[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1379
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1379/&gt;
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson5804237327793483582.sh
+ ver=master
+ dist=/var/www/html/geoserver/master
+ date +%Y-%m-%d
+ datestamp=2013-02-02
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=1379 -P release,communityRelease clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver:release
POM Location: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/release/pom.xml&gt;
Validation Messages:
    [0] 'dependencies.dependency.version' is missing for xerces:xercesImpl:jar
    [1] 'dependencies.dependency.version' is missing for xerces:xmlParserAPIs:jar
Reason: Failed to validate POM for project org.geoserver:release at <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/release/pom.xml&gt;
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver:release at <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/release/pom.xml&gt;
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:404)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:272)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:138)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:362)
  at org.apache.maven.cli.compat.CompatibleMain.main(CompatibleMain.java:60)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver:release at <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/release/pom.xml&gt;
  at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1077)
  at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:880)
  at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:508)
  at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:200)
  at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:604)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:487)
  at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:560)
  at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:391)
  ... 12 more
[INFO] Total time: 12 seconds
[INFO] Finished at: Sat Feb 02 05:32:18 UTC 2013
[INFO] Final Memory: 14M/108M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-02-02-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1380/&gt;
[...truncated 3558 lines...]
[INFO] Copying 0 resource
[INFO] Copying 1 resource
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/src/test/resources&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/sfs/2.4-SNAPSHOT/sfs-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/sfs/2.4-SNAPSHOT/sfs-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/sfs/2.4-SNAPSHOT/sfs-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/sfs/target/sfs-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/sfs/2.4-SNAPSHOT/sfs-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Aggregating Data Store
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.branch = a67ad986f6f2babb726cf0e368283cf917a9a36d
[INFO] [GitCommitIdMojo] build.commit.id = a67ad986f6f2babb726cf0e368283cf917a9a36d
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5375] Update JAITools dependency to 1.3.0
[INFO] [GitCommitIdMojo] build.commit.time = 02.02.2013 @ 17:08:52 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = a67ad98
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5375] Update JAITools dependency to 1.3.0
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.timestamp = 03-Feb-2013 03:53
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.build.time = 03.02.2013 @ 03:58:23 UTC
[INFO] Copying 3 resources
[INFO] Copying 2 resources
[INFO] snapshot org.geotools.unsupported:gt-feature-aggregate:10-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/src/test/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/src/test/resources&gt;
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.4-SNAPSHOT/feature-aggregate-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.4-SNAPSHOT/feature-aggregate-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.4-SNAPSHOT/feature-aggregate-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/feature-aggregate/target/feature-aggregate-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/feature-aggregate/2.4-SNAPSHOT/feature-aggregate-2.4-SNAPSHOT-test-sources.jar
[INFO] Building XLST based WFS output format
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 03.02.2013 @ 03:58:29 UTC
[INFO] Copying 5 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/src/main/resources&gt;
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/classes&gt;
[INFO] Copying 8 resources
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/dependency/gwc-core-1.4-SNAPSHOT.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.4-SNAPSHOT/xslt-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.4-SNAPSHOT/xslt-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.4-SNAPSHOT/xslt-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/xslt/target/xslt-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/xslt/2.4-SNAPSHOT/xslt-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 2.0 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 03.02.2013 @ 03:58:33 UTC
[INFO] Copying 109 resources
[INFO] Compiling 31 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/target/classes&gt;
[INFO] Copying 46 resources
[INFO] Compiling 19 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/target/test-classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/src/test/java/org/geoserver/wcs2_0/WCSTestSupport.java&gt;:\[27,28\] package org.apache.xerces.dom does not exist
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/src/test/java/org/geoserver/wcs2_0/WCSTestSupport.java&gt;:\[117,32\] cannot find symbol
symbol: class DOMInputImpl
                                DOMInputImpl input = new DOMInputImpl(publicId, systemId, null);
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0/src/test/java/org/geoserver/wcs2_0/WCSTestSupport.java&gt;:\[117,57\] cannot find symbol
[INFO] 3 errors
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 5 minutes 39 seconds
[INFO] Finished at: Sun Feb 03 03:58:40 UTC 2013
[INFO] Final Memory: 121M/457M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-02-03-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1381/&gt;
[...truncated 3489 lines...]
[INFO] [GitCommitIdMojo] build.branch = 24b7d38c6e554b17553094580a7564c5a83ec091
[INFO] [GitCommitIdMojo] build.commit.id = 24b7d38c6e554b17553094580a7564c5a83ec091
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #136 from simboss/upstream-master
[INFO] [GitCommitIdMojo] build.commit.time = 03.02.2013 @ 18:57:24 UTC
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 24b7d38
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #136 from simboss/upstream-master
GEOS-5630 fixing custom dimensions management
[INFO] [GitCommitIdMojo] build.commit.user.email = simone.giannecchini@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Simone Giannecchini
[INFO] [GitCommitIdMojo] build.timestamp = 04-Feb-2013 03:56
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 04:02:57 UTC
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 04:03:01 UTC
[INFO] [GitCommitIdMojo] build.build.time = 04.02.2013 @ 04:03:06 UTC
[INFO] 3 errors
[INFO] Total time: 6 minutes 14 seconds
[INFO] Finished at: Mon Feb 04 04:03:12 UTC 2013
[INFO] Final Memory: 121M/450M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-02-04-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1382/&gt;
