See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1422/>
[...truncated 1943 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-ldap/2.4-SNAPSHOT/sec-ldap-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-ldap/2.4-SNAPSHOT/sec-ldap-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-ldap/2.4-SNAPSHOT/sec-ldap-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/security/ldap/target/sec-ldap-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/security/sec-ldap/2.4-SNAPSHOT/sec-ldap-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 1.0 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding placemark decorator for time
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 19.03.2013 @ 18:43:01 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Mar-2013 03:48
[INFO] [GitCommitIdMojo] build.build.time = 20.03.2013 @ 03:51:15 UTC
[INFO] [GitCommitIdMojo] build.branch = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 4739d7c
[INFO] [GitCommitIdMojo] build.commit.id = 4739d7cb44ddad5a09516f1875cf4e25b6ce454e
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding placemark decorator for time
[INFO] Copying 8 resources
[INFO] Copying 7 resources
[INFO] snapshot org.geotools.ogc:net.opengis.wcs:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wcs:10-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 21 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/classes>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/src/test/resources>
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.03.2013 @ 03:51:26 UTC
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset"> does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt> . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java"> does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj>
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj> . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] Compiling 56 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/classes>
[INFO] Copying 2 resources
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar>
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service KML output formats
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target>
[INFO] [GitCommitIdMojo] build.build.time = 20.03.2013 @ 03:51:32 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/src/main/resources>
[INFO] Compiling 29 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/classes>
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/src/main/java/org/geoserver/kml/KMLMapTransformer.java>:\[985,36\] cannot find symbol
symbol : class FeatureTimeTemplate
location: class org.geoserver.kml.KMLMapTransformer.KMLMapTranslatorSupport
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 2 minutes 52 seconds
[INFO] Finished at: Wed Mar 20 03:51:34 UTC 2013
[INFO] Final Memory: 81M/428M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-03-20-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
