[Geoserver-devel] [Hudson] Build failed in Hudson: geoserver-master-nightly #1586
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1586/&gt;
[...truncated 3804 lines...]
[INFO] Copying 6 resources
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/test-classes&gt;
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [git-commit-id:revision {execution: default}]
[INFO] [GitCommitIdMojo] .git directory could not be found, skipping execution
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] [dependency:copy-dependencies {execution: copy-dependencies}]
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-bsh/2.5-SNAPSHOT/script-bsh-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-bsh/2.5-SNAPSHOT/script-bsh-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-bsh/2.5-SNAPSHOT/script-bsh-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/bsh/target/script-bsh-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-bsh/2.5-SNAPSHOT/script-bsh-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Ruby Scripting Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target&gt;
[INFO] [GitCommitIdMojo] Running on '<http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/.git’> repository...
[INFO] [GitCommitIdMojo] Initializing properties...
[INFO] [GitCommitIdMojo] Using maven project properties...
[INFO] [GitCommitIdMojo] Loading data from git repository...
[INFO] [GitCommitIdMojo] ------------------git properties loaded------------------
[INFO] [GitCommitIdMojo] build.commit.message.short = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO] [GitCommitIdMojo] build.build.user.email = Unknown
[INFO] [GitCommitIdMojo] build.hudsonId = -1
[INFO] [GitCommitIdMojo] build.commit.time = 22.08.2013 @ 16:55:56 UTC
[INFO] [GitCommitIdMojo] build.timestamp = 23-Aug-2013 03:54
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:00:24 UTC
[INFO] [GitCommitIdMojo] build.branch = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.user.email = andrea.aime@anonymised.com
[INFO] [GitCommitIdMojo] build.commit.user.name = Andrea Aime
[INFO] [GitCommitIdMojo] build.commit.id.abbrev = 404bf5d
[INFO] [GitCommitIdMojo] build.commit.id = 404bf5dacc496e8b82898322101f08e69dd5033a
[INFO] [GitCommitIdMojo] build.commit.message.full = [GEOS-5987] DescribeRecord xsi:schemaLocation lacks a / just before CSW-discovery.xsd
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/src/main/resources&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/classes&gt;
[INFO] Compiling 4 source files to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/test-classes&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-test-sources.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-rb/2.5-SNAPSHOT/script-rb-2.5-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-rb/2.5-SNAPSHOT/script-rb-2.5-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-rb/2.5-SNAPSHOT/script-rb-2.5-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/community/script/rb/target/script-rb-2.5-SNAPSHOT-test-sources.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/script/script-rb/2.5-SNAPSHOT/script-rb-2.5-SNAPSHOT-test-sources.jar
[INFO] Building Application Schema Support
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:00:28 UTC
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/target/app-schema-2.5-SNAPSHOT-tests.jar&gt;
[INFO] Copying gt-api-11-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/target/dependency/gt-api-11-SNAPSHOT.jar&gt;
[INFO] Copying gwc-core-1.5.0-beta.jar to <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/target/dependency/gwc-core-1.5.0-beta.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/pom.xml&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/app-schema/2.5-SNAPSHOT/app-schema-2.5-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/target/app-schema-2.5-SNAPSHOT-tests.jar&gt; to /usr/share/jetty/.m2/repository/org/geoserver/extension/app-schema/2.5-SNAPSHOT/app-schema-2.5-SNAPSHOT-tests.jar
[INFO] Building Application Schema Integration Test
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/app-schema-test/target&gt;
[INFO] [GitCommitIdMojo] build.build.time = 23.08.2013 @ 04:00:29 UTC
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/app-schema-test/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/ws/src/extension/app-schema/app-schema-test/src/main/resources&gt;
[INFO] snapshot org.geotools:gt-app-schema:11-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:app-schema:11-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.pom
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:pom:3.2.0-1' in repository central (http://repo1.maven.org/maven2)
[INFO] No sources to compile
[INFO] Copying 132 resources
Downloading: http://repo.opengeo.org//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://maven.restlet.org/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository maven-restlet (http://maven.restlet.org)
Downloading: http://repo1.maven.org/maven2/org/geotools/schemas/geosciml-3.2-seegrid/3.2.0-1/geosciml-3.2-seegrid-3.2.0-1.jar
[INFO] Unable to find resource 'org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1' in repository central (http://repo1.maven.org/maven2)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geotools.schemas -DartifactId=geosciml-3.2-seegrid -Dversion=3.2.0-1 -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geotools.schemas -DartifactId=geosciml-3.2-seegrid -Dversion=3.2.0-1 -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.extension:app-schema-test:jar:2.5-SNAPSHOT
    2) org.geotools.schemas:geosciml-3.2-seegrid:jar:3.2.0-1
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org),
[INFO] Total time: 6 minutes 5 seconds
[INFO] Finished at: Fri Aug 23 04:00:33 UTC 2013
[INFO] Final Memory: 124M/483M
+ cp target/release/geoserver*-bin.zip /var/www/html/geoserver/master/geoserver-master-2013-08-23-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-master-nightly/1587/&gt;
