[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3414
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3414/&gt;
[...truncated 2455 lines...]
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Regularise handling of "+" in file URLs to fix Jenkins build on Windows
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.04.2013 @ 08:48:20 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 09-Apr-2013 09:57
[INFO] [GitCommitIdMojo] build.build.time = 09.04.2013 @ 09:58:42 UTC
[INFO] [GitCommitIdMojo] build.branch = a818d082df5e7844153b753d4399db8ab846616a
[INFO] [GitCommitIdMojo] build.commit.user.email = Ben.Caradoc-Davies@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a818d08
[INFO] [GitCommitIdMojo] build.commit.id = a818d082df5e7844153b753d4399db8ab846616a
[INFO] [GitCommitIdMojo] build.commit.message.full = Regularise handling of "+" in file URLs to fix Jenkins build on Windows
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ security <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ security ---
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ security ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.4-SNAPSHOT/security-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/target/security-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.4-SNAPSHOT/security-2.4-SNAPSHOT-tests.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ security ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/maven-metadata.xml
Downloaded: dav:http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/maven-metadata.xml (810 B at 12.8 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/security-2.4-20130409.095842-148.pom
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/security-2.4-20130409.095842-148.pom (3 KB at 37.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml (836 B at 20.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/maven-metadata.xml (810 B at 12.4 KB/sec)
Uploading: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml
Uploaded: http://repo.opengeo.org/org/geoserver/security/maven-metadata.xml (836 B at 16.7 KB/sec)
Uploading: dav:http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/security-2.4-20130409.095842-148-tests.jar
Uploaded: dav:http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/security-2.4-20130409.095842-148-tests.jar (2 KB at 34.7 KB/sec)
Uploaded: http://repo.opengeo.org/org/geoserver/security/2.4-SNAPSHOT/maven-metadata.xml (810 B at 17.2 KB/sec)
[INFO]
[INFO] Building GeoServer JDBC Security Module 2.4-SNAPSHOT
[INFO]
[INFO] --- git-commit-id-plugin:2.0.4:revision (default) @ sec-jdbc ---
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] build.build.time = 09.04.2013 @ 09:58:43 UTC
[INFO]
[INFO] --- maven-resources-plugin:2.5:resources (default-resources) @ sec-jdbc ---
[debug] execute contextualize
[INFO] Copying 8 resources
[INFO] Copying 10 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:compile (default-compile) @ sec-jdbc ---
[INFO] Nothing to compile - all classes are up to date
[INFO]
[INFO] --- maven-resources-plugin:2.5:testResources (default-testResources) @ sec-jdbc ---
[INFO] Copying 0 resource
[INFO] Copying 4 resources
[INFO]
[INFO] --- maven-compiler-plugin:2.3.2:testCompile (default-testCompile) @ sec-jdbc ---
[INFO]
[INFO] --- maven-surefire-plugin:2.12.3:test (default-test) @ sec-jdbc ---
[INFO] Tests are skipped.
