[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1180
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1180/&gt;
[...truncated 1326 lines...]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/rest/target/rest-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/rest/2.3-SNAPSHOT/rest-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/rest/target/rest-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/rest/2.3-SNAPSHOT/rest-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/rest/target/rest-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/rest/2.3-SNAPSHOT/rest-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/rest/target/rest-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/rest/2.3-SNAPSHOT/rest-2.3-SNAPSHOT-test-sources.jar
[INFO] Building REST Configuration Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = bb3d1d1f37f9c4aa1c84bb12a8eac67e199e50b3
[INFO] [GitCommitIdMojo] build.commit.id = bb3d1d1f37f9c4aa1c84bb12a8eac67e199e50b3
[INFO] [GitCommitIdMojo] build.commit.message.short = -GEOS-5226: CoverageAccessSettings and JAI page and global change events handling fix
[INFO] [GitCommitIdMojo] build.commit.time = 08.08.2012 @ 14:33:27 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bb3d1d1
[INFO] [GitCommitIdMojo] build.commit.message.full = -GEOS-5226: CoverageAccessSettings and JAI page and global change events handling fix
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 09-Aug-2012 05:17
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 05:19:40 UTC
[INFO] Copying 35 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/src/main/resources&gt;
[INFO] Compiling 64 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/classes&gt;
[INFO] Copying 7 resources
[INFO] Copying 1 resource
[INFO] Compiling 29 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.3-SNAPSHOT/restconfig-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.3-SNAPSHOT/restconfig-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.3-SNAPSHOT/restconfig-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/restconfig/target/restconfig-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/restconfig/2.3-SNAPSHOT/restconfig-2.3-SNAPSHOT-test-sources.jar
[INFO] Building WMS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 05:19:45 UTC
[INFO] Copying 5 resources
[INFO] Copying 15 resources
[INFO] Compiling 19 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/classes&gt;
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/src/test/resources&gt;
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/wms/target/web-wms-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-wms/2.3-SNAPSHOT/web-wms-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GWC UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 09.08.2012 @ 05:19:50 UTC
[INFO] Copying 9 resources
[INFO] Copying 21 resources
[INFO] Compiling 31 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/resources&gt;
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/target/test-classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[7,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[7,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[8,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[8,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[9,25\] package org.mockito does not exist
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[9,0\] static import only from classes and interfaces
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[42,14\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.GWC>)
location: class org.geoserver.gwc.web.layer.LayerEditCacheOptionsTabPanelInfoTest
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[46,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.config.GWCConfig)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[48,35\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.FeatureTypeInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[49,8\] cannot find symbol
symbol : method when(java.lang.String)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[51,16\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.catalog.LayerInfo>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[52,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.ResourceInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[54,8\] cannot find symbol
symbol : method when(org.geoserver.catalog.MetadataMap)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[83,39\] cannot find symbol
symbol : method mock(java.lang.Class<org.geoserver.gwc.layer.GeoServerTileLayer>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[86,8\] cannot find symbol
symbol : method when(org.geoserver.gwc.layer.GeoServerTileLayerInfo)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/gwc/src/test/java/org/geoserver/gwc/web/layer/LayerEditCacheOptionsTabPanelInfoTest.java&gt;:\[87,30\] cannot find symbol
symbol : method same(org.geoserver.catalog.LayerInfo)
[INFO] Total time: 1 minute 55 seconds
[INFO] Finished at: Thu Aug 09 05:19:54 UTC 2012
[INFO] Final Memory: 72M/387M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-08-09-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1181/&gt;
