[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1508
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1508/&gt;
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson3081503236947171601.sh
FATAL: command execution failed
java.io.IOException: Cannot run program "/bin/sh" (in directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/&quot;\)>: java.io.IOException: error=24, Too many open files
  at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
  at hudson.Proc$LocalProc.<init>(Proc.java:192)
  at hudson.Proc$LocalProc.<init>(Proc.java:164)
  at hudson.Launcher$LocalLauncher.launch(Launcher.java:639)
  at hudson.Launcher$ProcStarter.start(Launcher.java:274)
  at hudson.Launcher$ProcStarter.join(Launcher.java:281)
  at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:84)
  at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:60)
  at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
  at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:630)
  at hudson.model.Build$RunnerImpl.build(Build.java:175)
  at hudson.model.Build$RunnerImpl.doRun(Build.java:137)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:429)
  at hudson.model.Run.run(Run.java:1366)
  at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
  at hudson.model.ResourceController.execute(ResourceController.java:88)
  at hudson.model.Executor.run(Executor.java:145)
Caused by: java.io.IOException: java.io.IOException: error=24, Too many open files
  at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
  at java.lang.ProcessImpl.start(ProcessImpl.java:65)
  at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
  ... 16 more
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1509/&gt;
[...truncated 2808 lines...]
[INFO] Excluding org.restlet:org.restlet.ext.spring:jar:1.0.8 from the shaded jar.
[INFO] Excluding com.noelios.restlet:com.noelios.restlet.ext.servlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding com.noelios.restlet:com.noelios.restlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding org.codehaus.jettison:jettison:jar:1.0.1 from the shaded jar.
[INFO] Excluding stax:stax-api:jar:1.0.1 from the shaded jar.
[INFO] Excluding org.geoserver:wfs:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.ogc:net.opengis.wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.ogc:net.opengis.fes:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-fes:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoserver:wms:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoserver:wcs:jar:2.4-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-arcgrid:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-arcgrid:jar:1.1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-gtopo30:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-svg:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-transcoder:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-awt-util:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-util:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-bridge:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-anim:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-dom:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-css:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-ext:jar:1.7 from the shaded jar.
[INFO] Excluding xml-apis:xml-apis-ext:jar:1.3.04 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-xml:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-parser:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-svg-dom:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-gvt:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-script:jar:1.7 from the shaded jar.
[INFO] Excluding org.apache.xmlgraphics:batik-svggen:jar:1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-wfs:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-process:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding com.lowagie:itext:jar:2.1.5 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-raster:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.jaitools:jt-rangelookup:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.jaitools:jt-contour:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.jaitools:jt-attributeop:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.jaitools:jt-vectorize:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-feature:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-grid:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geoscript:geoscript-js:jar:1.0.0 from the shaded jar.
[INFO] Excluding org.mozilla:rhino:jar:1.7R4 from the shaded jar.
[INFO] Excluding jline:jline:jar:0.9.94 from the shaded jar.
[INFO] Excluding org.geotools:gt-process-geometry:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-mysql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding mysql:mysql-connector-java:jar:5.1.17 from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-spatialite:jar:9.0 from the shaded jar.
[INFO] Excluding org.xerial:sqlite-jdbc-spatialite:jar:3.7.2-2.4 from the shaded jar.
[INFO] Excluding org.geotools:gt-swing:jar:9.0 from the shaded jar.
[INFO] Excluding com.miglayout:miglayout:jar:swing:3.7 from the shaded jar.
[INFO] Attaching shaded artifact.
