See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1323/>
[...truncated 3792 lines...]
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 49d8991
[INFO] [GitCommitIdMojo] build.commit.message.full = Improvements in interpolation handling an range subsetting
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 20-Dec-2012 03:48
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2012 @ 03:55:45 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/target/community-2.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/target/dependency/gwc-core-1.3-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/pom.xml> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.3-SNAPSHOT/community-2.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/target/community-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/2.3-SNAPSHOT/community-2.3-SNAPSHOT-tests.jar
[INFO] Building Authentication by unique url key
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = 49d899110ce534d6b42d17fc8a0135b00699aab3
[INFO] [GitCommitIdMojo] build.commit.id = 49d899110ce534d6b42d17fc8a0135b00699aab3
[INFO] [GitCommitIdMojo] build.commit.message.short = Improvements in interpolation handling an range subsetting
[INFO] [GitCommitIdMojo] build.commit.time = 18.12.2012 @ 13:43:17 UTC
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2012 @ 03:55:48 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/src/main/resources>
[INFO] Compiling 6 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/classes>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/src/test/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/dependency/gwc-core-1.3-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/authkey/target/authkey-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/authkey/2.3-SNAPSHOT/authkey-2.3-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer CSS Styling
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2012 @ 03:55:56 UTC
[INFO] Copying 16 resources
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/main/scala>
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/test/scala>
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/main/java>:\-1: info: compiling
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/main/scala>:\-1: info: compiling
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/classes> at 1355975758747
[INFO] prepare-compile in 0 s
[INFO] compile in 12 s
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/test/resources>
[INFO] [scala:testCompile {execution: scala-test-compile}]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/src/test/scala>:\-1: info: compiling
[INFO] Compiling 1 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/test-classes> at 1355975773854
[INFO] compile in 4 s
[INFO] Nothing to compile - all classes are up to date
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-9-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/dependency/gt-api-9-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.3-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/dependency/gwc-core-1.3-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/css/2.3-SNAPSHOT/css-2.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/css/2.3-SNAPSHOT/css-2.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/css/2.3-SNAPSHOT/css-2.3-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/css/target/css-2.3-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/community/css/2.3-SNAPSHOT/css-2.3-SNAPSHOT-test-sources.jar
[INFO] Building WorldWind Format Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.12.2012 @ 03:56:20 UTC
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/src/main/resources>
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java>:\[13,39\] cannot find symbol
symbol : class DefaultProcessor
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java>:\[56,14\] cannot find symbol
location: class org.geoserver.wms.worldwind.util.BilWCSUtils
<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/dds/src/main/java/org/geoserver/wms/worldwind/util/BilWCSUtils.java>:\[56,47\] cannot find symbol
[INFO] Total time: 8 minutes 7 seconds
[INFO] Finished at: Thu Dec 20 03:56:23 UTC 2012
[INFO] Final Memory: 93M/424M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2012-12-20-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
