See <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/433/>
[...truncated 204 lines...]
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-project-info-reports-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1368, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-surefire-report-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1373, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-jxr-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1381, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:taglist-maven-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1389, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:cobertura-maven-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1403, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-app:jar:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-resources-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1126, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-war-plugin is missing. @ line 261, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1225, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-source-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1253, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-site-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1307, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-javadoc-plugin is missing. @ org.geoserver:geoserver:2.4-SNAPSHOT, <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/pom.xml,> line 1312, column 12
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-demo:jar:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-wms:jar:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-wfs:jar:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-wcs:jar:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-gwc:jar:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver.web:web-security:jar:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 65, column 13
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:web:pom:2.4-SNAPSHOT
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:community:pom:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 53, column 10
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:extension:pom:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 32, column 10
[WARNING]
[WARNING] Some problems were encountered while building the effective model for org.geoserver:geoserver:pom:2.4-SNAPSHOT
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-resources-plugin is missing. @ line 1126, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-source-plugin is missing. @ line 1253, column 12
[WARNING] 'build.plugins.plugin.version' for org.apache.maven.plugins:maven-jar-plugin is missing. @ line 1225, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-site-plugin is missing. @ line 1307, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-javadoc-plugin is missing. @ line 1312, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-project-info-reports-plugin is missing. @ line 1368, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-surefire-report-plugin is missing. @ line 1373, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.apache.maven.plugins:maven-jxr-plugin is missing. @ line 1381, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:taglist-maven-plugin is missing. @ line 1389, column 12
[WARNING] 'reporting.plugins.plugin.version' for org.codehaus.mojo:cobertura-maven-plugin is missing. @ line 1403, column 12
[WARNING]
[WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
[WARNING]
[WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
[WARNING]
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Map Service KML output formats
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-resources-plugin/maven-metadata.xml (686 B at 1.0 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-jar-plugin/maven-metadata.xml (588 B at 22.1 KB/sec)
Downloading: http://snapshots.repository.codehaus.org/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloading: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml
Downloaded: http://repo.maven.apache.org/maven2/org/apache/maven/plugins/maven-source-plugin/maven-metadata.xml (692 B at 52.0 KB/sec)
[INFO]
[INFO] Building GeoServer 2.4-SNAPSHOT
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-api/10-SNAPSHOT/maven-metadata.xml (974 B at 1.7 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/library/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/10-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/library/10-SNAPSHOT/maven-metadata.xml (592 B at 1.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/maven-metadata.xml (592 B at 32.1 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/modules/10-SNAPSHOT/modules-10-20130612.055210-79.pom
Downloading: http://repo.opengeo.org/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-main/10-SNAPSHOT/maven-metadata.xml (2 KB at 28.2 KB/sec)
[INFO] Reactor Summary:
[INFO]
[INFO] GeoServer ......................................... FAILURE [1.815s]
[INFO] Core Platform Module .............................. SKIPPED
[INFO] Open Web Service Module ........................... SKIPPED
[INFO] Main Module ....................................... SKIPPED
[INFO] Web Feature Service Module ........................ SKIPPED
[INFO] Web Coverage Service Module ....................... SKIPPED
[INFO] Web Map Service Module ............................ SKIPPED
[INFO] GeoServer Web Modules ............................. SKIPPED
[INFO] Core UI Module .................................... SKIPPED
[INFO] Security UI Module ................................ SKIPPED
[INFO] GeoServer Security Modules ........................ SKIPPED
[INFO] GeoServer JDBC Security Module .................... SKIPPED
[INFO] GeoServer LDAP Security Module .................... SKIPPED
[INFO] Web Coverage Service 1.0 Module ................... SKIPPED
[INFO] Web Coverage Service 1.1 Module ................... SKIPPED
[INFO] Web Map Service KML output formats ................ SKIPPED
[INFO] REST Support Module ............................... SKIPPED
[INFO] WFS UI Module ..................................... SKIPPED
[INFO] Community Space ................................... SKIPPED
[INFO] GeoServer Extensions .............................. SKIPPED
[INFO] BUILD FAILURE
[INFO] Total time: 5.666s
[INFO] Finished at: Thu Jun 13 04:01:03 UTC 2013
[INFO] Final Memory: 13M/107M
[INFO] o.h.m.e.h.MavenExecutionResultHandler - Build failed with exception(s)
[INFO] o.h.m.e.h.MavenExecutionResultHandler - [1] org.apache.maven.lifecycle.LifecycleExecutionException: Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.4-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.1.RELEASE (compile), org.springframework:spring-core:jar:3.1.1.RELEASE (compile), org.springframework:spring-context:jar:3.1.1.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.1.RELEASE (compile), org.geotools:gt-api:jar:10-SNAPSHOT (compile), org.geotools:gt-main:jar:10-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]
[DEBUG] Closing connection to remote
[ERROR] Failed to execute goal on project geoserver: Could not resolve dependencies for project org.geoserver:geoserver:pom:2.4-SNAPSHOT: Failed to collect dependencies for [org.springframework:spring-beans:jar:3.1.1.RELEASE (compile), org.springframework:spring-core:jar:3.1.1.RELEASE (compile), org.springframework:spring-context:jar:3.1.1.RELEASE (compile), org.springframework:spring-webmvc:jar:3.1.1.RELEASE (compile), org.geotools:gt-api:jar:10-SNAPSHOT (compile), org.geotools:gt-main:jar:10-SNAPSHOT (compile), junit:junit:jar:4.11 (test)]: Failed to read artifact descriptor for org.geotools:gt-api:jar:10-SNAPSHOT: Could not find artifact org.geotools:modules:pom:10-20130612.055210-79 in opengeo (http://repo.opengeo.org/) -> [Help 1]
[ERROR]
[ERROR]
[ERROR] [Help 1] http://cwiki.apache.org/confluence/display/MAVEN/DependencyResolutionException
[DEBUG] Waiting for process to finish
[DEBUG] Result: 1
[FINDBUGS] Skipping publisher since build result is FAILURE