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/js/target/script-js-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-test-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/js/target/shaded-artifact-2.4-SNAPSHOT-remoteconsole.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-js/2.4-SNAPSHOT/script-js-2.4-SNAPSHOT-remoteconsole.jar
[INFO] Building Groovy Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target&gt;
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = updating test to include port
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 10.06.2013 @ 23:10:11 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-Jun-2013 05:22
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2013 @ 05:26:32 UTC
[INFO] [GitCommitIdMojo] build.branch = 73eb8b997ca2e1eac227adf4d616b818f9891bd2
[INFO] [GitCommitIdMojo] build.commit.user.email = jdeolive@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = jdeolive
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 73eb8b9
[INFO] [GitCommitIdMojo] build.commit.id = 73eb8b997ca2e1eac227adf4d616b818f9891bd2
[INFO] [GitCommitIdMojo] build.commit.message.full = updating test to include port
[INFO] snapshot org.geoscript:geoscript-groovy:1.1-SNAPSHOT: checking for updates from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '497723dfeb63d3c1e77bce98adf8ef2ff8b00d8d'; remote = '670846df3814c9700e90a1fa30d28f8fec62ce0f' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '497723dfeb63d3c1e77bce98adf8ef2ff8b00d8d'; remote = '670846df3814c9700e90a1fa30d28f8fec62ce0f' - IGNORING
[INFO] snapshot org.geoscript:geoscript-groovy:1.1-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoscript/geoscript-groovy/1.1-SNAPSHOT/geoscript-groovy-1.1-SNAPSHOT.pom
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-spatialite:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:modules:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:geotools:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:geotools:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:geotools:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/geotools/9-SNAPSHOT/geotools-9-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-brewer:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-brewer:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-brewer:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:extension:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/gt-geojson/9-SNAPSHOT/gt-geojson-9-SNAPSHOT.pom
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/unsupported/9-SNAPSHOT/unsupported-9-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-swing:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-swing:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-swing:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-kml:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:xsd:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/xsd/xsd/9-SNAPSHOT/xsd-9-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-grassraster:9-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-grassraster:9-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-grassraster:9-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-imagepyramid:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagepyramid:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagepyramid:10-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geoscript/geoscript-groovy/1.1-SNAPSHOT/geoscript-groovy-1.1-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-geojson/9-SNAPSHOT/gt-geojson-9-SNAPSHOT.jar
[INFO] [groovy:generateStubs {execution: default}]
[INFO] Generated 6 Java stubs
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/src/main/resources&gt;
[INFO] Compiling 9 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/classes&gt;
[INFO] [groovy:compile {execution: default}]
[INFO] Compiled 12 Groovy classes
[INFO] [groovy:generateTestStubs {execution: default}]
[INFO] Copying 6 resources
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/test-classes&gt;
[INFO] [groovy:testCompile {execution: default}]
[INFO] Compiled 6 Groovy classes
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/dependency/gt-api-10-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.4-M20130509a.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/dependency/gwc-core-1.4-M20130509a.jar&gt;
[INFO] [antrun:run {execution: default}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.4-SNAPSHOT/script-groovy-2.4-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.4-SNAPSHOT/script-groovy-2.4-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.4-SNAPSHOT/script-groovy-2.4-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/groovy/target/script-groovy-2.4-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-groovy/2.4-SNAPSHOT/script-groovy-2.4-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer JDBC KV Catalog
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/jdbcconfig/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 12.06.2013 @ 05:26:52 UTC
[INFO] Copying 0 resource
[INFO] Copying 15 resources
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/jdbcconfig/target/classes&gt;
[ERROR] COMPILATION ERROR :
[ERROR] <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/jdbcconfig/src/main/java/org/geoserver/jdbcconfig/catalog/JDBCCatalogFacade.java&gt;:\[52,7\] org.geoserver.jdbcconfig.catalog.JDBCCatalogFacade is not abstract and does not override abstract method <T>list(java.lang.Class<T>,org.opengis.filter.Filter,java.lang.Integer,java.lang.Integer,org.opengis.filter.sort.SortBy...) in org.geoserver.catalog.CatalogFacade
[INFO] 1 error
[ERROR] BUILD FAILURE
[INFO] Compilation failure
[INFO] Total time: 4 minutes 37 seconds
[INFO] Finished at: Wed Jun 12 05:26:54 UTC 2013
[INFO] Final Memory: 124M/392M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-12-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1510/&gt;
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson2266553394691356840.sh
+ ver=master
+ dist=/var/www/html/geoserver/master
+ date +%Y-%m-%d
+ datestamp=2013-06-13
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=1510 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] Web Map Service KML output formats
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] GeoServer CSS Styling
[INFO] WorldWind Format Module
[INFO] Printing Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] GeoServer Extensions
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] Web Coverage Service 2.0 Module
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target&gt;
[INFO] [GitCommitIdMojo] build.commit.message.short = KML 2 superoverlay refactor and tests
[INFO] [GitCommitIdMojo] build.commit.time = 12.06.2013 @ 18:42:19 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 13-Jun-2013 03:40
[INFO] [GitCommitIdMojo] build.build.time = 13.06.2013 @ 03:40:25 UTC
[INFO] [GitCommitIdMojo] build.branch = 53410366a32420f26bcafb13f168129c0f867d6e
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 5341036
[INFO] [GitCommitIdMojo] build.commit.id = 53410366a32420f26bcafb13f168129c0f867d6e
[INFO] [GitCommitIdMojo] build.commit.message.full = KML 2 superoverlay refactor and tests
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-api:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:library:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:library:10-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:modules:10-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:modules:10-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/modules/10-SNAPSHOT/modules-10-20130612.055210-79.pom
[ERROR] BUILD ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geotools:library:pom:null
Reason: Cannot find parent: org.geotools:modules for project: org.geotools:library:pom:null for project org.geotools:library:pom:null
[INFO] Total time: 11 seconds
[INFO] Finished at: Thu Jun 13 03:40:27 UTC 2013
[INFO] Final Memory: 41M/359M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-13-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1511/&gt;
[...truncated 2845 lines...]
