See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1288/>
[...truncated 762 lines...]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = e974165868e40ca719b9d52a20edde681bc87ffd
[INFO] [GitCommitIdMojo] build.commit.id = e974165868e40ca719b9d52a20edde681bc87ffd
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert filename guessing changes (GEOS-5366)
[INFO] [GitCommitIdMojo] build.commit.time = 16.11.2012 @ 14:53:14 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e974165
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert filename guessing changes (GEOS-5366)
This reverts commit f7804d6546541afe2e440610dbbc18550180ee42.
[INFO] [GitCommitIdMojo] build.commit.user.email = dwinslow@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = David Winslow
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 17-Nov-2012 04:02
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 17.11.2012 @ 04:03:04 UTC
[INFO] Copying 32 resources
[INFO] Copying 162 resources
Downloading: http://repo.opengeo.org//org/geotools/gt-data/9-SNAPSHOT/gt-data-9-20121117.033606-267.pom
3/3K
3K downloaded (gt-data-9-20121117.033606-267.pom)
Downloading: http://repo.opengeo.org//org/geotools/plugin/9-SNAPSHOT/plugin-9-20121117.033423-267.pom
2/2K
2K downloaded (plugin-9-20121117.033423-267.pom)
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/9-SNAPSHOT/gt-geotiff-9-20121117.033657-267.pom
4/4K
4/4K
4K downloaded (gt-geotiff-9-20121117.033657-267.pom)
Downloading: http://repo.opengeo.org//org/geotools/gt-image/9-SNAPSHOT/gt-image-9-20121117.034103-266.pom
4/4K
4/4K
4K downloaded (gt-image-9-20121117.034103-266.pom)
Downloading: http://repo.opengeo.org//org/geotools/gt-imagemosaic/9-SNAPSHOT/gt-imagemosaic-9-20121117.034136-266.pom
4/7K
7/7K
7K downloaded (gt-imagemosaic-9-20121117.034136-266.pom)
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-h2/9-SNAPSHOT/gt-jdbc-h2-9-20121117.034111-266.pom
2/2K
2K downloaded (gt-jdbc-h2-9-20121117.034111-266.pom)
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc/9-SNAPSHOT/gt-jdbc-9-20121117.034105-266.pom
4/4K
4/4K
4K downloaded (gt-jdbc-9-20121117.034105-266.pom)
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wfs/9-SNAPSHOT/net.opengis.wfs-9-20121117.033759-267.pom
1/1K
1K downloaded (net.opengis.wfs-9-20121117.033759-267.pom)
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.fes/9-SNAPSHOT/net.opengis.fes-9-20121117.033743-267.pom
1/1K
1K downloaded (net.opengis.fes-9-20121117.033743-267.pom)
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-h2/9-SNAPSHOT/gt-jdbc-h2-9-20121117.034111-266.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-data/9-SNAPSHOT/gt-data-9-20121117.033606-267.jar
4/26K
8/26K
12/26K
16/26K
20/26K
24/26K
26/26K
26K downloaded (gt-jdbc-h2-9-20121117.034111-266.jar)
4/69K
8/69K
12/69K
16/69K
20/69K
24/69K
28/69K
32/69K
36/69K
40/69K
44/69K
48/69K
52/69K
56/69K
60/69K
64/69K
68/69K
69/69K
69K downloaded (gt-data-9-20121117.033606-267.jar)
Downloading: http://repo.opengeo.org//org/geotools/gt-imagemosaic/9-SNAPSHOT/gt-imagemosaic-9-20121117.034136-266.jar
4/210K
8/210K
12/210K
16/210K
20/210K
24/210K
28/210K
32/210K
36/210K
40/210K
44/210K
48/210K
52/210K
56/210K
60/210K
64/210K
68/210K
72/210K
76/210K
80/210K
84/210K
88/210K
92/210K
96/210K
100/210K
104/210K
108/210K
112/210K
116/210K
120/210K
124/210K
128/210K
132/210K
136/210K
140/210K
144/210K
148/210K
152/210K
156/210K
160/210K
164/210K
168/210K
172/210K
176/210K
180/210K
184/210K
188/210K
192/210K
196/210K
200/210K
204/210K
208/210K
210/210K
210K downloaded (gt-imagemosaic-9-20121117.034136-266.jar)
[INFO] Compiling 539 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[86,68\] cannot find symbol
symbol : method close(java.util.Iterator)
location: interface org.geotools.feature.FeatureCollection
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[90,73\] cannot find symbol
symbol : method iterator()
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[100,77\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[120,25\] cannot find symbol
symbol : method removeAll(java.util.Collection)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[131,25\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[143,30\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/CompositeFeatureCollection.java>:\[147,15\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/RetypingFeatureCollection.java>:\[44,44\] cannot find symbol
location: interface org.geotools.data.simple.SimpleFeatureCollection
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/RetypingFeatureCollection.java>:\[49,16\] cannot find symbol
symbol : method close(java.util.Iterator<org.opengis.feature.simple.SimpleFeature>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java>:\[136,48\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java>:\[141,20\] cannot find symbol
symbol : method close(org.geotools.data.simple.SimpleFeatureIterator)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/feature/ReprojectingFeatureCollection.java>:\[149,20\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[52,56\] cannot find symbol
location: interface org.geotools.feature.FeatureCollection<T,F>
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[80,20\] cannot find symbol
symbol : method close(org.geotools.feature.FeatureIterator)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[82,20\] cannot find symbol
symbol : method close(org.geotools.feature.FeatureIterator<F>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[77,4\] method does not override or implement a method from a supertype
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[88,20\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[90,20\] cannot find symbol
symbol : method close(java.util.Iterator<F>)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[85,4\] method does not override or implement a method from a supertype
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[105,35\] cannot find symbol
symbol : method add(F)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[160,20\] cannot find symbol
symbol : method clear()
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/SecuredFeatureCollection.java>:\[171,31\] cannot find symbol
symbol : method remove(java.lang.Object)
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/main/src/main/java/org/geoserver/security/decorators/CheckAttributesFeatureCollection.java>:\[46,4\] method does not override or implement a method from a supertype
[INFO] Total time: 1 minute 27 seconds
[INFO] Finished at: Sat Nov 17 04:03:34 UTC 2012
[INFO] Final Memory: 69M/296M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-11-17-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
