[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1201
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1201/&gt;
[...truncated 2798 lines...]
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/2.3-SNAPSHOT/extension-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/target/extension-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/2.3-SNAPSHOT/extension-2.3-SNAPSHOT-tests.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = c05714e5f3c6234ecfba5e9e86fa21a1dadd05a0
[INFO] [GitCommitIdMojo] build.commit.id = c05714e5f3c6234ecfba5e9e86fa21a1dadd05a0
[INFO] [GitCommitIdMojo] build.commit.message.short = GSIP-69: Some fixes around handling of misconfigured layers in WMS capabilities when skip broken config is selected.
[INFO] [GitCommitIdMojo] build.commit.time = 29.08.2012 @ 17:31:40 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = c05714e
[INFO] [GitCommitIdMojo] build.commit.message.full = GSIP-69: Some fixes around handling of misconfigured layers in WMS capabilities when skip broken config is selected.
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 30-Aug-2012 03:37
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 30.08.2012 @ 03:40:18 UTC
[INFO] Copying 2 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/src/main/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/classes&gt;
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/src/test/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/h2/2.3-SNAPSHOT/h2-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/h2/2.3-SNAPSHOT/h2-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/h2/2.3-SNAPSHOT/h2-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/h2/target/h2-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/h2/2.3-SNAPSHOT/h2-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Python Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 30.08.2012 @ 03:40:21 UTC
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:9-SNAPSHOT: checking for updates from osgeo
[INFO] [antrun:run {execution: generate-sources}]
[INFO] Executing tasks
checkout:
     [echo] Pulling master from git://github.com/jdeolive/geoscript-py.git (ignore fatal warning)
     [exec] fatal: destination path 'geoscript' already exists and is not an empty directory.
     [exec] Result: 128
     [exec] From git://github.com/jdeolive/geoscript-py
     [exec] * branch master -> FETCH_HEAD
     [exec] Already up-to-date.
     [exec] Already on 'master'
     [exec] Your branch is ahead of 'origin/master' by 18 commits.
[INFO] Executed tasks
[INFO] [antrun:run {execution: generate-resources}]
[INFO] Copying 4 resources
[INFO] Copying 98 resources
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-tests.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-sources.jar&gt;
checkout:
     [exec] Result: 128
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/python/2.3-SNAPSHOT/python-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/python/2.3-SNAPSHOT/python-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/python/2.3-SNAPSHOT/python-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/python/target/python-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/python/2.3-SNAPSHOT/python-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Hibernate Catalog/Configuration Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dbconfig/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 30.08.2012 @ 03:40:28 UTC
[INFO] Copying 6 resources
[INFO] Compiling 23 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dbconfig/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dbconfig/src/main/java/org/geoserver/catalog/hib/HibCatalogFacade.java&gt;:\[35,7\] org.geoserver.catalog.hib.HibCatalogFacade is not abstract and does not override abstract method <T>list(java.lang.Class<T>,org.opengis.filter.Filter,java.lang.Integer,java.lang.Integer,org.opengis.filter.sort.SortBy) in org.geoserver.catalog.CatalogFacade
[INFO] Total time: 3 minutes 20 seconds
[INFO] Finished at: Thu Aug 30 03:40:30 UTC 2012
[INFO] Final Memory: 89M/376M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-08-30-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1202/&gt;
[...truncated 3455 lines...]