[INFO] Excluding net.sf.json-lib:json-lib:jar:jdk15:2.2.3 from the shaded jar.
[INFO] Excluding commons-beanutils:commons-beanutils:jar:1.7.0 from the shaded jar.
[INFO] Excluding net.sf.ezmorph:ezmorph:jar:1.0.6 from the shaded jar.
[INFO] Excluding commons-digester:commons-digester:jar:1.7 from the shaded jar.
[INFO] Excluding commons-fileupload:commons-fileupload:jar:1.2.1 from the shaded jar.
[INFO] Excluding commons-validator:commons-validator:jar:1.1.4 from the shaded jar.
[INFO] Excluding org.freemarker:freemarker:jar:2.3.18 from the shaded jar.
[INFO] Excluding oro:oro:jar:2.0.8 from the shaded jar.
[INFO] Excluding org.geotools:gt-cql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-validation:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-data:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-jdbc:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-property:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-epsg-hsql:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding hsqldb:hsqldb:jar:1.8.0.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-wms:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-xml:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.apache.xml:xml-commons-resolver:jar:1.2 from the shaded jar.
[INFO] Excluding org.geotools:gt-render:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-sld:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding com.thoughtworks.xstream:xstream:jar:1.4.3 from the shaded jar.
[INFO] Excluding xmlpull:xmlpull:jar:1.1.3.1 from the shaded jar.
[INFO] Excluding xpp3:xpp3_min:jar:1.1.4c from the shaded jar.
[INFO] Excluding org.geotools:gt-imagemosaic:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-h2:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.opengeo:geodb:jar:0.7-RC2 from the shaded jar.
[INFO] Excluding net.sourceforge.hatbox:hatbox:jar:1.0.b7 from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-oracle:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.jdbc:gt-jdbc-postgis:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding postgresql:postgresql:jar:8.4-701.jdbc3 from the shaded jar.
[INFO] Excluding org.geotools:gt-shapefile:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-geotiff:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding it.geosolutions.imageio-ext:imageio-ext-streams:jar:1.1.7 from the shaded jar.
[INFO] Excluding org.geotools:gt-image:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.jaitools:jt-vectorbinarize:jar:1.3.0 from the shaded jar.
[INFO] Excluding net.sf.ehcache:ehcache:jar:1.6.2 from the shaded jar.
[INFO] Excluding org.springframework.security:spring-security-web:jar:3.1.0.RELEASE from the shaded jar.
[INFO] Excluding org.springframework.security:spring-security-config:jar:3.1.0.RELEASE from the shaded jar.
[INFO] Excluding org.jasypt:jasypt:jar:1.8 from the shaded jar.
[INFO] Excluding org.bouncycastle:bcprov-jdk14:jar:1.46 from the shaded jar.
[INFO] Excluding org.restlet:org.restlet:jar:1.0.8 from the shaded jar.
[INFO] Excluding org.restlet:org.restlet.ext.freemarker:jar:1.0.8 from the shaded jar.
