 1b396ca
[INFO] [GitCommitIdMojo] build.commit.id = 1b396caa01f283f099b8262d30296a216609a457
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5667] Add support for multipart responses in WCS 2.0
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ proxy ---
[debug] execute contextualize
[INFO] Copying 7 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/src/main/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ proxy ---
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/target/classes&gt;
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ proxy ---
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/src/test/resources&gt;
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ proxy ---
[INFO] No sources to compile
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ proxy ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ proxy ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ proxy ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ proxy >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 28.02.2013 @ 12:30:31 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ proxy <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ proxy ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ proxy >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ proxy <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ proxy ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ proxy ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/target/proxy-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.4-SNAPSHOT/proxy-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.4-SNAPSHOT/proxy-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/target/proxy-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.4-SNAPSHOT/proxy-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/community/proxy/target/proxy-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/proxy/2.4-SNAPSHOT/proxy-2.4-SNAPSHOT-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ proxy ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/community/proxy/2.4-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.community:proxy:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/community/proxy/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [17.089s]
[INFO] Core Platform Module .............................. SUCCESS [3.344s]
[INFO] Open Web Service Module ........................... SUCCESS [5.307s]
[INFO] Main Module ....................................... SUCCESS [19.135s]
[INFO] Web Feature Service Module ........................ SUCCESS [2.499s]
[INFO] Web Coverage Service Module ....................... SUCCESS [2.135s]
[INFO] Web Map Service Module ............................ SUCCESS [2.712s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.608s]
[INFO] Core UI Module .................................... SUCCESS [5.061s]
[INFO] Security UI Module ................................ SUCCESS [2.597s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.931s]
[INFO] GeoServer JDBC Security Module .................... SUCCESS [2.618s]
[INFO] GeoServer LDAP Security Module .................... SUCCESS [6.293s]
[INFO] Web Coverage Service 1.0 Module ................... SUCCESS [2.052s]
[INFO] Web Coverage Service 1.1 Module ................... SUCCESS [2.489s]
[INFO] Web Map Service KML output formats ................ SUCCESS [1.326s]
[INFO] GeoWebCache (GWC) Module .......................... SUCCESS [7.762s]
[INFO] REST Support Module ............................... SUCCESS [1.458s]
[INFO] REST Configuration Service Module ................. SUCCESS [1.902s]
[INFO] WMS UI Module ..................................... SUCCESS [1.904s]
[INFO] GWC UI Module ..................................... SUCCESS [2.054s]
[INFO] WFS UI Module ..................................... SUCCESS [2.362s]
[INFO] Demoes Module ..................................... SUCCESS [1.807s]
[INFO] WCS UI Module ..................................... SUCCESS [1.923s]
[INFO] Community Space ................................... SUCCESS [1.013s]
[INFO] Printing Module ................................... SUCCESS [3.754s]
[INFO] HTTP Proxy Extension .............................. FAILURE [14.752s]
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:01.581s
[INFO] Finished at: Thu Feb 28 12:30:41 UTC 2013
[INFO] Final Memory: 39M/126M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project proxy: Failed to retrieve remote metadata org.geoserver.community:proxy:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.community:proxy:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/community/proxy/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project proxy: Failed to retrieve remote metadata org.geoserver.community:proxy:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.community:proxy:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/community/proxy/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :proxy
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3326/&gt;
