[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1216
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1216/&gt;
[...truncated 908 lines...]
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/2.3-SNAPSHOT/web-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/target/web-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/2.3-SNAPSHOT/web-2.3-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 10f4ef0145ddbbc664bdc954270f5a59aef9a373
[INFO] [GitCommitIdMojo] build.commit.id = 10f4ef0145ddbbc664bdc954270f5a59aef9a373
[INFO] [GitCommitIdMojo] build.commit.message.short = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.time = 15.09.2012 @ 09:40:25 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 10f4ef0
[INFO] [GitCommitIdMojo] build.commit.message.full = Fixing GEOS-5309
[INFO] [GitCommitIdMojo] build.commit.user.email = christian.mueller@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Christian Mueller
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 16-Sep-2012 03:32
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 16.09.2012 @ 03:33:59 UTC
[INFO] Copying 5 resources
[INFO] Copying 372 resources
[INFO] [antrun:run {execution: process-resources}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO] Compiling 214 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/classes&gt;
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/src/test/resources&gt;
[INFO] Compiling 55 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-core/2.3-SNAPSHOT/web-core-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-core/2.3-SNAPSHOT/web-core-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-core/2.3-SNAPSHOT/web-core-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/core/target/web-core-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-core/2.3-SNAPSHOT/web-core-2.3-SNAPSHOT-test-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 16.09.2012 @ 03:34:10 UTC
[INFO] Copying 77 resources
[INFO] Compiling 128 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/classes&gt;
[INFO] Copying 4 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/src/test/resources&gt;
[INFO] Compiling 43 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/web/security/target/web-security-2.3-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/web/web-security/2.3-SNAPSHOT/web-security-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Security Modules
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 16.09.2012 @ 03:34:17 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/target/security-2.3-SNAPSHOT-tests.jar&gt;
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/target/dependency/gt-api-9-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/target/dependency/gwc-core-1.3-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/target/security-2.3-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/security/2.3-SNAPSHOT/security-2.3-SNAPSHOT-tests.jar
[INFO] Building GeoServer CAS Security Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/cas/target&gt;
[INFO] Copying 1 resource
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/cas/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[169,20\] cacheAuthentication(org.springframework.security.core.Authentication,javax.servlet.http.HttpServletRequest) in org.geoserver.security.filter.GeoServerPreAuthenticationFilter cannot be applied to (org.springframework.security.core.Authentication)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/cas/src/main/java/org/geoserver/security/cas/GeoServerCasProxiedAuthenticationFilter.java&gt;:\[163,4\] method does not override or implement a method from a supertype
[INFO] Total time: 1 minute 34 seconds
[INFO] Finished at: Sun Sep 16 03:34:19 UTC 2012
[INFO] Final Memory: 68M/391M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-09-16-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1217/&gt;