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
[INFO] [GitCommitIdMojo] build.commit.time = 13.06.2013 @ 13:51:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 14-Jun-2013 03:52
[INFO] [GitCommitIdMojo] build.build.time = 14.06.2013 @ 03:57:23 UTC
[INFO] [GitCommitIdMojo] build.branch = 77bdd31b0731d841b48ef8fe45331bc788e3eb41
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 77bdd31
[INFO] [GitCommitIdMojo] build.commit.id = 77bdd31b0731d841b48ef8fe45331bc788e3eb41
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5800] GeoServer won't parse relative external graphic locations in SE 1.1 styles
[INFO] [GitCommitIdMojo] build.build.time = 14.06.2013 @ 03:57:38 UTC
[INFO] 1 error
[INFO] Total time: 4 minutes 56 seconds
[INFO] Finished at: Fri Jun 14 03:57:40 UTC 2013
[INFO] Final Memory: 118M/466M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-14-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1512/&gt;
[...truncated 2871 lines...]
[INFO] Excluding xml-apis:xml-apis:jar:1.0.b2 from the shaded jar.
[INFO] Excluding commons-jxpath:commons-jxpath:jar:1.3 from the shaded jar.
[INFO] Excluding org.eclipse.xsd:xsd:jar:2.6.0 from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-gml2:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-gml3:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding xpp3:xpp3:jar:1.1.3.4.O from the shaded jar.
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #251 from Gnafu/master
[INFO] [GitCommitIdMojo] build.commit.time = 14.06.2013 @ 13:48:49 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 15-Jun-2013 03:50
[INFO] [GitCommitIdMojo] build.build.time = 15.06.2013 @ 03:54:17 UTC
[INFO] [GitCommitIdMojo] build.branch = 2ba1e7b84dd6b48b0007244edf9a72093bce8741
[INFO] [GitCommitIdMojo] build.commit.user.name = Justin Deoliveira
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 2ba1e7b
[INFO] [GitCommitIdMojo] build.commit.id = 2ba1e7b84dd6b48b0007244edf9a72093bce8741
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #251 from Gnafu/master
Typo in documentation
[INFO] [GitCommitIdMojo] build.build.time = 15.06.2013 @ 03:54:32 UTC
[INFO] 1 error
[INFO] Total time: 4 minutes 31 seconds
[INFO] Finished at: Sat Jun 15 03:54:34 UTC 2013
[INFO] Final Memory: 123M/416M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-15-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1513/&gt;
[...truncated 2879 lines...]
[INFO] [GitCommitIdMojo] build.timestamp = 16-Jun-2013 03:50
[INFO] [GitCommitIdMojo] build.build.time = 16.06.2013 @ 03:54:32 UTC
[INFO] [GitCommitIdMojo] build.build.time = 16.06.2013 @ 03:54:47 UTC
[INFO] 1 error
[INFO] Total time: 4 minutes 21 seconds
[INFO] Finished at: Sun Jun 16 03:54:49 UTC 2013
[INFO] Final Memory: 117M/466M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-16-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1514/&gt;
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5769] JDK 7 gives a preference to the pure java PNG writer even if the native one is available
[INFO] [GitCommitIdMojo] build.commit.time = 16.06.2013 @ 09:05:18 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 17-Jun-2013 03:52
[INFO] [GitCommitIdMojo] build.build.time = 17.06.2013 @ 03:57:39 UTC
[INFO] [GitCommitIdMojo] build.branch = eef6503d5727ac4e865e6e9c3663504ba172f074
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = eef6503
[INFO] [GitCommitIdMojo] build.commit.id = eef6503d5727ac4e865e6e9c3663504ba172f074
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5769] JDK 7 gives a preference to the pure java PNG writer even if the native one is available
[INFO] [GitCommitIdMojo] build.build.time = 17.06.2013 @ 03:57:57 UTC
[INFO] 1 error
[INFO] Total time: 5 minutes 18 seconds
[INFO] Finished at: Mon Jun 17 03:57:59 UTC 2013
[INFO] Final Memory: 119M/465M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-17-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1515/&gt;
[...truncated 2921 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Revert "GEOS-5844 fix nulls in SecureCatalog.list"
[INFO] [GitCommitIdMojo] build.commit.time = 17.06.2013 @ 14:39:53 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 18-Jun-2013 03:51
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2013 @ 03:55:55 UTC
[INFO] [GitCommitIdMojo] build.branch = f526fb07b4b0e88252ef19dcf11ddb07f7b660cb
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = f526fb0
[INFO] [GitCommitIdMojo] build.commit.id = f526fb07b4b0e88252ef19dcf11ddb07f7b660cb
[INFO] [GitCommitIdMojo] build.commit.message.full = Revert "GEOS-5844 fix nulls in SecureCatalog.list"
This reverts commit b076629ebce1dc4cbdfe2eff622cc361ad0ebc8d.