[INFO] [GitCommitIdMojo] build.branch = 7442a72e20e2e7a95012109794c643886245e619
[INFO] [GitCommitIdMojo] build.commit.id = 7442a72e20e2e7a95012109794c643886245e619
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5292: fixing sldService
[INFO] [GitCommitIdMojo] build.commit.time = 31.08.2012 @ 16:20:50 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 7442a72
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5292: fixing sldService
[INFO] [GitCommitIdMojo] build.commit.user.email = daniele.romagnoli@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Daniele Romagnoli
[INFO] [GitCommitIdMojo] build.timestamp = 02-Sep-2012 03:37
[INFO] [GitCommitIdMojo] build.build.time = 02.09.2012 @ 03:40:57 UTC
[INFO] [GitCommitIdMojo] build.build.time = 02.09.2012 @ 03:40:59 UTC
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 02.09.2012 @ 03:41:08 UTC
[INFO] Total time: 3 minutes 37 seconds
[INFO] Finished at: Sun Sep 02 03:41:10 UTC 2012
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-02-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1203/&gt;
[...truncated 2775 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 03-Sep-2012 03:37
[INFO] [GitCommitIdMojo] build.build.time = 03.09.2012 @ 03:41:01 UTC
[INFO] [GitCommitIdMojo] build.build.time = 03.09.2012 @ 03:41:03 UTC
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 03.09.2012 @ 03:41:12 UTC
[INFO] Total time: 3 minutes 38 seconds
[INFO] Finished at: Mon Sep 03 03:41:14 UTC 2012
[INFO] Final Memory: 90M/415M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-03-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1204/&gt;
[...truncated 2364 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/target/extension-2.3-SNAPSHOT-tests.jar&gt;
[INFO] [GitCommitIdMojo] build.branch = 2f47b8d53f202a1c0f2856b26a2cc22283da02ef
[INFO] [GitCommitIdMojo] build.commit.id = 2f47b8d53f202a1c0f2856b26a2cc22283da02ef
[INFO] [GitCommitIdMojo] build.commit.message.short = Support three-dimensional Envelopes and Bounding Box filters GEOS-5148 Online Test Bug Fix
[INFO] [GitCommitIdMojo] build.commit.time = 04.09.2012 @ 01:28:48 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2f47b8d
[INFO] [GitCommitIdMojo] build.commit.message.full = Support three-dimensional Envelopes and Bounding Box filters GEOS-5148 Online Test Bug Fix
[INFO] [GitCommitIdMojo] build.commit.user.email = niels@anonymised.com(none)
[INFO] [GitCommitIdMojo] build.commit.user.name = Niels
[INFO] [GitCommitIdMojo] build.timestamp = 04-Sep-2012 04:16
[INFO] [GitCommitIdMojo] build.build.time = 04.09.2012 @ 04:19:31 UTC
[INFO] [GitCommitIdMojo] build.build.time = 04.09.2012 @ 04:19:34 UTC
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 04.09.2012 @ 04:19:42 UTC
[INFO] Total time: 3 minutes 16 seconds
[INFO] Finished at: Tue Sep 04 04:19:44 UTC 2012
[INFO] Final Memory: 88M/373M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-04-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1205/&gt;
[...truncated 3024 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 05-Sep-2012 03:37
[INFO] [GitCommitIdMojo] build.build.time = 05.09.2012 @ 03:41:01 UTC
[INFO] [GitCommitIdMojo] build.build.time = 05.09.2012 @ 03:41:04 UTC
Downloading: http://repo.opengeo.org//org/geotools/gt-process/9-SNAPSHOT/gt-process-9-20120905.023835-131.pom
4/5K
5/5K
5K downloaded (gt-process-9-20120905.023835-131.pom)
Downloading: http://repo.opengeo.org//org/geotools/gt-process/9-SNAPSHOT/gt-process-9-20120905.023835-131.jar
4/52K
8/52K
12/52K
16/52K
20/52K
24/52K
28/52K
32/52K
36/52K
40/52K
44/52K
48/52K
52/52K
52/52K
52K downloaded (gt-process-9-20120905.023835-131.jar)
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 05.09.2012 @ 03:41:13 UTC
[INFO] Total time: 3 minutes 50 seconds
[INFO] Finished at: Wed Sep 05 03:41:15 UTC 2012
[INFO] Final Memory: 90M/384M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-05-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1206/&gt;
[...truncated 2349 lines...]
[INFO] [GitCommitIdMojo] build.branch = cf172c0eae5c879e8b82b6b262f9f075423d20b6
[INFO] [GitCommitIdMojo] build.commit.id = cf172c0eae5c879e8b82b6b262f9f075423d20b6
[INFO] [GitCommitIdMojo] build.commit.message.short = Updated and sorted the PSC list (by full name, so first personal name is most significant, with LC_COLLATE=C)
[INFO] [GitCommitIdMojo] build.commit.time = 05.09.2012 @ 05:47:09 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = cf172c0
[INFO] [GitCommitIdMojo] build.commit.message.full = Updated and sorted the PSC list (by full name, so first personal name is most significant, with LC_COLLATE=C)
[INFO] [GitCommitIdMojo] build.commit.user.email = Ben.Caradoc-Davies@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Ben Caradoc-Davies
[INFO] [GitCommitIdMojo] build.timestamp = 06-Sep-2012 05:26
[INFO] [GitCommitIdMojo] build.build.time = 06.09.2012 @ 05:29:52 UTC
[INFO] [GitCommitIdMojo] build.build.time = 06.09.2012 @ 05:29:54 UTC
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 06.09.2012 @ 05:30:02 UTC
[INFO] Total time: 3 minutes 10 seconds
[INFO] Finished at: Thu Sep 06 05:30:04 UTC 2012
[INFO] Final Memory: 90M/409M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-06-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1207/&gt;
[...truncated 3034 lines...]
