See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1574/>
Started by timer
[workspace] $ /bin/sh -xe /var/cache/jetty/data/hudson539493498881629423.sh
+ ver=master
+ dist=/var/www/html/geoserver/master
+ date +%Y-%m-%d
+ datestamp=2013-08-12
+ mvn=/opt/apache-maven-2.2.1/bin/mvn
+ cd src
+ /opt/apache-maven-2.2.1/bin/mvn -DskipTests -Dbuild.hudsonId=1574 -P release,communityRelease clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Core Platform Module
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Feature Service Module
[INFO] Web Coverage Service Module
[INFO] Web Map Service Module
[INFO] GeoServer Web Modules
[INFO] Core UI Module
[INFO] Security UI Module
[INFO] GeoServer Security Modules
[INFO] GeoServer JDBC Security Module
[INFO] GeoServer LDAP Security Module
[INFO] Web Coverage Service 1.0 Module
[INFO] Web Coverage Service 1.1 Module
[INFO] KML support for GeoServer
[INFO] GeoWebCache (GWC) Module
[INFO] REST Support Module
[INFO] REST Configuration Service Module
[INFO] WMS UI Module
[INFO] GWC UI Module
[INFO] WFS UI Module
[INFO] Demoes Module
[INFO] WCS UI Module
[INFO] GeoServer Web Application
[INFO] Community Space
[INFO] Authentication by unique url key
[INFO] Catalog Services for the Web parent
[INFO] Catalog Services for the Web interfaces
[INFO] Catalog Services for the Web - Simple CatalogStore implementation
[INFO] Catalog Services for the Web core module
[INFO] WorldWind Format Module
[INFO] Printing Module
[INFO] GeoServer Embedded FTP server
[INFO] GeoServer Scripting Extensions
[INFO] Core Scripting Extension
[INFO] GeoServer Extensions
[INFO] H2 DataStore Extension
[INFO] Python Scripting Extension
[INFO] JavaScript Scripting Extension
[INFO] Groovy Scripting Extension
[INFO] GeoServer JDBC KV Catalog
[INFO] Simple Feature Service
[INFO] Aggregating Data Store
[INFO] WMS-EO
[INFO] Web Coverage Service 2.0 Module
[INFO] Web Coverage Service 2.0 Earth Observation extensions
[INFO] Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] GeoServer libjpeg-turbo Module
[INFO] GeoServer Community Release Module
[INFO] SpatiaLite Extension
[INFO] BeanShell Scripting Extension
[INFO] Ruby Scripting Extension
[INFO] Application Schema Support
[INFO] Application Schema Integration Test
[INFO] Sample DataAccess Integration Test
[INFO] ArcSDE DataStore Extension
[INFO] GeoSearch Index Module
[INFO] SQL Server DataStore Extension
[INFO] Oracle DataStore Extension
[INFO] MySQL DataStore Extension
[INFO] DB2 DataStore Extension
[INFO] ImageMap Output Format
[INFO] ImageI/O-Ext GDAL Coverage Extension
[INFO] JP2K Coverage Extension
[INFO] ogr2ogr Output Format
[INFO] Excel Output Format
[INFO] Validation Module
[INFO] Chart external graphics support
[INFO] Feature Generalization Extension
[INFO] Image Mosaic JDBC Extension
[INFO] OWS request flow controller
[INFO] Web Processing Service parent
[INFO] Web Processing Service Module
[INFO] Web Processing Service GUI
[INFO] GeoServer Layer Querying filter functions
[INFO] Teradata DataStore Extension
[INFO] GeoServer Monitor Extensions
[INFO] Core Monitor Extension
[INFO] Monitor Hibernate Extension
[INFO] GeoServer CAS Security Module
[INFO] GeoServer Security Extension Modules
[INFO] XLST based WFS output format
[INFO] GeoServer INSPIRE Extensions
[INFO] GeoServer CSS Styling
[INFO] GeoServer Release Module
[INFO] Building GeoServer
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target>
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5955] Reosurce error handling drop down choice is not internationalized
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 11.08.2013 @ 09:35:52 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 12-Aug-2013 03:54
[INFO] [GitCommitIdMojo] build.build.time = 12.08.2013 @ 03:54:14 UTC
[INFO] [GitCommitIdMojo] build.branch = 3bd1db6ac98aa4ebab111db8ee2bcdf65badc200
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 3bd1db6
[INFO] [GitCommitIdMojo] build.commit.id = 3bd1db6ac98aa4ebab111db8ee2bcdf65badc200
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5955] Reosurce error handling drop down choice is not internationalized
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] snapshot org.geowebcache:gwc-core:1.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:gwc-core:1.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geowebcache:geowebcache:1.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geowebcache:geowebcache:1.5-SNAPSHOT: checking for updates from osgeo
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/geoserver-2.4-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [GitCommitIdMojo] build.build.time = 12.08.2013 @ 03:54:18 UTC
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-10-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/dependency/gt-api-10-SNAPSHOT.jar>
[INFO] Copying gwc-core-1.5-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
[ERROR] BUILD ERROR
[INFO] Error copying artifact from /usr/share/jetty/.m2/repository/org/geowebcache/gwc-core/1.5-SNAPSHOT/gwc-core-1.5-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/target/dependency/gwc-core-1.5-SNAPSHOT.jar>
Embedded error: Disk quota exceeded
[INFO] Total time: 18 seconds
[INFO] Finished at: Mon Aug 12 03:54:19 UTC 2013
[INFO] Final Memory: 59M/393M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-08-12-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
