See <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/461/>
Started by timer
[INFO] Using Maven 3 installation: maven-3.0.4
[INFO] Checking Maven 3 installation environment
[src] $ /opt/apache-maven-3.0.4/bin/mvn --help
[ERROR] Failure: java.io.IOException: Cannot run program "/opt/apache-maven-3.0.4/bin/mvn" (in directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/"\)>: java.io.IOException: error=24, Too many open files
FATAL: Cannot run program "/opt/apache-maven-3.0.4/bin/mvn" (in directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/"\)>: java.io.IOException: error=24, Too many open files
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
at hudson.Proc$LocalProc.<init>(Proc.java:192)
at hudson.Proc$LocalProc.<init>(Proc.java:164)
at hudson.Launcher$LocalLauncher.launch(Launcher.java:639)
at hudson.Launcher$ProcStarter.start(Launcher.java:274)
at org.hudsonci.maven.plugin.builder.internal.MavenInstallationValidator.validate(MavenInstallationValidator.java:296)
at org.hudsonci.maven.plugin.builder.internal.PerformBuild.doExecute(PerformBuild.java:121)
at org.hudsonci.utils.tasks.PerformOperation.execute(PerformOperation.java:58)
at org.hudsonci.maven.plugin.builder.MavenBuilder.perform(MavenBuilder.java:169)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:630)
at hudson.model.Build$RunnerImpl.build(Build.java:175)
at hudson.model.Build$RunnerImpl.doRun(Build.java:137)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:429)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: java.io.IOException: java.io.IOException: error=24, Too many open files
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
... 17 more