[INFO] [GitCommitIdMojo] build.branch = bc89592bc37f72ccb868eafcd7841f4c2d0ad373
[INFO] [GitCommitIdMojo] build.commit.id = bc89592bc37f72ccb868eafcd7841f4c2d0ad373
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding support for bbox in the record features, fixing the type and attribute builders to allow the creation of also simple attributes
[INFO] [GitCommitIdMojo] build.commit.time = 06.09.2012 @ 14:35:29 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = bc89592
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding support for bbox in the record features, fixing the type and attribute builders to allow the creation of also simple attributes
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.timestamp = 07-Sep-2012 03:37
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2012 @ 03:40:58 UTC
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2012 @ 03:41:00 UTC
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 07.09.2012 @ 03:41:09 UTC
[INFO] Total time: 3 minutes 36 seconds
[INFO] Finished at: Fri Sep 07 03:41:11 UTC 2012
[INFO] Final Memory: 90M/408M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-07-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1208/&gt;
[...truncated 4787 lines...]
[INFO] [GitCommitIdMojo] build.branch = 49fae7c8b848ee90ffbe336da98be4ca1a872738
[INFO] [GitCommitIdMojo] build.commit.id = 49fae7c8b848ee90ffbe336da98be4ca1a872738
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding support for filtering and paging in the simple catalog store, sorting and attribute selection still missing
[INFO] [GitCommitIdMojo] build.commit.time = 07.09.2012 @ 17:40:35 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 49fae7c
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding support for filtering and paging in the simple catalog store, sorting and attribute selection still missing
[INFO] [GitCommitIdMojo] build.timestamp = 08-Sep-2012 03:37
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2012 @ 03:41:22 UTC
Downloading: http://repo.opengeo.org//org/geotools/gt-geojson/9-SNAPSHOT/gt-geojson-9-20120908.024843-138.pom
3/3K
3K downloaded (gt-geojson-9-20120908.024843-138.pom)
Downloading: http://repo.opengeo.org//org/geotools/gt-process/9-SNAPSHOT/gt-process-9-20120908.024652-138.pom
4/5K
5/5K
5K downloaded (gt-process-9-20120908.024652-138.pom)
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-kml/9-SNAPSHOT/gt-xsd-kml-9-20120908.024602-138.pom
3/3K
3K downloaded (gt-xsd-kml-9-20120908.024602-138.pom)
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-kml/9-SNAPSHOT/gt-xsd-kml-9-20120908.024602-138.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geojson/9-SNAPSHOT/gt-geojson-9-20120908.024843-138.jar
4/56K
8/56K
12/56K
16/56K
20/56K
24/56K
28/56K
32/56K
36/56K
40/56K
44/56K
48/56K
52/56K
56/56K
56/56K
56K downloaded (gt-geojson-9-20120908.024843-138.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-process/9-SNAPSHOT/gt-process-9-20120908.024652-138.jar
4/133K
8/133K
12/133K
16/133K
20/133K
24/133K
28/133K
32/133K
36/133K
40/133K
44/133K
48/133K
52/133K
56/133K
60/133K
64/133K
68/133K
72/133K
76/133K
80/133K
84/133K
88/133K
92/133K
96/133K
100/133K
104/133K
108/133K
112/133K
116/133K
120/133K
124/133K
128/133K
132/133K
133/133K
133K downloaded (gt-xsd-kml-9-20120908.024602-138.jar)
4/52K
8/52K
12/52K
16/52K
20/52K
24/52K
28/52K
32/52K
36/52K
40/52K
44/52K
48/52K
52/52K
52/52K
52K downloaded (gt-process-9-20120908.024652-138.jar)
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
checkout:
     [exec] Result: 128
[INFO] [GitCommitIdMojo] build.build.time = 08.09.2012 @ 03:41:32 UTC
[INFO] Total time: 3 minutes 57 seconds
[INFO] Finished at: Sat Sep 08 03:41:35 UTC 2012
[INFO] Final Memory: 91M/411M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-08-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1209/&gt;
