See <http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/507/>
Started by timer
[INFO] Using Maven 3 installation: maven-3.0.4
[INFO] Checking Maven 3 installation environment
[src] $ /opt/apache-maven-3.0.4/bin/mvn --help
[INFO] Checking Maven 3 installation version
[INFO] Detected Maven 3 installation version: 3.0.4
[src] $ /opt/apache-maven-3.0.4/bin/mvn -U -Djava.awt.headless=true -DskipTests -P findbugs findbugs:findbugs -V -B -Dfindbugs.excludeFilterFile=<http://hudson.opengeo.org/hudson/job/geoserver-master-findbugs/ws/maven/findbugs/findbugs-excludeAll.xml> -Dmaven.ext.class.path=/var/lib/hudson/maven/slavebundle/resources:/var/lib/hudson/maven/slavebundle/lib/maven3-eventspy-3.0.jar:/var/lib/jetty/webapps/hudson/WEB-INF/lib/hudson-remoting-2.2.0.jar -Dhudson.eventspy.port=40794 -f pom.xml
[DEBUG] Waiting for connection on port: 40794
Apache Maven 3.0.4 (r1232337; 2012-01-17 08:44:56+0000)
Maven home: /opt/apache-maven-3.0.4
Java version: 1.6.0_21, vendor: Sun Microsystems Inc.
Java home: /usr/lib/jvm/java-6-sun-1.6.0.21_i586/jre
Default locale: en_US, platform encoding: UTF-8
OS name: "linux", version: "2.6.32-11-pve", arch: "i386", family: "unix"
[DEBUG] Connected to remote
[INFO] Scanning for projects...
[INFO] Reactor Build Order:
[INFO]
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] GeoServer Extensions
[INFO]
[INFO] Building GeoServer 2.5-SNAPSHOT
Downloading: http://repo.opengeo.org/org/geotools/gt-api/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-api/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-api/11-SNAPSHOT/maven-metadata.xml (306 B at 0.8 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/library/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/library/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/library/11-SNAPSHOT/maven-metadata.xml (307 B at 27.3 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/modules/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/modules/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/modules/11-SNAPSHOT/maven-metadata.xml (307 B at 42.8 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/geotools/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/geotools/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/geotools/11-SNAPSHOT/maven-metadata.xml (308 B at 3.0 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-referencing/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-referencing/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-referencing/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-referencing/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-referencing/11-SNAPSHOT/maven-metadata.xml (314 B at 43.8 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-metadata/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-metadata/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-metadata/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-metadata/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-metadata/11-SNAPSHOT/maven-metadata.xml (311 B at 38.0 KB/sec)
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-opengis/11-SNAPSHOT/maven-metadata.xml
Downloading: http://repo.opengeo.org/org/geotools/gt-opengis/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.java.net/maven/2/org/geotools/gt-opengis/11-SNAPSHOT/maven-metadata.xml
Downloading: http://maven.geo-solutions.it/org/geotools/gt-opengis/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-opengis/11-SNAPSHOT/maven-metadata.xml (310 B at 43.2 KB/sec)
Downloading: http://repo.opengeo.org/org/geotools/gt-main/11-SNAPSHOT/maven-metadata.xml
Downloading: http://download.osgeo.org/webdav/geotools/org/geotools/gt-main/11-SNAPSHOT/maven-metadata.xml
Downloaded: http://repo.opengeo.org/org/geotools/gt-main/11-SNAPSHOT/maven-metadata.xml (307 B at 42.8 KB/sec)
[INFO]
[INFO] --- findbugs-maven-plugin:2.4.0:findbugs (default-cli) @ geoserver ---
[ERROR] Failure: hudson.remoting.RequestAbortedException: hudson.remoting.RequestAbortedException: java.io.IOException: Unexpected termination of the channel
FATAL: hudson.remoting.RequestAbortedException: hudson.remoting.RequestAbortedException: java.io.IOException: Unexpected termination of the channel
org.hudsonci.utils.tasks.OperationFailure: hudson.remoting.RequestAbortedException: hudson.remoting.RequestAbortedException: java.io.IOException: Unexpected termination of the channel
at org.hudsonci.utils.tasks.PerformOperation.execute(PerformOperation.java:75)
at org.hudsonci.maven.plugin.builder.MavenBuilder.perform(MavenBuilder.java:169)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:630)
at hudson.model.Build$RunnerImpl.build(Build.java:175)
at hudson.model.Build$RunnerImpl.doRun(Build.java:137)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:429)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: hudson.remoting.RequestAbortedException: hudson.remoting.RequestAbortedException: java.io.IOException: Unexpected termination of the channel
at hudson.remoting.Request.call(Request.java:149)
at hudson.remoting.Channel.call(Channel.java:650)
at org.hudsonci.maven.plugin.builder.internal.PerformBuild.doExecute(PerformBuild.java:198)
at org.hudsonci.utils.tasks.PerformOperation.execute(PerformOperation.java:58)
... 10 more
Caused by: hudson.remoting.RequestAbortedException: java.io.IOException: Unexpected termination of the channel
at hudson.remoting.Request.abort(Request.java:269)
at hudson.remoting.Channel.terminate(Channel.java:750)
at hudson.slaves.Channels$1.terminate(Channels.java:77)
at hudson.remoting.Channel$ReaderThread.run(Channel.java:1049)
Caused by: java.io.IOException: Unexpected termination of the channel
at hudson.remoting.Channel$ReaderThread.run(Channel.java:1030)
Caused by: java.io.EOFException
at java.io.ObjectInputStream$BlockDataInputStream.peekByte(ObjectInputStream.java:2553)
at java.io.ObjectInputStream.readObject0(ObjectInputStream.java:1296)
at java.io.ObjectInputStream.readObject(ObjectInputStream.java:350)
at hudson.remoting.Channel$ReaderThread.run(Channel.java:1024)