[INFO] [GitCommitIdMojo] build.build.time = 18.06.2013 @ 03:56:11 UTC
[INFO] 1 error
[INFO] Total time: 4 minutes 35 seconds
[INFO] Finished at: Tue Jun 18 03:56:13 UTC 2013
[INFO] Final Memory: 117M/460M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-18-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1516/&gt;
[...truncated 2854 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Clean up the kml feature access code and separate it from kmlutils, remove all kmlutils dead methods
[INFO] [GitCommitIdMojo] build.commit.time = 18.06.2013 @ 17:24:32 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Jun-2013 03:59
[INFO] [GitCommitIdMojo] build.build.time = 19.06.2013 @ 04:07:25 UTC
[INFO] [GitCommitIdMojo] build.branch = ea37dddd84c985827be62c652581ef689b9af33e
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = ea37ddd
[INFO] [GitCommitIdMojo] build.commit.id = ea37dddd84c985827be62c652581ef689b9af33e
[INFO] [GitCommitIdMojo] build.commit.message.full = Clean up the kml feature access code and separate it from kmlutils, remove all kmlutils dead methods
[INFO] [GitCommitIdMojo] build.build.time = 19.06.2013 @ 04:07:43 UTC
[INFO] 1 error
[INFO] Total time: 8 minutes 17 seconds
[INFO] Finished at: Wed Jun 19 04:07:45 UTC 2013
[INFO] Final Memory: 119M/462M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-19-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1517/&gt;
[INFO] [GitCommitIdMojo] build.timestamp = 20-Jun-2013 03:52
[INFO] [GitCommitIdMojo] build.build.time = 20.06.2013 @ 03:57:15 UTC
[INFO] [GitCommitIdMojo] build.build.time = 20.06.2013 @ 03:57:35 UTC
[INFO] 1 error
[INFO] Total time: 5 minutes 8 seconds
[INFO] Finished at: Thu Jun 20 03:57:38 UTC 2013
[INFO] Final Memory: 117M/470M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-06-20-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1518/&gt;
[...truncated 2652 lines...]
[INFO] Excluding org.jaitools:jt-zonalstats:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.jaitools:jt-utils:jar:1.3.0 from the shaded jar.
[INFO] Excluding org.geotools.xsd:gt-xsd-core:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding org.geotools:gt-graph:jar:10-SNAPSHOT from the shaded jar.
[INFO] Excluding picocontainer:picocontainer:jar:1.2 from the shaded jar.
[INFO] [GitCommitIdMojo] build.commit.message.short = Adding a WFS KML output format
[INFO] [GitCommitIdMojo] build.commit.time = 20.06.2013 @ 13:56:05 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Jun-2013 17:51
[INFO] [GitCommitIdMojo] build.build.time = 20.06.2013 @ 17:56:35 UTC
[INFO] [GitCommitIdMojo] build.branch = fa38629448ae0edc6f64916ec7c8ed48eba4feb2
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = fa38629
[INFO] [GitCommitIdMojo] build.commit.id = fa38629448ae0edc6f64916ec7c8ed48eba4feb2
[INFO] [GitCommitIdMojo] build.commit.message.full = Adding a WFS KML output format
[INFO] [GitCommitIdMojo] build.build.time = 20.06.2013 @ 17:57:16 UTC
[INFO] 1 error
[INFO] Total time: 5 minutes 54 seconds
[INFO] Finished at: Thu Jun 20 17:57:19 UTC 2013
[INFO] Final Memory: 118M/476M
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1519/&gt;
