[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1581
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1581/&gt;
[...truncated 3665 lines...]
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0-eo/2.5-SNAPSHOT/wcs2_0-eo-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0-eo/2.5-SNAPSHOT/wcs2_0-eo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0-eo/2.5-SNAPSHOT/wcs2_0-eo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/wcs2_0-eo/target/wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/wcs2_0-eo/2.5-SNAPSHOT/wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Web Coverage Service 2.0 Earth Observation GUI extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = Updating master to be the 2.5 series
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 18.08.2013 @ 12:33:29 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 19-Aug-2013 03:52
[INFO] [GitCommitIdMojo] build.build.time = 19.08.2013 @ 03:58:16 UTC
[INFO] [GitCommitIdMojo] build.branch = 63e5faf1f2b28a0d002f4eec188bc54cd4e89504
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 63e5faf
[INFO] [GitCommitIdMojo] build.commit.id = 63e5faf1f2b28a0d002f4eec188bc54cd4e89504
[INFO] [GitCommitIdMojo] build.commit.message.full = Updating master to be the 2.5 series
[INFO] Copying 3 resources
[INFO] Copying 1 resource
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/classes&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/src/test/resources&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/web-wcs2_0-eo/2.5-SNAPSHOT/web-wcs2_0-eo-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/web-wcs2_0-eo/2.5-SNAPSHOT/web-wcs2_0-eo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/web-wcs2_0-eo/2.5-SNAPSHOT/web-wcs2_0-eo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/web-wcs2_0-eo/target/web-wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/web-wcs2_0-eo/2.5-SNAPSHOT/web-wcs2_0-eo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer libjpeg-turbo Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 19.08.2013 @ 03:58:20 UTC
[INFO] Copying 0 resource
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/classes&gt;
[INFO] Copying 2 resources
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.5-SNAPSHOT/libjpeg-turbo-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.5-SNAPSHOT/libjpeg-turbo-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.5-SNAPSHOT/libjpeg-turbo-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/libjpeg-turbo/target/libjpeg-turbo-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/community/libjpeg-turbo/2.5-SNAPSHOT/libjpeg-turbo-2.5-SNAPSHOT-test-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/release/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 19.08.2013 @ 03:58:26 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/release/src/main/resources&gt;
[INFO] snapshot org.geoserver.community:css:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:css:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/css/2.5-SNAPSHOT/css-2.5-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:css:pom:2.5-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/css/2.5-SNAPSHOT/css-2.5-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:css:pom:2.5-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/css/2.5-SNAPSHOT/css-2.5-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:css:jar:2.5-SNAPSHOT' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/css/2.5-SNAPSHOT/css-2.5-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:css:jar:2.5-SNAPSHOT' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:css:jar:2.5-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=css -Dversion=2.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=css -Dversion=2.5-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:release:jar:2.5-SNAPSHOT
    2) org.geoserver.community:css:jar:2.5-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 9 seconds
[INFO] Finished at: Mon Aug 19 03:58:28 UTC 2013
[INFO] Final Memory: 124M/482M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-08-19-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1582/&gt;
[...truncated 3423 lines...]
[INFO] [GitCommitIdMojo] build.commit.message.short = Merge pull request #299 from NielsCharlier/csw
[INFO] [GitCommitIdMojo] build.commit.time = 19.08.2013 @ 15:25:16 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 20-Aug-2013 03:58
[INFO] [GitCommitIdMojo] build.build.time = 20.08.2013 @ 04:05:55 UTC
[INFO] [GitCommitIdMojo] build.branch = e92148f736fb8b981392acb9bf52b4affbbc7472
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = e92148f
[INFO] [GitCommitIdMojo] build.commit.id = e92148f736fb8b981392acb9bf52b4affbbc7472
[INFO] [GitCommitIdMojo] build.commit.message.full = Merge pull request #299 from NielsCharlier/csw
GSIP 98: Move CSW from community to extensions
[INFO] [GitCommitIdMojo] build.build.time = 20.08.2013 @ 04:06:00 UTC
[INFO] [GitCommitIdMojo] build.build.time = 20.08.2013 @ 04:06:05 UTC
[INFO] snapshot org.geoserver.csw:csw-api:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.csw:csw-api:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:csw:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:csw:2.5-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.csw:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.csw:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.csw/11-SNAPSHOT/net.opengis.csw-11-SNAPSHOT.pom
[INFO] snapshot org.geotools.xsd:gt-xsd-csw:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-csw:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-complex:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-complex/11-SNAPSHOT/gt-complex-11-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-app-schema-resolver:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from geosolutions
[INFO] snapshot org.geoserver.csw:csw-core:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.csw:csw-core:2.5-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.csw/11-SNAPSHOT/net.opengis.csw-11-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-complex/11-SNAPSHOT/gt-complex-11-SNAPSHOT.jar
[ERROR] BUILD ERROR
Missing:
  Path to dependency:
for artifact:
[INFO] Total time: 7 minutes 18 seconds
[INFO] Finished at: Tue Aug 20 04:06:10 UTC 2013
[INFO] Final Memory: 130M/499M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-08-20-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1583/&gt;
