See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1474/>
[...truncated 1355 lines...]
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-test-sources.jar>
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_0/target/wcs1_0-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_0/2.4-SNAPSHOT/wcs1_0-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target>
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = GEOS-5803, using proper name for storage parameter
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 09.05.2013 @ 15:57:51 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 10-May-2013 03:41
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 03:43:10 UTC
[INFO] [GitCommitIdMojo] build.branch = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = eb78a0b
[INFO] [GitCommitIdMojo] build.commit.id = eb78a0bff82fea38108565580318edc0103498e2
[INFO] [GitCommitIdMojo] build.commit.message.full = GEOS-5803, using proper name for storage parameter
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset"> does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt> . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java"> does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java"> does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj>
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj> . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] Compiling 56 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/classes>
[INFO] Copying 2 resources
[INFO] Compiling 15 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/test-classes>
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset> are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/generated-sources/jjtree> are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/wcs1_1/target/wcs1_1-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/wcs1_1/2.4-SNAPSHOT/wcs1_1-2.4-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service KML output formats
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target>
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 03:43:15 UTC
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/src/main/resources>
[INFO] Compiling 30 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/classes>
[INFO] Copying 14 resources
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/test-classes>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-test-sources.jar>
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.4-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/dependency/gwc-core-1.4-SNAPSHOT.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT.jar> to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-tests.jar> to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/kml/target/kml-2.4-SNAPSHOT-test-sources.jar> to /usr/share/jetty/.m2/repository/org/geoserver/kml/2.4-SNAPSHOT/kml-2.4-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/gwc/target>
[INFO] [GitCommitIdMojo] build.build.time = 10.05.2013 @ 03:43:21 UTC
[INFO] Copying 0 resource
[INFO] Copying 13 resources
[INFO] Compiling 36 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/gwc/target/classes>
[WARNING] COMPILATION WARNING :
[WARNING] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/ConfigurableQuotaStoreProvider.java>:\[24,33\] sun.reflect.generics.scope.DummyScope is Sun proprietary API and may be removed in a future release
[INFO] 1 warning
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[75,7\] org.geoserver.gwc.layer.GeoServerTileLayer is not abstract and does not override abstract method getInfoMimeTypes() in org.geowebcache.layer.TileLayer
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 2 minutes 4 seconds
[INFO] Finished at: Fri May 10 03:43:24 UTC 2013
[INFO] Final Memory: 83M/434M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-05-10-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
