[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-deploy #3610
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3610/&gt;
Started by upstream project "geoserver-master" build number 6217
[src] $ /opt/apache-maven-2.2.1/bin/mvn -f pom.xml -U -Djava.awt.headless=true -DskipTests -P allExtensions,proxy,printing,ftp,monitoring deploy -DconfigDirectory=../../../data
[INFO] Scanning for projects...
[WARNING]
  Profile with id: 'monitoring' has not been activated.
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] Community Space
[INFO] Printing Module
[INFO] HTTP Proxy Extension
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Web Application
[INFO] GeoServer Extensions
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] H2 DataStore Extension
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] Building GeoServer
[INFO] task-segment: [deploy]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '/var/lib/hudson/jobs/geoserver-master/workspace/.git' repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = JDBCConfig improvments, closes #257.
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 31.07.2013 @ 13:46:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 31-Jul-2013 16:00
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2013 @ 16:00:57 UTC
[INFO] [GitCommitIdMojo] build.branch = 6ecc9321f13470cd8be97ed44544f35506da13db
[INFO] [GitCommitIdMojo] build.commit.user.email = ksmith@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Kevin Smith
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 6ecc932
[INFO] [GitCommitIdMojo] build.commit.id = 6ecc9321f13470cd8be97ed44544f35506da13db
[INFO] [GitCommitIdMojo] build.commit.message.full = JDBCConfig improvments, closes #257.
- support for jndi
- support for multiple sort by elements in catalog facade
- tidied up some warnings
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from opengeo
[WARNING] repository metadata for: 'snapshot org.geotools:gt-api:10-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Error transferring file: repo.opengeo.org
[INFO] Repository 'opengeo' will be blacklisted
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-referencing:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-referencing:10-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-metadata:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-metadata:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-metadata:10-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-opengis:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-opengis:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-opengis:10-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:gt-main:10-SNAPSHOT: checking for updates from osgeo
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] build.build.time = 31.07.2013 @ 16:01:46 UTC
- support for jndi
- support for jndi
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.4-SNAPSHOT/geoserver-2.4-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/ws/target/geoserver-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/geoserver/2.4-SNAPSHOT/geoserver-2.4-SNAPSHOT-tests.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
WAGON_VERSION: 1.0-beta-2
[ERROR] BUILD ERROR
[INFO] Error retrieving previous build number for artifact 'org.geoserver:geoserver:pom': repository metadata for: 'snapshot org.geoserver:geoserver:2.4-SNAPSHOT' could not be retrieved from repository: opengeo due to an error: Failed to transfer file: http://repo.opengeo.org/org/geoserver/geoserver/2.4-SNAPSHOT/maven-metadata.xml. Return code is: 0
[INFO] Total time: 58 seconds
[INFO] Finished at: Wed Jul 31 16:01:48 UTC 2013
[INFO] Final Memory: 47M/352M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-deploy/3611/&gt;
