See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1567/>
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson8314926563393851854.sh
FATAL: command execution failed
java.io.IOException: Cannot run program "/bin/sh" (in directory "<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/"\)>: java.io.IOException: error=24, Too many open files
at java.lang.ProcessBuilder.start(ProcessBuilder.java:460)
at hudson.Proc$LocalProc.<init>(Proc.java:192)
at hudson.Proc$LocalProc.<init>(Proc.java:164)
at hudson.Launcher$LocalLauncher.launch(Launcher.java:639)
at hudson.Launcher$ProcStarter.start(Launcher.java:274)
at hudson.Launcher$ProcStarter.join(Launcher.java:281)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:84)
at hudson.tasks.CommandInterpreter.perform(CommandInterpreter.java:60)
at hudson.tasks.BuildStepMonitor$1.perform(BuildStepMonitor.java:19)
at hudson.model.AbstractBuild$AbstractRunner.perform(AbstractBuild.java:630)
at hudson.model.Build$RunnerImpl.build(Build.java:175)
at hudson.model.Build$RunnerImpl.doRun(Build.java:137)
at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:429)
at hudson.model.Run.run(Run.java:1366)
at hudson.model.FreeStyleBuild.run(FreeStyleBuild.java:46)
at hudson.model.ResourceController.execute(ResourceController.java:88)
at hudson.model.Executor.run(Executor.java:145)
Caused by: java.io.IOException: java.io.IOException: error=24, Too many open files
at java.lang.UNIXProcess.<init>(UNIXProcess.java:148)
at java.lang.ProcessImpl.start(ProcessImpl.java:65)
at java.lang.ProcessBuilder.start(ProcessBuilder.java:453)
... 16 more