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:jar (default-jar) @ sec-jdbc ---
[INFO]
[INFO] --- maven-jar-plugin:2.3.2:test-jar (default) @ sec-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc >>>
[INFO]
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:jar (attach-sources) @ sec-jdbc ---
[INFO]
[INFO] >>> maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc >>>
[INFO]
[INFO] [GitCommitIdMojo] build.build.time = 09.04.2013 @ 09:58:44 UTC
[INFO]
[INFO] <<< maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc <<<
[INFO]
[INFO] --- maven-source-plugin:2.2.1:test-jar (attach-sources) @ sec-jdbc ---
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO]
[INFO] --- maven-install-plugin:2.3.1:install (default-install) @ sec-jdbc ---
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/sec-jdbc-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/sec-jdbc-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/sec-jdbc-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/sec-jdbc-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/security/jdbc/target/sec-jdbc-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/sec-jdbc-2.4-SNAPSHOT-test-sources.jar
[INFO]
[INFO] --- maven-deploy-plugin:2.7:deploy (default-deploy) @ sec-jdbc ---
Downloading: dav:http://repo.opengeo.org/org/geoserver/security/sec-jdbc/2.4-SNAPSHOT/maven-metadata.xml
[WARNING] Could not transfer metadata org.geoserver.security:sec-jdbc:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... SUCCESS [25.139s]
[INFO] Core Platform Module .............................. SUCCESS [2.652s]
[INFO] Open Web Service Module ........................... SUCCESS [5.146s]
[INFO] Main Module ....................................... SUCCESS [24.730s]
[INFO] Web Feature Service Module ........................ SUCCESS [8.340s]
[INFO] Web Coverage Service Module ....................... SUCCESS [1.202s]
[INFO] Web Map Service Module ............................ SUCCESS [9.152s]
[INFO] GeoServer Web Modules ............................. SUCCESS [0.687s]
[INFO] Core UI Module .................................... SUCCESS [5.506s]
[INFO] Security UI Module ................................ SUCCESS [2.564s]
[INFO] GeoServer Security Modules ........................ SUCCESS [0.902s]
[INFO] GeoServer JDBC Security Module .................... FAILURE [31.518s]
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] Printing Module ................................... SKIPPED
[INFO] HTTP Proxy Extension .............................. SKIPPED
[INFO] GeoServer Embedded FTP server ..................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] Application Schema Support ........................ SKIPPED
[INFO] Sample DataAccess Integration Test ................ SKIPPED
[INFO] ArcSDE DataStore Extension ........................ SKIPPED
[INFO] H2 DataStore Extension ............................ SKIPPED
[INFO] SQL Server DataStore Extension .................... SKIPPED
[INFO] Oracle DataStore Extension ........................ SKIPPED
[INFO] MySQL DataStore Extension ......................... SKIPPED
[INFO] DB2 DataStore Extension ........................... SKIPPED
[INFO] ImageI/O-Ext GDAL Coverage Extension .............. SKIPPED
[INFO] JP2K Coverage Extension ........................... SKIPPED
[INFO] ogr2ogr Output Format ............................. SKIPPED
[INFO] Excel Output Format ............................... SKIPPED
[INFO] Validation Module ................................. SKIPPED
[INFO] Chart external graphics support ................... SKIPPED
[INFO] Feature Generalization Extension .................. SKIPPED
[INFO] Image Mosaic JDBC Extension ....................... SKIPPED
[INFO] OWS request flow controller ....................... SKIPPED
[INFO] Web Processing Service parent ..................... SKIPPED
[INFO] GeoServer Layer Querying filter functions ......... SKIPPED
[INFO] Teradata DataStore Extension ...................... SKIPPED
[INFO] GeoServer Monitor Extensions ...................... SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 2:00.955s
[INFO] Finished at: Tue Apr 09 09:59:14 UTC 2013
[INFO] Final Memory: 31M/238M
[WARNING] The requested profile "monitoring" could not be activated because it does not exist.
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project sec-jdbc: Failed to retrieve remote metadata org.geoserver.security:sec-jdbc:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.security:sec-jdbc:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal org.apache.maven.plugins:maven-deploy-plugin:2.7:deploy (default-deploy) on project sec-jdbc: Failed to retrieve remote metadata org.geoserver.security:sec-jdbc:2.4-SNAPSHOT/maven-metadata.xml: Could not transfer metadata org.geoserver.security:sec-jdbc:2.4-SNAPSHOT/maven-metadata.xml from/to opengeo (dav:http://repo.opengeo.org): Failed to transfer file: http://repo.opengeo.org/org/geoserver/security/sec\-jdbc/2\.4\-SNAPSHOT/maven\-metadata\.xml\. Return code is: 0: Unknown host repo.opengeo.org -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/MojoExecutionException
[ERROR]
[ERROR] mvn <goals> -rf :sec-jdbc
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
